Alpine ILX-F511. Game Changer
Discussion in 'Audio & Video' started by running214, Mar 2, 2023.
  1. Jun 21, 2024 at 7:31 PM
    #1711
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    I've never had that issue once with mine.
  2. Jun 21, 2024 at 7:33 PM
    #1712
    RainMan_PNW
    Casey
    Clark County, WA
  3. Jun 21, 2024 at 7:35 PM
    #1713
    RainMan_PNW
    Casey
    Clark County, WA
    screens are measured diagonally corner to corner. It's the viewable diagonal measurement.
    TaquitoBandito likes this.
  4. Jun 21, 2024 at 7:40 PM
    #1714
    Azblue
    The Dirty T ( ^_^)_且
    Yep, if I recall correctly, I lowered it 1 notch from what it came like out of the box, or #2 of the 4 settings. And note to anybody just putting one in, as mentioned a few pages back, those little screws are set with way too many ugga=duggas and soft as fuck, they will strip the heads. I had to find replacements at Ace hardware and drill one out. You have been warned.
  5. Jun 21, 2024 at 7:47 PM
    #1715
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Right, that's why I was asking because the measurements on Crutchfield weren't specifying.
  6. Jun 21, 2024 at 9:05 PM
    #1716
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Pretty much the industry standard.
    All TVs and monitors are measured diagonally...:thumbsup:
  7. Jun 21, 2024 at 9:38 PM
    #1717
    1st Tun
    1st Tun New Member
    2019 Gray Tundra
    Anyone know if these are still available, will be stopping by local stores tomorrow.
    HulkSmurf14 likes this.
  8. Jun 21, 2024 at 9:41 PM
    #1718
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    They are still available - just no where near the price they were when this thread started. I think I did see some 9” screen Pioneer on sale a couple weeks ago though.
  9. Jun 21, 2024 at 9:44 PM
    #1719
    1st Tun
    1st Tun New Member
    2019 Gray Tundra
    Thanks, crazy deal for those that got in.
  10. Jun 22, 2024 at 6:54 AM
    #1720
    WFD473
    WFD473 Long Live The V8
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    Anyone know why my Trans temp is grayed out? Would love to have that feature for towing the camper.
  11. Jun 22, 2024 at 6:55 AM
    #1721
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    @Azblue just got done wrestling with that himself. Said it was a Maestro setting. Did you validate your PIDs?
  12. Jun 22, 2024 at 7:39 AM
    #1722
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Is your truck actually on and running? Do that, make sure your OBD setting is on or enabled on demand, and validate PIDs.
  13. Jun 22, 2024 at 9:14 AM
    #1723
    WFD473
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    Yes, the truck was on and running at the time. Could you explain how to validate the PID's? I didn't do the install. Thanks
  14. Jun 22, 2024 at 9:36 AM
    #1724
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I don't have this particular HU but I went to Car Features on my Pioneer then pressed the little cog icon (settings) and saw Validate PIDs
  15. Jun 22, 2024 at 9:37 AM
    #1725
    WFD473
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    I'll give it a shot. Thanks!
  16. Jun 22, 2024 at 9:47 AM
    #1726
    Azblue
    I forgot exactly how it's worded on the HU, but there is a selection to confirm or validate communication, takes a minute or 2 then with the truck running I was able to select the trans temp.
  17. Jun 22, 2024 at 10:33 AM
    #1727
    WFD473
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    That did the trick. You guys are the best!!
  18. Jun 22, 2024 at 10:34 AM
    #1728
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Glad it was an easy fix for ya.
  19. Jun 27, 2024 at 12:24 PM
    #1729
    fireheadman
    fireheadman Devil Dog - Semper Fi
    1794 Tundra (2018)
    I realize this has been asked once/twice before.... (I've been around a while, just not posted a lot)
    Just got my ILX-F511 installed and really wanting to put a brake bypass module in to toggle settings during drive mode.
    I've seen a few brands mentioned but haven't seen which is the best (imagine they all do the same thing)
    Looks like only 3 wires is all that is required right? (ground, remote, parking brake wire)
    I also am using the maestro rr unit.... which I wanted to ask for clarification on.
    Is the Green/yellow wire (brake sensor wire) from the HU to the RR clipped or taped into?
    ...If clipped, then the bypass module connects to green/yellow... which would leave the RR clipped side to be capped/taped?
    Lastly, if the RR was using this as an input, has anyone noticed any issues for lose of function?
  20. Jun 27, 2024 at 12:40 PM
    #1730
    2TunGet1
    2TunGet1 Tundra owner since 2000
    2020 Limited 4x4 CM QS / 2000 Limited 4x2 AC Black
    see post #8, it’s the first diagram.
    https://www.tundras.com/threads/the-great-hu-install-of-2023.129229/
  21. Jun 28, 2024 at 2:09 PM
    #1731
    fireheadman
    1794 Tundra (2018)
    Got another question about this head unit...
