Dashcam in 3rd gen tundra
Discussion in '3rd Gen Tundras (2022+)' started by bobsicle, Jul 2, 2024.
  1. Jul 2, 2024 at 8:27 AM
    bobsicle
    bobsicle [OP] New Member
    Bob
    Red trd or limited
    A little thread about installing a dashcam in a 3rd gen limited tundra. FYI
    so far:
    VANTRUE n4 camera with rear camera
    Front.
    mounted as high as possible directly behind the rear view mirror. I can barely see it from the driver seat (I don’t like seeing it/videoing myself but the inside cam can see my passengers).
    rear.
    Mounted behind rear headrest on a mount clipped onto the trim. I made this by folding a piece of thermoplastic. This way the window still works.
    wire was easy to run from front to back up through the hole by the rear view mirror then past the sunglass holder which pulls down (with an uncomfortable amount of force). Gentle pull on the headliner by the sun roof gives loads of space then pushed an old bicycle brake cable housing up from the dismantled rear to pull it through the last bit.
    next I’m going to hook the vantrue power supply to the spare plug up by the sunglasses holder and I’ll let you know it that works. IMG_5249.jpg IMG_5246.jpg
  2. Jul 2, 2024 at 8:29 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Tundrastruck91 likes this.
  3. Jul 2, 2024 at 8:35 AM
    Dpoll995
    Dpoll995 New Member
    Houston TX
    2024 Tundra Limited
  4. Jul 2, 2024 at 8:40 AM
    eddiefromcali
    Eddie
    100% Stock
    Yes I do use it. Think I've posted pictures before in other thread but it looks just like the pics in the link...theres an older gen tundra pic there...same thing. Just pull the weatherstrip down, slide the mount on and put the strip back in place....done.
  5. Jul 2, 2024 at 8:46 AM
    eddiefromcali
    Eddie
    100% Stock
  6. Jul 2, 2024 at 8:48 AM
    bobsicle
    Bob
    Red trd or limited
    I considered it. Canada is the answer. That said, wherever you put your camera it’s mainly a bed cam. But mine has a decent view.
  7. Jul 2, 2024 at 8:52 AM
    eddiefromcali
    Eddie
    100% Stock
    dang..they wont ship to canadia? You can always ask one of us to ship it to you...done it plenty of times when vendors wont accommodate
  8. Jul 2, 2024 at 9:18 AM
    bobsicle
    Bob
    Red trd or limited
    IIRC they will but it costs much more than the part. I’ll probably take you up on that offer at some point though. The thermoplastic is surprisingly easy though. Cheaper than a 3d printer too.
    eddiefromcali likes this.
