Interesting informed take on the Tundra Recall
Discussion in '3rd Gen Tundras (2022+)' started by cmiles97, Jun 26, 2024.
  1. Jun 26, 2024 at 3:45 PM
    CC TIGER
    CC TIGER New Member
    2024 Limited 4x4
    Heritage Grill
    I imagine if they had identified the problem and developed a new part in January of 24 they would not be installing the "old" engines after the date of the new part. Why would they continue creating problems for themselves?
  2. Jun 26, 2024 at 4:05 PM
    jctmundra
    jctmundra New Member
    Northern VT
    '23 1794 Hybrid Stunning Mesquite/Cream
    How do you know a "old" engine was installed?
  3. Jun 26, 2024 at 4:20 PM
    CC TIGER
    CC TIGER New Member
    2024 Limited 4x4
    Heritage Grill
    I don’t know, and I guess I wasn’t clear what I meant. I was saying it would make sense to me if Toyota ONLY installed new engines starting when the new part # came out. They wouldn’t continue installing old engines. I also felt like that is what TCCN was saying. Unfortunately, it is all speculation.
  4. Jun 26, 2024 at 4:40 PM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    I think the challenge is trying to read between the lines in the recall notices.
    Why would we need a different short block if the debris issue was fixed in early 2023? Wouldn't all the engines be the same if there was nothing wrong with them other than debris? Did Toyota switch the main bearings to a more debris tolerant metal?
    We would need to know what the part number is for the debris :)
    This smells like someone put a red herring in the heating duct last week!
    in_the_mud and Retired...finally like this.
  5. Jun 26, 2024 at 4:44 PM
    5thgen
    5thgen New Member
    Seattle
    2024 limited trd crewmax
    What happened to Ryan? He disappeared from FB too.
    HighroadTRD likes this.
  6. Jun 26, 2024 at 4:48 PM
    Lee.M
    Lee.M New Member
    TN
    24tundra limited 4x4
    Level/35s
  7. Jun 26, 2024 at 5:00 PM
    demfer
    demfer New Member
    But Ryan won't tell you to let the lord bless you and hold you?
    75tranzam and Vizsla like this.
  8. Jun 26, 2024 at 5:02 PM
    raylo
    raylo not so new member
    Frederick, MD
    DashCam, amp & sub, DIY rear seat delete, cat shield
    But I believe he did suggest replacing your coolant with a 50/50 mix of Toyota antifreeze and holy water. ;-) Maybe that would exorcise our engine demons.
  9. Jun 26, 2024 at 5:59 PM
    mass-hole
    mass-hole New Member
    Im not convinced we got the whole truth. Something isn’t adding up to me.
    Westerntowboss, raylo and DimSum07 like this.
  10. Jun 26, 2024 at 7:46 PM
    katekebo
    katekebo New Member
    Based on the part number change and as implied by TCCN, it appears that Toyota didn't implement a definitive engineering change (either redesign and/or change to manufacturing procedures) until January 2024. However, in the letter to NHTSA they mention that they improved cleaning procedures some time between January and September 2023. Most likely Toyota only recalled early production vehicles because they are more likely to fail due to mileage, and are waiting for more results from the interim change implemented between early/mid 2023 and January 2024. It is possible that they will expand the recall to newer (pre Jan 2024) vehicles at a later date.
    CC TIGER likes this.
  11. Jun 26, 2024 at 8:33 PM
    BossDawg24
    BossDawg24 New Member
    Mark
    Cumming, GA
    2023 Tundra Capstone Blueprint, 2017 1794 Barcelona Red
    None
    My manufacture date is 2/13/2023, also have a hybrid. Hope I dodged the bullet both ways.
  12. Jun 26, 2024 at 9:10 PM
    jctmundra
    Northern VT
    New PN does not have much value.
    The PN can change for many reasons such as change of supplier, change in another unrelated part/process. Why hasn't the PN changed when previous cleaning processing improvements occurred?
    Too bad Ryan never got around to sharing his short block dissection.
    coTony and Lee.M like this.
  13. Jun 26, 2024 at 9:16 PM
    40man
    40man New Member
    I thought it was a good video. Basically saying that if it was a blockage, the rod bearings would go first, which makes sense as they'd be more starved of oil than the main bearing. Also confirmed that the debris
    The current offerings of 0w20 limit zinc/phosphorus. So generally 800 ppm is what you'll find. I highly doubt that is an issue.
    Cleaning procedures happened after that. You are in the zone, but excluded because hybrids have motive power to pull over...
  14. Jun 27, 2024 at 2:13 AM
    raylo
    Frederick, MD
    Exactly the point I was making to AZ. ZZDP is an anti-wear agent and the zinc levels we see are normal based on the oils we use, as noted in the analysis reports.
  15. Jun 27, 2024 at 2:37 AM
    Retired...finally
    I have to hand the Nut a point for mentioning the number of failures could probably be much higher than the official number given by Toyota. What he claims make sense. At least some of it.
    Polo08816 and raylo like this.