    I see the preamp voltage is rated at 4 volts. (RCAs measure between 1.9v - 2.5v at volume level 27, which is ~75% of the max 35)
    I am running a JL Audio 700/5v2 amp, which has a RCA input voltage selector switch
    Low - 2v
    High - 8v
    Currently I configured the setup to use the High (8v) setting and everything sounds clean, but it the volume is usually set around 20-24 (35 max) to really hear and feel the music.
    Curious what others are running their amps at if you have an input selector like this?
    From the Manual:
  22. Jun 28, 2024 at 2:13 PM
    #1732
    1st Tun
    1st Tun New Member
    2019 Gray Tundra
    Anyone pick up an extra head unit that might want to help out a fellow member, PM me. Thanks
  23. Jun 28, 2024 at 2:26 PM
    #1733
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    "High" is for speaker level inputs, as in if you were feeding the amp signal from the wiring that would normally go to the speakers from either an upstream amp or the head unit. If you're using RCA outputs from the HU, select "Low" on the input selector.
    bulldog93 and TaquitoBandito like this.
  24. Jun 28, 2024 at 5:09 PM
    #1734
    fireheadman
    1794 Tundra (2018)
    I do not disagree with what you said... however the section I highlighted is specific to this amp also mentions it can be used for preamp rcas with a higher voltage, which the ILX-F511 seems to have (4 volts).
    Just did not want to push a 2.5volt signal to an amp that is set to only receive up to 2v (max) which set to low. Would you consider 4 volts to be a "High signal"?
    however....
    I contacted Alpine and they pointed fingers to JL Audio.
    JL Audio commented and said either could be used, but preferred the HIGH setting.
    This forum is more "real world" to me and would assume a lot of the members watching/commenting on this thread own the F511 or family of head units.
    Just trying to get a consensus of what others are setup to use.
  25. Jun 28, 2024 at 5:14 PM
    #1735
    Do a live chat with Crutchfield and see what they say.
    bulldog93 likes this.
  26. Jun 28, 2024 at 7:23 PM
    #1736
    AZBoatHauler
    So.Arizona
    I’ve never heard RCAs referred to as anything other than “low level” inputs. All the way up to 5 volts. As @TRDFerguson pointed out - high level inputs refer to using speaker outputs from a HU.
    ToyoMafia, TaquitoBandito and Mater like this.
  27. Jul 1, 2024 at 10:35 AM
    #1737
    Triton19X2
    Triton19X2 New Member
    2021 Silver 1794 Crewmax 4X4
    Guys, I'm having trouble with the stock backup camera being intermittent. I found a youtube video about the F 511 needing a second ground for the reverse camera. I pinched a ground wire in the RCA connector and grounded it to a metal bar in the back of the stereo "pocket" in the dash and it seemed to work but now it is flickering and going black again. When it acts up it does it when putting the truck in reverse and when you use the camera button. I bought the unit through Trailgrid pro and have been working with them for several months on this. They are now saying they reached out to Alpine about it and Alpine says they have not heard of this issue:confused:. They are suggesting I call Alpine. Have any of you had this problem and found a solve for it?
  28. Jul 3, 2024 at 12:11 PM
    #1738
    fireheadman
    1794 Tundra (2018)
    onto this issue.... I'm also not seeing the transmission temp, have the X next to it.
    Have performed a soft reset on the maestro RR, clicked the ODB2 calibrate function and clicked the validate PIDS.
    Contacted trailgridpro where I purchased the unit from. They mentioned there has been several others experiencing this issue and there really isn't a good answer to why some tundras show it and others do not.
    Something else I want to try is next time my trailer is connected, going into the tundra vehicle settings on the dash cluster to select the trailer type, weight..etc and performing the ODB2 calibration and PID validation again to see if that changes anything?
    Otherwise, I'll check with iDatalink/Maestro support to see if they have any details.
    Aside from that, I am getting ready to hook up an external HDMI/USB extension to the rear console for the kids and install a e-brake bypass module.
    While I am doing that, I will take care of the speaker/amp/rca setup to switch the input level to LOW and recalibrate the input/output voltages and gains.
  29. Jul 3, 2024 at 4:57 PM
    #1739
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    @Azblue mentioned changing the settings in his Maestro to get it goin.
  30. Jul 3, 2024 at 5:21 PM
    #1740
    Azblue
    Every thing I did was done on the HU. There is a Maestro setting on the Alpine that I used, but I can't remember exactly what it was called. That being said, I'm pretty dumb and usually intoxicated and it was pretty obvious what to do, so shouldn't be that hard.
