General Supercharger Thread
  1. Jun 27, 2024 at 5:57 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I do as well. Your bypass will look generally similar to the photo.
  2. Jun 27, 2024 at 6:03 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    the Harrop version
  3. Jun 27, 2024 at 6:14 AM
    Ctaylor76
    Ctaylor76 New Member
    Chaz
    Houston
    2021 Tundra Supercharged
    BDS 4.5 inch coil over lift BDS UCA’s 35 inch ridge grapplers AT 20 inch methods with offset 5.29 Nitro Gears ARB rear air locker with dual stage air compressor RC switch panel Both bumpers are RC LED Bumpers (6 pods and lower LED light bar) AMP Research power steps Lower RC Tow hooks B&M Transmission Pan CSF Radiator Radium Duel Catch Can BDS recoil traction bars Helwig adjustable rear sway bar Retrax Power Trax tunnel cover NSV LED front light bar Morimoto XB LED Head lights DOOD Rear smoked LED Tail lights (Amazon) NSLUMA Smoked 3rd brake light (Amazon) Morimoto 4 Banger LED A pillar lights Boostautoparts LED tow mirrors w/ power fold (smoked black) Full 3 inch true duel with XF Flowmaster mufflers custom Vbands Steelworks Longtube Headers RC seat covers OEM Audio plus full sound system duel sub 13 inch Phoenix Automotive In dash screen Stater X remote start system Uniden R8 Radar detector Odyssey Extreme Battery RC Seat Covers RC Rubber Mat Bed Cover Full body color door handles & TRD Grille OEM Magnuson TVS2650 Supercharger
  4. Jun 27, 2024 at 6:15 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
  5. Jun 27, 2024 at 6:16 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    ^^^awwwwe the streets of Mexico are ladened with rubber!
    Saltyhero13 and reywcms like this.
  6. Jun 27, 2024 at 6:30 AM
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    I did that adjustment on the Taco s/c and DID hear the "tink" sound. But I think my Tundra maggy was adjusted properly when I tried on it.
    ARES35, Wynnded, Mdl and 1 other person like this.
  7. Jun 27, 2024 at 6:52 AM
    JohnWhicker
    JohnWhicker New Member
  8. Jun 27, 2024 at 6:59 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Wynnded and Mdl like this.
  9. Jun 27, 2024 at 7:01 AM
    e30cabrio
    I have had sporadic issues with the sensor, Innovate (Autometer) replaced it & it started working again. It is a Bosch unit so not Innovate's fault & I believe it is the same unit every manufacturer uses.
    blenton and PolishedTRD like this.
  10. Jun 27, 2024 at 7:16 AM
    M3Tundra-JK
    Scott
    2005 GX470
    Super easy on the Tundra since the bypass is in thr front of the s/c. It's just turning an Allen head screw
  11. Jun 27, 2024 at 7:33 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Does the banks have a wideband afr accessory sensor?
    AEM but then it's 2 gauges, one for boost and another for afr's. I'm still using their old failsafe with both boost and afr. Still going after 12 years and 2 sensors...
    ARES35 likes this.
  12. Jun 27, 2024 at 7:34 AM
    pursuit2550
    pursuit2550 New Member
    I read that also and went with AEM. But if I had to do it over again Aero Force Interceptor would be my go to. I have had them before without issues and it's a multi use gauge. Hooks up to your OBD and you can buy add on acct sensors.
    Mdl likes this.
  13. Jun 27, 2024 at 7:44 AM
    e30cabrio
    Assuming I read it right, turn until there is tension and back a hair?
  14. Jun 27, 2024 at 8:05 AM
    TurboKits
    TurboKits New Member
    Yeah buddy!
    AZTundra[QUOTED] likes this.
  15. Jun 27, 2024 at 8:08 AM
    TurboKits
    Welp... Back to our testing on lowering IATs in general. We did get one of the Stillen Intakes with the patent pending intake scoop. Unfortunately, the location and geometry aren't going to work with the filter location on the turbo, so before we send this baby back. Does anyone want a killer deal on the intake to save us the extra paperwork?
    We have the TP403203 - Trupower by STILLEN Stage 2 direct flow cold air intake with dry air filter 2014-21 Tundra 5.7, BRAND NEW and can ship right out. Thanks!
    Link: https://www.turbokits.com/2014-2021-tundra-5-7l-stillen-trupower-cold-air-intake.html
    ARES35, Saltyhero13, reywcms and 5 others like this.