  16. Jun 27, 2024 at 2:43 AM
    raylo
    Frederick, MD
    Yeah, he is always really straight with his presentations. And as a Toyota fanboy you can see how much this hurts him. He grimaced and used the very expression that I have told my friends: this is really bad. But I am keeping my faith for now that Toyota will do the right thing by us.... unless and until they do otherwise.
    Also interesting to see he left his job as a Toyota tech and opened a shop. I wonder where it is?
    Polo08816 likes this.
  17. Jun 27, 2024 at 3:36 AM
    MEGA VOL
    MEGA VOL New Member
    24 1794 limited edition
    He is located in Chicago
    Tundrastruck91 and raylo[QUOTED] like this.
  18. Jun 27, 2024 at 4:07 AM
    Lee.M
    Lee.M New Member
    TN
    Level/35s
    I belive toyota told the truth about engine debri. Do not think its design flaw or oil type related. After changing my oil twice on my 24 and seeing the size and qaunity of debri. I can relate to there claim I think they do not have a full grasp on how many engines. No matter the build date are contaminated.
    j-utah and Vizsla like this.
  19. Jun 27, 2024 at 4:45 AM
    Retired...finally
    Did any of the debris look like the fine black casting sand that is often used in making the heads? If you had to guess the amount of total debris would you say it would fill a soda bottle cap? A concern I have is any debris caught by the filter has to go through the oil pump first. If it's casting sand it would ruin an oil pump very quickly and starve the engine of oil.
    I haven't seen anything but a very few metal slivers in any oil drain pan or filter for years. This is from Honda, Fiat and my 5.7. If I saw what some of the members here are posting, I'd be sick to my stomach and call a rollback to take the truck back to the dealer.
  20. Jun 27, 2024 at 5:29 AM
    #50
    Breathing Borla
    Northern Illinois
    really where , maybe I’ll go see him , ha!
    SnrDisregardo likes this.
  21. Jun 27, 2024 at 5:37 AM
    #51
    rlc177
    rlc177 Data Logger
    Northeast PA
  22. Jun 27, 2024 at 5:41 AM
    #52
    Lee.M
    Lee.M New Member
    TN
    Level/35s
    Yes black flakes like coffe grinds .So
    me in the forum of a grain of rice just not as big. Some fine metal flake to be expected but also some large aluminum and some good bits of shiny brass. My filter cut looked cleaned to my findings only a few metal flakes. If you look at the tundra oil pan it has the little dimple bowls wonder if they settle in that.
  23. Jun 27, 2024 at 5:53 AM
    #53
    Breathing Borla
    Northern Illinois
    Tundrastruck91 and MEGA VOL like this.
  24. Jun 27, 2024 at 6:57 AM
    #54
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    You would think ZDDP having an issue with silver bearings would cause the problem with the other bearings as well and just not #1 bearing and to a lesser extent #3 bearing.
    BaldMenace, VCheng and nobodyintexas like this.
  25. Jun 27, 2024 at 7:05 AM
    #55
    coTony
    Tony
    Montrose, CO
    A part and a process are two different things. The process is not in the BOM
  26. Jun 27, 2024 at 7:19 AM
    #56
    JJtruckon
    JJtruckon New Member
    JJ
    2018 Tundra
    Undercoating
    Part numbers do not change without a reason. Engine material would not affect just one or two bearings. Toyota is lying about the issues.
  27. Jun 27, 2024 at 7:31 AM
    #57
    WNY PAT
    WNY PAT New Member
    Western New York
    2017 Crewmax Limited (Mines) 2019 Crewmax SR5 (Work)
    Crazy times when people like me are thinking of jumping back to a domestic versus “rolling the dice” on buying another Tundra . I’m sure Toyota will fix the issue eventually, but in the meantime, it sure seems like there will be a lot of folks waiting on “goodwill” repair/replacement approvals from Toyota corporate when they’re out of warranty. I feel for you guys.
    myfirsttundra1 and j-utah like this.
  28. Jun 27, 2024 at 7:32 AM
    #58
    Retired...finally
    Part numbers change for almost any number of reasons. It could be something as simple as a different package or color or minor thread depth change to hole where a bracket mounts. Conclusion jumping seems to rampant on this forum. Toyota will fix it and treat the customer right. Remember the frame recalls? People with ratted out Tacomas on the way to the scrap yard got new frames.
  29. Jun 27, 2024 at 7:37 AM
    #59
    blschaefer1
    blschaefer1 New Member
    A 40 minutes video filled with speculations and theories isn't much help. Everyone needs to chill out and wait until Toyota rolls out the details of the recall. It should be forthcoming next month.
    Having said this, his comments regarding full engine replacements versus short block rebuilds makes sense. And the timing of the 350 new hires in Alabama is interesting.
    ChucklesToy likes this.
  30. Jun 27, 2024 at 7:46 AM
    #60
    rlc177
    rlc177 Data Logger
    Northeast PA
    There was an interesting info that AMD did give about the numbers Toyota reported.
    824 Warranty Claims: This means that these are the claims where the work has been done and the dealer got paid for the warranty work and the claim is closed
    166 Field reports: This is a number that is part of the 824 Claims not in addition to.
    The numbers don't include any trucks that are currently in repair waiting on parts, nor any that actually had this issue and then Toyota Denied the warranty claim.
