Poor little Tink Tink..
Discussion in '1st Gen Tundras (2000-2006)' started by RotaryRevo18, Jun 23, 2024.
  1. Jun 23, 2024 at 4:49 PM
    RotaryRevo18
    RotaryRevo18 [OP] New Member
    AJ
    2006 Teal Tundra SR5 DC
    Welp it happened to me as well now. I had not even had the truck a month and I experienced flex-plate failure.. Ugghhh. Atleast it wasn't my transmission like I had original thought.
  2. Jun 23, 2024 at 5:02 PM
    Yup, that is one of the warnings in the Megathread:
    • Strange rattle noises at back of engine, like marbles rolling around: Several people here and at other forums have found this issue where they describe the sound as loose marbles banging around. Then found their flex plate was cracked in multiple places. Ticking timebomb. Check it out.
    Sorry it happened to you. Hopefully when it grenaded, it didn’t screw you too bad.
  3. Jun 24, 2024 at 3:17 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    Any thoughts on how this happens? Were any bolts loose allowing deflection under the torque of the starter?
  4. Jun 24, 2024 at 6:26 AM
    Based on the pics in the thread I linked above, it looks like material failure to me. Not dissimilar to the material failure that causes the 2WD trucks to crack their transmission crossmember. This is similar to what I saw in pics from the three people nice enough to post pics.
  5. Jun 24, 2024 at 2:47 PM
    bfunke
    bfunke Tundra Curmudgeon
    Things that cause this:
    1. Mismating trans bellhousing to engine
    2. Crankshaft flange with excessive runout
    3. Unbalanced flex plate or torque converter.
    4. Loose torque converter bolts
    5. Material defect in flex plate
    6. Engine making excessive power for application - haha Tundra 4.7 yeah no!
    shifty` likes this.