  16. Jun 27, 2024 at 8:31 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Sounds about right. I did mine when I pulled the snout for the @snivilous pulley hub. It was still at factory settings.
  17. Jun 27, 2024 at 8:38 AM
    M3Tundra-JK
    Scott
    2005 GX470
    Yup! Turn until tight, then back it off and you should hear this "tink" sound (at least I did on the Tacoma), then leave it be.
    "Adjust counter clockwise to allow for further valve butterfly stop. You can physically feel the valve bind when you have went to far. Back it out just a hair and you'll hear a solid "tink" sound, which is your good to go audible indicator that it is fully adjusted and ready for playtime.
    (Note: The blower is upside down in this photo, and the Allen head which requires adjustment has pink loctite on the threads of it.) This adjustment is accurate to a properly adjusted valve and is exactly where mine is adjusted to as well when I hear the audible "tink" sound."
    ARES35, Saltyhero13, Wynnded and 3 others like this.
  18. Jun 27, 2024 at 8:42 AM
    e30cabrio
    Seeing as it's already 104, not going out there today. :(
    Wynnded, Mdl and M3Tundra-JK like this.
  19. Jun 27, 2024 at 9:04 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    It's 57 and trying to rain here...
  20. Jun 27, 2024 at 9:06 AM
    blenton
    blenton New Member
    I believe that what @e30cabrio said is correct - they all use the same sensor(s) from the likes of Bosch. My PSB-1 has been installed for 6 months and so far so good. Knock on wood..
    As far as the Banks iDash, when I looked in to them at the same time as the PSB-1, I don’t believe they had the hardware side worked out to monitor boost and wideband AFR on a vehicle not originally equipped with those two sensors, like our tundras. IIRC, you can add modules via their CanBUS system but they didn’t have any compatible with the tundra; or they weren’t available and were “upcoming products”. Either way, the iDash wasn’t a viable option at the time. If it were, it would have been much more expensive than the Innovate setup for all the hardware. Hopefully Banks keeps pushing things forward but the PSB-1 checked all the boxes for me for a great price. It also allows me to datalog that info using HPTuners MPVI3 and ProLink, alongside the vehicle data from the ECU.
    That said, I’m looking at getting the simpler version of the iDash to monitor everything else. My Craven speed mount has room for two gauges so I guess I might as well use it.
  21. Jun 27, 2024 at 9:09 AM
    JohnWhicker
    Ok, the bosch sensor seals the deal for me, since is the same one across multiple vendors. So I will go with the PSB-1 and add the ScanGauge 3 to the mix.
  22. Jun 27, 2024 at 11:37 AM
    NatesNightMare
    NatesNightMare Is what it is
    Pinetop Az
    Checked mine and its not in there or in the hose anywhere
    Wynnded[QUOTED] likes this.
  23. Jun 27, 2024 at 11:45 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I believe Whipple and Harrop don't have them either. After some further review think it's up to the tvs2300 series.
    reywcms, Wynnded and HulkSmurf14 like this.
  24. Jun 27, 2024 at 12:14 PM
    e30cabrio
    All this mirrors my experience, plus the antiquated software Active Autowerke uses for my BMW only works with Innovate for getting AFR into the logs so I lucked out there.
  25. Jun 27, 2024 at 1:02 PM
    blenton
    blenton New Member
    Unless Whipple is hiding the valve somewhere else, I can confirm there isn’t a tiny brass orifice in the bypass valve that they supply.
  26. Jun 27, 2024 at 1:04 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I can't keep track of who has what. So, if you're running a TVS 2650 Whipple/Harrop, please check for the orifice at the bypass and report back please. Two units not having one is a coincidence, more becomes evidence/confirmation ...or some such :p. Thanks!
  27. Jun 27, 2024 at 1:08 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I just noticed that your bypass has....uh, two nipples. I wonder what the unconnected one's purpose is.
  28. Jun 27, 2024 at 1:10 PM
    snivilous
    SW UT
    300k+ Supercharged 2008
    Looks like it's on the other side of the diaphragm, so presumably if you want to actuate it with positive (increasing) pressure as opposed to sucking on the top one :D
    e30cabrio, ARES35, Fastlane47 and 6 others like this.
  29. Jun 27, 2024 at 1:12 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I guess that as long as the end result is the same, the approach isn't as important, huh? :rofl:
  30. Jun 27, 2024 at 1:40 PM
    bflooks
    bflooks New Member
    Metrowest MA
