  1. Jul 3, 2024 at 11:26 PM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    So that particular AAL ads like 1"?
    I have 1.5" single OG Wheeler AALs in OE pack from like a decade ago. Getting a little (normal) Toy lean on the rear left (@ 250,000 miles) and considering what to do next.
  2. Jul 3, 2024 at 11:26 PM
    ToyotaDude
    ToyotaDude Member
    shifty` and JakeJake like this.
  3. Jul 3, 2024 at 11:28 PM
    VR6T
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
    No clue cause who ever put it in put it in backwards...... @Mr.bee @455h0le_dachshund @FishNinja can atest to it.
  4. Jul 3, 2024 at 11:34 PM
    ToyotaDude
    ToyotaDude Member
    Remember the build thread. So basically you expected 6 leaves x 1/2" for 3" total when you decided to build it up that way?
  5. Jul 3, 2024 at 11:50 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Most single AALs advertise 2" and most progressive AALs (3 leafs) advertise 1.5"
    Edit: to answer the lean, your could swap side of your leaf packs and adjust your front suspension by either using a shim spacer on the driver side or if you have adjustable coilovers, use them to raise the front a half inch or so.
    oscardog86 likes this.
  6. Jul 3, 2024 at 11:57 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Definitely trial and error involved if you're a perfectionist. I know a handful of others have done a fair bit of trial and error. I think a few just get lucky and are happy with their first attempt
    oscardog86 and JakeJake like this.
  7. Jul 4, 2024 at 4:31 AM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    I have some wiggle room since the truck gets 700lbs of camper and gear loaded. I will have airbags too, so some ride height adjustment can be made. I am fully prepared to add/subtract leaves until I am happy.
    Thanks for the Serra heads up, I had almost forgotten I was waiting for a sale. I picked up steering rack boots, clamps, outer TRE's, and a PCV valve. Saved $54 by their math.
  8. Jul 4, 2024 at 5:33 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    So you probably gonna ditch those 5100's and assuming OEM coils for some
    adjustable 2.5's with 700lb coils down the road
  9. Jul 4, 2024 at 7:57 AM
    JakeJake
    2000 Tundra AC 4X4
    Woke up an hour before my alarm, and was in the shop by 6. A good thing if I want the truck back on the ground today.
    Made up these doublers to replace the factory units that I peeled off.
    At my desk finalizing the spring perch design for the u bolt eliminator. Wish me luck!
  10. Jul 4, 2024 at 8:31 AM
    805Tundra
    805Tundra New Member
    Ben
    Central Coast
    2004 White 4x4 Double Cab
    ya, it’s a WIY kit from coastal offroad
  11. Jul 4, 2024 at 11:34 AM
    ToyotaDude
    ToyotaDude Member
    How did you bend that?
  12. Jul 4, 2024 at 11:48 AM
    I'm going to guess it's steel pipe cut in half and dressed, if not rolled.
    ToyotaDude and JakeJake like this.
  13. Jul 4, 2024 at 12:01 PM
    JakeJake
    2000 Tundra AC 4X4
    @shifty` nailed it. It's "canoe'd" pipe.
    MORE
  14. Jul 4, 2024 at 12:06 PM
    ToyotaDude
    ToyotaDude Member
    It's be u ti ful Art.
    Weejub and JakeJake like this.
  15. Jul 4, 2024 at 12:07 PM
    BroHon
    BroHon Bitch in the Mitten
    Bro
    2000 SR5 AC 4x4 4.7
    Sketchy street barnacle
    You do really nice work Jake, enjoy seeing that level of creating and craftsmanship :thumbsup:
  16. Jul 4, 2024 at 12:10 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Pretty. So why'd you ditch the stock ones?
    At first I thought maybe you'd have gotta Sequoia axle, but then I saw the drums.
  17. Jul 4, 2024 at 12:16 PM
    Curiosity more than anything here, but how will you set the angle it'll get welded on, or is there some rule of thumb, like always weld the tops parallel to the pinion shaft? I mean, I realize you can shim if the pinion angle is off, it's what I've typically done on major drops, but I've never built an axle with its provisions from the ground up.
