  1. Jun 28, 2024 at 5:38 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    That looks so damn nice man. :drool::thumbsup: Great work!
    JakeJake[QUOTED] likes this.
  2. Jun 28, 2024 at 6:02 PM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    whered your flappy flaps go?
  3. Jun 28, 2024 at 6:04 PM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    I'm about to install them, ill shoot you a pic
    @FishNinja just kidding they are pretty beat up. Im going to think about remaking them.
    They go forward of the shock towers. Not sure why they are called "rear fender apron seals" unless im missing 2 of the four.
    Edit Edit- Son of a bitch, I have one front and one rear.
  4. Jun 28, 2024 at 6:13 PM
    KTM_AJ421
    KTM_AJ421 New Member
    AJ
    2006 SR5 DC 2WD 4.7
    what clip are you running those 5100s at? How’s the ride?
  5. Jun 28, 2024 at 6:16 PM
    JakeJake
    2000 Tundra AC 4X4
    Bottom or #1 with an ome 2884 spring. The test drive was mind blowing, but I only have about 5 miles on the setup so far.
    oscardog86, bmf4069, shifty` and 2 others like this.
  6. Jun 28, 2024 at 6:21 PM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    What did you use as a catalysis?
  7. Jun 28, 2024 at 6:24 PM
    JakeJake
    2000 Tundra AC 4X4
    Majic/Krylon/Vansickle/Rustoleum and im sure others make an alkyd/enamel catalyst. I use Majic as its available next to the tractor paint at the farm store.
    BroHon and whodatschrome[QUOTED] like this.
  8. Jun 28, 2024 at 6:34 PM
    FishNinja
    Lee
    06DC2wd
    I mean honestly, do we even "need" them? Lol mine are there just cause they've lasted this long. I bet you can get the old carpet liner from a sedan trunk or something and just cut out some pieces and zip tie them up.
  9. Jun 28, 2024 at 6:35 PM
    Knobs are in. I like em. The mounting shafts for these are way more robust than the OEM. 2 of mine were cracked, I had already glued and tape wrapped one.
  10. Jun 28, 2024 at 6:42 PM
    JakeJake
    2000 Tundra AC 4X4
    Ive got a sheet of kydex around here somewhere, not sure that would handle the heat well. Aluminum? I know a guy that repurposes an aluminum sign from time to time...
    Really it just needs some bling bling pie cut titanium exhaust :D
    455h0le_dachshund likes this.
  11. Jun 28, 2024 at 6:48 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
  12. Jun 28, 2024 at 7:09 PM
    whodatschrome
    lots of dents
    That’s some mid-70’s ford power steering technology for ya..
    EDIT: and i just realized that about 5 years ago i was looking for these EXACT fender well exit headers for my 1971 F250! I ended up giving up on my header search and decided to just swap in a 12v cummins instead. I did just order replacement inner fenders (aka fender aprons) last week for the Ford. My current aprons have been cut most of the way out, and i want some engine bay protection from mud and other crud.
    Mr.bee[QUOTED] likes this.
  13. Jun 28, 2024 at 7:09 PM
    Do they feel secure when you turn them? I may have to pick up a set.
    Care to share the link again?
    Tundra2 likes this.
  14. Jun 28, 2024 at 7:18 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    No aprons here. Gotta show off the long tubes. :muscleflexing:
    They ain't shiny any more :(
  15. Jun 28, 2024 at 7:31 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
  16. Jun 28, 2024 at 7:34 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Like corn on the cob?
  17. Jun 28, 2024 at 7:36 PM
    whodatschrome
    lots of dents
    interesting...the Dorman look to be better quality that the OEM ones i bought 6 months ago
  18. Jun 28, 2024 at 7:41 PM
    whodatschrome
    lots of dents
    I just went over to my shop to see if my JDM Toyota bB HVAC “crystals” would fit the tundra. No dice. The tundra has a square drive hole, while my scion xB has a round-ish drive hole.
    4F29390D-32E8-4C25-A48C-BD7AD8F0E75E.jpg BEE9DCA4-0722-4AFB-B11D-18E3729E75E9.jpg
    NUDRAT, bmf4069, TX-TRD1stGEN and 5 others like this.
  19. Jun 28, 2024 at 7:55 PM
    Super solid. Way less brittle than the OEM knobs.
  20. Jun 28, 2024 at 7:56 PM
  21. Jun 28, 2024 at 7:57 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    What size is the square?
    Tundra2, oscardog86, NUDRAT and 10 others like this.
  22. Jun 28, 2024 at 8:01 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Chasing a rattle in my dash between the radio and the airbag. I found this module just hanging out. Looks like I’m missing a mounting bracket like the one circled. Used some zip ties for now.
    wire under that box was chewed/cut or snipped by someone also. I think it answers while my radio antenna sucked
  23. Jun 28, 2024 at 8:16 PM
    I have a spare NOS OEM one if it’s the one you need. Which do you have?
    The drivers side are stamped out with L for front of tower and LL for behind tower. Passenger side is R and RR respectively. I think I have an extra RR.
  24. Jun 28, 2024 at 8:16 PM
    Thanks, this is what I’ve been wanting to see.
    artsr2002[QUOTED] and FishNinja like this.
  25. Jun 28, 2024 at 8:20 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
  26. Jun 28, 2024 at 8:20 PM
    VR6T
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
    Those must sound amazing. Oil changes would be a bitch tho
  27. Jun 28, 2024 at 8:21 PM
    VR6T
    1/4 x 1/4 inch usually
  28. Jun 28, 2024 at 8:23 PM
    JakeJake
    2000 Tundra AC 4X4
    Good info, and thanks!
    I have an R and an LL. Really they are so bad that they will just get used as patterns for whatever I reproduce them in.
    If it's not too much trouble, a picture of it with the blade of a tape measure laid over the top would give me all the info I need. Willing to pay one hand drawn spider.
    bmf4069 and BroHon like this.
  29. Jun 28, 2024 at 8:23 PM
    VR6T
    Anyone know where I can find the led compadible flasher module?
  30. Jun 28, 2024 at 8:26 PM
    JakeJake
    2000 Tundra AC 4X4
    Man I would run those in a heartbeat. If nothing else just to poke fun at the round knob crew.
    Also, how do you like the scion? I keep an eye out for the right 1st gen xb.
    Edit- Thats a $200 hand-full of knobs!
