GEN 3 (2022+) Wheels and Tires Photo thread
Discussion in 'Wheels & Tires' started by Tsquare, Jan 16, 2022.
  1. Jun 25, 2024 at 8:22 PM
    #4981
    donproline
    donproline New Member
    Donny
    2023 White Tundra TRD Pro
    Stock 2023 Tundra TRD Pro
    2023 Tundra TRD Pro with Toyo Open Country AT3 35x12.5R18 on stock rims. No lift or level kit.
    ytank1, SWFL23TRDOR, Siblue and 5 others like this.
  2. Jun 25, 2024 at 8:26 PM
    #4982
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    @donproline
    If ever a truck should have come stock with 35's, it's this one. That just looks proper.:thumbsup:
    Bryzzo, SWFL23TRDOR and drewpweinerMD like this.
  3. Jun 26, 2024 at 4:24 AM
    #4983
    arrampico
    arrampico New Member
    2023 SR5 CM 4X4 SB Silver Tundra
    @FNWheels
    Dustin I’m reaching out to you via email - looking to get another set of wheels - from arrampico@gmail.com
    Can you check it out?
    Thanks!
  4. Jun 26, 2024 at 4:13 PM
    #4984
    FNWheels
    FNWheels New Member
    Dustin
    2005 Tundra and 2019 Tundra
    Thank you! I will respond to your email right now.
  5. Jun 27, 2024 at 2:36 AM
    #4985
    Tartar88
    Tartar88 New Member
    Steven
    24 trd pro
    Westtcot lift 37s
    I unbolted the fender liner brace and cut off the crash/ horn on the body mount. Then pinned back the fender liner. Also pinned the front liner forward too so it clears everything by a couple inches now at full lock compressed.
    az 3rdGen[QUOTED] likes this.
  6. Jul 2, 2024 at 1:43 PM
    #4986
    Chomponthis
    Chomponthis New Member
    Billings, MT
    2023 Tundra Limited Cremax 4x4, TRD OR
    Before: stock TRD OR wheels & tires
    After: TRD Pro wheels with General Grabber ATX 275/70R18 (SL)
    TERRAble Pro and Tundrastruck91 like this.
  7. Jul 2, 2024 at 3:19 PM
    #4987
    dadrocz
    dadrocz New Member
    Ny
    23’ TRD Pro. 18’Platinum
    Agreed!!
  8. Jul 2, 2024 at 9:32 PM
    #4988
    xptundra33
    xptundra33 New Member
    This is the exact look I am looking for but I have 18 inch wheels, does anyone know how I would convert that?
  9. Jul 2, 2024 at 10:47 PM
    #4989
    davidfo
    davidfo New Member
    I got 18X9.5 +40 wheels for my 2024 tundra SR5 stock. What is the biggest all terrain tire size will fit without rubbing (no lift nor leveling).
    Thanks!!
  10. Jul 3, 2024 at 6:49 AM
    #4990
    drewpweinerMD
    drewpweinerMD MPG’s are for your moms Prius.
    Jeremy
    2024 Limited TRD OR
    RB20 Slims, BAK X4s, Fabtech Level, Cooper 35's
    Use this tool,
    xptundra33[QUOTED] likes this.
  11. Jul 3, 2024 at 8:27 AM
    #4991
    Northern Toyota
    Northern Toyota New Member
    2023 Tundra TRD Off Road, 2022 Tacoma TRD off road premium
    Tires and bilstein
    a 295/65/20 is a hard one to directly convert to an 18” wheel. 295/70/18 is the same width but almost an inch shorter. 295/75/18 is an option but not sure anyone making that size.
    285/75/18 will get you the height but 10mm narrower.
    There are a few companies making 35x11.5x18 tires which would be your closest conversion.
  12. Jul 4, 2024 at 10:35 AM
    #4992
    SM Tundra
    SM Tundra New Member
    Cody
    2024 Limited Smoked Mesquite Tundra
    Kind of wish I didn’t have the digital rear view mirror, I wanted a smart cap so badly. I know it kind of works with a smart cap but I’ve really been enjoying the digital mirror. Truck looks really good with the smart cap!
    Chomponthis[QUOTED] likes this.
  13. Jul 4, 2024 at 10:49 AM
    #4993
    tundrabobbob
    tundrabobbob New Member
    295/70/18 ko2 on agp pro rep wheels 18x9 +12.
    Stock suspension. A little poke but not too much. Some rubbing on the front mud guards which I will remove and pin the lining back as everyone does.
    Customer service at agp was very good btw.
    Yaboy, Helo, SilveradoSwap and 2 others like this.
  14. Jul 4, 2024 at 10:50 AM
    #4994
    tundrabobbob
  15. Jul 5, 2024 at 6:34 AM
    #4995
    Chomponthis
    Billings, MT
    Out of curiosity how much are the agp pro replicas? I ended up getting the OEM pro wheels on FB marketplace for an insanely good deal.
