2014 Tundra crewmax dying with no check engine light
Discussion in '2.5 Gen Tundras (2014-2021)' started by karlnator, Jun 22, 2024.
  1. Jun 22, 2024 at 5:02 AM
    karlnator
    karlnator [OP] New Member
    Kyle
    2014 tundra crew max
    I have a 2014 crew max with 180k miles on it. I drove to work yesterday no issue drove home and made one stop. Left there to head home and about 1 minute into my ride home my truck died. I put it in neutral and it fired right back up. Drove about 30 second and it did it again. Costed a little bit in neutral turned the key and it started back up. Did this a couple More times till I got to a car parts store. Checked the oil it was in the middle. Added some seafoam to the gas. Used code reader at the car part store but there was no check engine light. Seems when I let it sit for a little bit it runs a little longer opposed to when I’m driving. I left the car part store and it ran for another 1-2 minutes then died I coasted put it in neutral and started it back up. Continued to do this till I got home roughly 15 miles from the car part store. Looking for any ideas suggestions and direction. Lost because there is no dam check engine light.
  2. Jun 22, 2024 at 5:18 AM
    Leedaar
    Leedaar New Member
    2016 Tundra CM
    Tested the battery and alternator? Loose negative?
    Tundrastruck91 and BlueRibbon4x4 like this.
  3. Jun 22, 2024 at 5:20 AM
    karlnator
    Kyle
    Yes I tested it with my fluke multi meter. I held the leads on the battery when it was in park and idling. 12.9 volts and stayed there when it died.
    BlueRibbon4x4 likes this.
  4. Jun 22, 2024 at 5:58 AM
    Check your grounds
  5. Jun 22, 2024 at 6:06 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    So did you read for any Pending CELs - the CEL won't light up with Pending yet they can be a Clue.
  6. Jun 22, 2024 at 6:27 AM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    12.9 is kinda low at idle. But you can get that reading if you have a loose connection. I would check all connections then have the battery and alternator checked.
    Saltyhero13 likes this.
  7. Jun 22, 2024 at 6:41 AM
    karlnator
    Kyle
    I’m not sure about pending CEL but all he said was there were no codes and the light also wasn’t lit
  8. Jun 22, 2024 at 7:33 AM
    karlnator
    Kyle
    I disconnected the battery over night cleaned the termalls with a brush real good. Hooked it up this morning checked the voltage on the battery it was 12.5 started the truck it went to 14.1. Went for a ride like 4 miles came home checked the voltage it was around 13.5 let it sit and run in the drive way for 20-25 minutes and the voltage was 13.4. Do you think the alternator could be going bad? At what voltage does a truck shut off because the voltage is to low?
  9. Jun 22, 2024 at 7:39 AM
    Alternator sounds fine. Battery should be load tested at your LAPS. Check all the ground locations to make sure one of them isn't broken or corroded.
    ColoradoTJ likes this.
  10. Jun 22, 2024 at 8:29 AM
    karlnator
    Kyle
    Knabores do you know where I can find a diagram where to look for them all? Location wise
  11. Jun 22, 2024 at 8:40 AM
    FSM is a great resource. There’s also an EWD floating around here somewhere. Maybe in a sticky.
  12. Jun 22, 2024 at 8:45 AM
  13. Jun 22, 2024 at 8:52 AM
  14. Jun 22, 2024 at 11:24 AM
    AZBoatHauler
    So.Arizona
    Any mods done on the truck?
  15. Jun 22, 2024 at 12:30 PM
    ARMYGREEN
    ARMYGREEN New Member
    2014 CrewMax MGM
    Do you have an aftermarket intake? If so, make sure all of the connections are tight And none of the Rubber couplings came loose.
  16. Jun 23, 2024 at 3:46 AM
    karlnator
    Kyle
    No mods and no after market intake.
  17. Aug 18, 2024 at 7:07 PM
    Willie64
    Willie64 New Member
    Mark
    2018 Platinum crew cab
    Working on it....,.
    Sounds like you may have something floating around in the tank; when it gets near the pump it gets sucked on to the intake and cuts out the gas.