    Are you also planning to weld up provisions for a rear sway?
    oscardog86 and FrenchToasty like this.
  18. Jul 4, 2024 at 12:19 PM
    Damn, dude. I get jelly every time I see this stuff. Did you cut that with some type of programmable plasma cutter? Very nice symmetrical edges.
    oscardog86 and BroHon like this.
  19. Jul 4, 2024 at 12:25 PM
    I was thinking the same thing, I’m sure he’s got a base measurement to go off of
    shifty`[QUOTED] likes this.
  20. Jul 4, 2024 at 1:35 PM
    ToyotaDude
    ToyotaDude Member
  21. Jul 4, 2024 at 1:38 PM
    ToyotaDude
    ToyotaDude Member
    Anyone know of replacement LSD stickers? The writing on these (and others like on the front diff and CVs) don't seem to react well to solvents.
  22. Jul 4, 2024 at 3:10 PM
    JakeJake
    2000 Tundra AC 4X4
    I center punched through the original spring hangers before removing them just a a reference. The two punch marks could be connected with a line to get a centerline layout mark to the original locations.
    Some guys just pick a pinion angle between 3-5 degrees, and some guys measure the t-case output angle and do the opposite on axle side.
    You are supposed to set the pinion angle at ride height. The way I have fabricated the u bolt eliminators I have plenty of rotational adjustment :D I Think I have 13 bags of 80lb quickcrete around here (1040 lbs) that I could load the chassis with to simulate the weight of the flatbed/camper combo. Or I guess that's the working plan? Fast and Loose.
    I hadn't thought about a rear sway bar, I'll have to look into that!
    I got interested in the u bolt eliminator because I'll likely have to do some fine tuning on the leaf pack.
    I can get the 8 grade8 nuts and bolts locally and pay by the pound. Costs about $20 for the whole set. vs ordering u bolts and waiting etc.
    It will make putting the airbag cups where I want them much easier.
    It's been said that it controls axle wrap much better than a standard spring perch.
    Just because I can :p
    Springs are assembled and ready to go in, just gotta reference the shackle and bolt orientations. Top plates/ lower bag cup mount coming right up!
  23. Jul 4, 2024 at 3:22 PM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    I used to have a rod holder that was made of aluminum, it was a 90 with a little lip on the back. Kinda looked like this IMG_4720.jpg
    worked great
  24. Jul 4, 2024 at 3:40 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    So no u bolts... Ok this is all new to me.
    So you going to sandwich the leaf springs between two plates with four bolts?
  25. Jul 4, 2024 at 3:42 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    If you know a good way to remove them and keep in tact, I have an elocker now and don't need my LSD sticker.
    Once my other tundra gets its TrueTrac, it won't need the sticker either. As they don't require LSD oil
  26. Jul 4, 2024 at 5:57 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
  27. Jul 4, 2024 at 6:48 PM
    Part number is 41991-22010 with substitute p/n 41991-04030. I found repops @ https://nightrungarage.com/products/toyota-lsd-decal
  28. Jul 4, 2024 at 7:42 PM
    JakeJake
    2000 Tundra AC 4X4
    So close, I should have cut a few test holes for the hex. Im out of 3/8 material, so I'll have to finish this thought in the morning. Damn good day overall though, and should be on all four tomorrow!
    bmf4069, oscardog86, Weejub and 11 others like this.
  29. Jul 4, 2024 at 8:02 PM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    A Sequoia rear sway bar might fit? I took a close look at one at a wrecking years not to long ago, and it looked like it wouldn’t be that difficult to make it work on a tundra. The best part is that it’s high clearance design, so there’s nothing that hangs down below the axle housing.
    oscardog86 and 455h0le_dachshund like this.
  30. Jul 4, 2024 at 8:14 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    You going to clean up and paint that frame while you got the bed off?