  16. Jul 5, 2024 at 7:49 AM
    #4996
    SilveradoSwap
    SilveradoSwap New Member
    2024 1794 Edition Tundra
    Love the wheel color choice.
    tundrabobbob likes this.
  17. Jul 5, 2024 at 12:25 PM
    #4997
    Foques
    Foques New Member
    gents, i'm reading and reading.. and I'm reading myself into a hole, I think.
    Stock suspension, 21' platinum with the variable suspension.. what tyre can I fit on a 18x9 +12 wheel? I don't reckon a new suspension is going to be in the cards for me for a minute.
  18. Jul 6, 2024 at 6:04 AM
    #4998
    Capt321
    Capt321 New Member
    2023 Silver Tundra Limited
    2.75” RC Level
    275/65R20 Pirelli AT+IMG_0065.png
    WickedBassn, Livin and jachal like this.
  19. Jul 6, 2024 at 6:21 PM
    #4999
    AZxp
    AZxp New Member
    '23 on 3.ohs and dirty sevens
    Icon 3.ohs with 37" cooper's on 17" rrw
    Yaboy, AND, Poolguy89 and 1 other person like this.
  20. Jul 6, 2024 at 8:11 PM
    #5000
    Poolguy89
    Poolguy89 New Member
    2024 Black Limited iForce Max
    Nice to see that 17” wheels will fit. I’ve been thinking about getting some 17s with a big meaty tire. Was going to ask if anyone was running 17s or knew they would fit on the truck.
    ARCOVT23 likes this.
  21. Jul 6, 2024 at 9:55 PM
    #5001
    terraj66
    terraj66 New Member
    Las vegas
    Works 18x9 +18 wrapped in 295 toyos
  22. Jul 6, 2024 at 11:12 PM
    #5002
    SM Tundra
    Cody
    I’m running 17s (method 314s +25 offset) with some toyo open country AT3s. 17s fit great but just be aware that when they are balancing they need to place the weights properly so they don’t rub on the calipers. But 17s fit and definitely look good. I’m running stock suspension currently with a 34” tire but might lift down the road and go to 37s. These trucks look real good lifted with 37s
  23. Jul 7, 2024 at 12:47 PM
    #5003
    AZxp
    AZxp New Member
    Quick wash today after alignment.
    20240707_124224.jpg 20240707_124103.jpg 20240707_124159.jpg 20240707_124242.jpg
  24. Jul 7, 2024 at 4:34 PM
    #5004
    Northern Toyota
    Tires and bilstein
    I’m going for another alignment tomorrow. Did you set your toe close to 0? Mine was within factory spec and I’m getting feathering on the outside edge of my wildpeaks
  25. Jul 7, 2024 at 4:57 PM
    #5005
    AZxp
    AZxp New Member
    .004 well see how it fares
  26. Jul 7, 2024 at 5:03 PM
    #5006
    gesekee19
    gesekee19 New Member
    Titan 7 ATK-1 wheels. 18x8.5 with +20 offset. Yokohama AT/XD 295-70-18.
  27. Jul 7, 2024 at 6:55 PM
    #5007
    Exec_TRD
    Exec_TRD New Member
    2024 Tundra Limited TRD Off Road
    Factory TRD OR wheels and new nitto recon grapplers 275/65/20. These are SL. Ride great, no more slop, no noticeable sound increase. The factory AT3Wa’s are neutered down to 9/32 new and are highway orientated. Pathetically weak tires, I got a flat 43 miles in and the screw barely pierced the tread, and it was leaking like a siv. I normally change tires and batteries immediately and glad I did. Added rekgen mud flaps also and gorhino steps
    txez, BlackNBlu and doublethebass like this.
  28. Jul 7, 2024 at 7:00 PM
    #5008
    Northern Toyota
    Tires and bilstein
    My tires are almost $2,000 to replace where I live and the feathering is starting to make the tires louder. It’s minimal but I’ve rotated them twice in less than 5,000 miles.
  29. Jul 7, 2024 at 8:25 PM
    #5009
    BlackNBlu
    Rich
    MN
    Looks great! No lift or level?
    Pretty sure you're size is 275/65/20, just a tick over 34" tall. That's the size and exact tire I'm going with. Not happy with my Mildpeaks either.
    (Doing the math a 275/75/20 comes out about 36-1/4".)
  30. Jul 7, 2024 at 8:28 PM
    #5010
    Exec_TRD
    Exec_TRD New Member
    Yep you’re right, typo I missed, fixed it.
    no lift or level, happy with the off road billsteins so I left it stock. There didn’t seem to be much of a rake if any that I noticed as I’ve put some miles on it. A step far above what came with my 4Runner TRD off road, those shocks were horrible, swapped with Fox and much improved, I’ll be leaving the tundra as is.
    Tundrastruck91 likes this.
