  1. Jul 9, 2024 at 2:21 PM
    "Japan...big surprise."
  2. Jul 9, 2024 at 2:35 PM
    The Black Mamba
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    I fixed that after the pic was posted when @artsr2002 pointed it out to me.
  3. Jul 9, 2024 at 2:42 PM
    Pssshhhhh. I double spring.
  4. Jul 9, 2024 at 4:04 PM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    South of ATL
    We have a local store that sells Shiner Blonde, one of my favorites. First had it at a bar on the River Walk years back.
    Then we drove over to Austin the next morning to eat @ Franklin's
    It was a cool trip
  5. Jul 9, 2024 at 5:05 PM
    I was doing the same. But when I was trying to figure out my goddamn squealing shit, I pulled the lower out, and was too lazy to reinstall. Yes, I know, it'd only take 2 minutes per side to reinstall. I'm just too damn lazy to get under the truck again, until the next oil change.
    Ugh, that @artsr2002 guy again, with his holier-than-though nitpicking! :rofl:
    (I love that guy)
    bmf4069 and artsr2002 like this.
  6. Jul 9, 2024 at 5:27 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Had not turned a wrench on the ole girl in a while... it got me out of a little slump and made me feel good.
    Up for a challenge apparently. Bell Cranks/Parking brake nonfunctional for Years
    Driver side
    Pivots got working pretty easily, no problems.
    The NO-SAG reach around cable run... interesting.
    Passenger side. Everything on these cranks is frozen up tight AF
    Bolts, pretty sure these were 13mm to start, a solid 12mm now
    Drivers was about as expected. Looks like aluminum in there. A ton of white powder under the boot. sniff sniff
    Got the Passengers side to come free, bonus!
    Tucked away the cables while I test my patients extracting the broken bolts, and freeing up the arms on the bell cranks.
    Did the manual adjustments while I was there. (wheels up/neutral/make them drag a bit) Learned how to reach around and install the grommets by feel with the wheels on... forgot to put them back beforehand.
    Last October when I did the brakes for the first time in the rear/and adjusted the rears like this it took at least 2in of down travel off my brake pedal!
    Thinking about stripping the boots off and soaking them in vinegar, maybe ATF... for a few days. Taking advice and recommendations :thumbsup:
    Could be a lost cause, but I have patients.
    Anyone used the set of bell cranks from Rockauto? Curious of fitment/quality.
    Ill post my progress on these crusty little barnacles though.
    Kimosabe, bmf4069, oscardog86 and 2 others like this.
  7. Jul 9, 2024 at 5:28 PM
    VR6T
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
    Fuck that nut
  8. Jul 9, 2024 at 5:31 PM
    VR6T
  9. Jul 9, 2024 at 5:35 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Bust that Nut:rofl:o_O
    VR6T[QUOTED] likes this.
  10. Jul 9, 2024 at 5:36 PM
    Is that green mold??
  11. Jul 9, 2024 at 5:38 PM
    Man, you really busted that nut!
    Great penetration and puddlefor such an odd position.
  12. Jul 9, 2024 at 5:39 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Where Jack? I see some green on the closeup of the broken bolts... is that it?
  13. Jul 9, 2024 at 5:40 PM
    Maybe my eyes are going but everything has a green hue and the backplate looks partially green.
  14. Jul 9, 2024 at 5:40 PM
    Bed Tundy
    Bed Tundy Like changing a tire, the 1st time you're careful
    Neature Gary
    Moscow, ID
    (W) 2005 AC 4.7 4x4 with VSC, (G)2005 AC 4.7 TRD Sport RWD
    See Signature or my Photo Album
    NICE! haha
    Installing lift kit soon, SPC UCA, OEM LBJs/bolts, 6112's, smx-122270T, and new LCA bushings. Do I need to get all new Cam assembly for Toe Adjustments? I don't think anything is wrong with the current ones but is there any reason I should replace them after 20 years?
    oscardog86 and VR6T[QUOTED] like this.
  15. Jul 9, 2024 at 5:41 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Its the lighting, I promise you its Solid Effin Rust hahaha
  16. Jul 9, 2024 at 5:42 PM
    If you can put the parts in a tub, either oxalic acid mixture (get the granules to dissolve at hardware store) or Evaporust.
    If the parts are installed and rusted in-place, slather on Naval Jelly from Loctite, rinse after 30 mins. Repeat a few times. It'll eat the rust out.
    BroHon[QUOTED] likes this.
  17. Jul 9, 2024 at 6:12 PM
    VR6T
    You say that, and you're not wrong but I torqued the weld off the first go around. Had to get the 5 pound mini Thor to break it loose. Motherfucker was on there. Aaron and his fucking impact gun.
    Added a little anti seize to all 6 so when I go to put the new ones in Saturday after work I won't have an issue.
  18. Jul 9, 2024 at 6:25 PM
    VR6T
    This is why we're friends
  19. Jul 9, 2024 at 6:28 PM
  20. Jul 9, 2024 at 6:29 PM
    VR6T
    Jokes on you, I used rubber gloves this time lol
  21. Jul 9, 2024 at 6:34 PM
    We changed out a DHW circulation pump today, and we usually slather the gaskets in AS, hahah I stood on the other side of the room while that was going down
    bmf4069 and BroHon like this.
  22. Jul 9, 2024 at 6:59 PM
    Well at least it’s solid. Mine’s falling apart. Haha
    I do take the bell cranks out every few years, sand them down and grease up the pins so they won’t freeze in place.
    BroHon[QUOTED] and FrenchToasty like this.
  23. Jul 9, 2024 at 7:04 PM
    Hahah thanks for that chuckle
  24. Jul 9, 2024 at 7:08 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    :rofl::rofl:or like this
    I like the copper on stainless fasteners. But AS is very similar to say... roofing tar :cool: :rofl:
    bmf4069, Mr.bee, VR6T and 1 other person like this.
  25. Jul 9, 2024 at 7:30 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    I drilled and tapped the holes 1/4-20, pressed out the pin on the arm
    Then I noticed it was already split completely down one side. and then it fell apart...
    The other side I dismantled just for S&G I guess?
    Ordering new.
    Old break with corrosion in it.
  26. Jul 9, 2024 at 7:33 PM
    Were they frozen? Sounds like the PO did zero maintenance.
  27. Jul 9, 2024 at 7:48 PM
    VR6T
    Shit just even hitting them up with PB Blaster will keep them in working order
  28. Jul 9, 2024 at 7:56 PM
    Ain’t nobody going out in the snow to do that here. Haha
    Festerw and FrenchToasty like this.
  29. Jul 9, 2024 at 8:40 PM
    VR6T
    Also fluid film all of it before the snows come PB Blaster for non snow months
  30. Jul 9, 2024 at 8:44 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    i'm a kopr kote man myself. It leaves classier stains.
