  1. Jun 21, 2024 at 12:01 PM
    VR6T
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
    Pretty sure I seen height adjustable 4600s before. Not recently, but years ago. I could be misremembering tho honestly.
  2. Jun 21, 2024 at 12:03 PM
    5100s are the adjustable 4600s to hear Bilstein tell it. If you want stock height, 4600. If you want lift, 5100. Adding lift springs to 4600s sounds like a no-no to me, although some members have apparently done it.
  3. Jun 21, 2024 at 12:08 PM
    VR6T
    I just did a quick search and surf, and it seem 4600 are for OEM static ride height and are not recommend for any sort of lift.
    The ones I'm thinking of were black rubbers and yellow painted bodies and we're on a classic Chevy square body in the Norfolk naval base parking lot. So I was wrong. But they were 100% adjustable as that mother trucker was lifted like 4 or 5 inches. It was restored really nicely as well, orange on white cab paint and tan on brown interior. And it was twin manual shifters. 4 speed trans and a 4 mode transfer case 4wd. Oh and it had the classic Chevy white painted steelies.
    KNABORES[QUOTED] likes this.
  4. Jun 21, 2024 at 12:23 PM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    My truck came with 4600's from the factory??? Or some rendition of blue and yellow Bilsteins. So I'd assume you are correct.
  5. Jun 21, 2024 at 12:28 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    I installed 4600s in mine too. Had to leave something out so I could have enough threads on the center bolt to thread the nut on there. Don't remember what it was. Spacer level here. I is broke.
    BroHon, VR6T and Jack McCarthy like this.
  6. Jun 21, 2024 at 3:11 PM
    Hi06silver
    Hi06silver Fat. Thumbs.
    2006 DC 4x4 Waltrip
    Update on these first set on the picture for the third brake light. Those bulbs are trash! Can't say they lasted a year before flickering and diodes burning out. Tails are still working just fine
  7. Jun 21, 2024 at 4:04 PM
    artsr2002
    'Yonder
    Get the Sylvania ZEVOs if available in the bulb type and color you want and call it good. They have lifetime warranty. The super duper ultra big time brightest Chinesium bulbs may be brighter but you see how well they last.
    shifty` and FrenchToasty like this.
  8. Jun 21, 2024 at 4:26 PM
    Those factory "4600s" are an OEM version of the 4600, but are different than the off the shelf ones. Less robust.
    FishNinja[QUOTED] likes this.
  9. Jun 21, 2024 at 4:34 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    I had to use one of the old ones to find threads
  10. Jun 21, 2024 at 5:14 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    4100's? :D
  11. Jun 21, 2024 at 5:25 PM
    VR6T
    This is what it's all about boys, "shit box" trucks that are better and will out last anything made today
    Look at that turd lightly mudded up shining in the sun like a diamond, in the rough, albeit still a diamond.
  12. Jun 21, 2024 at 9:11 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Does this count as wrestling?
  13. Jun 21, 2024 at 9:54 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Yes
    des2mtn[QUOTED] likes this.
  14. Jun 21, 2024 at 10:20 PM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    Reused OE Rubber at about 247000 miles on third set of shocks and still in good shape.
  15. Jun 22, 2024 at 4:49 AM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    @shifty` I saw this in another thread and didn't want to derail.
    Regarding Valve cover gasket FIPG
    the 06 FSM shows
    While the 00-03 FSM shows
    Looks like "making the turn" up the cam timing gear case would be the improved way, and probably a better seal.
    bmf4069, shifty` and VR6T like this.
  16. Jun 22, 2024 at 7:46 AM
    Yup, that's how I did mine. I didn't want to say anything about how you did yours. But that section of the FSM actually seems to show smoothing out at the half-moons like I was saying you need to do.
    I looked it up after seeing how fucked/incorrect most YouTube videos I checked out prior to doing the work were.
  17. Jun 22, 2024 at 7:51 AM
    artsr2002
    'Yonder
    Yesterday, I put a longer eye bolt on my LSPV bracket. The eye bolt I used only has a portion of the bolt threaded and at the lowest spot, its about half an inch higher than the stock bolt was maxed out. This gives me about 2 more inches of adjustment. Feels a bit better so far.
    I also ordered those JDMCAR ac knobs now they are back in stock.
    bmf4069 and des2mtn like this.
  18. Jun 22, 2024 at 8:01 AM
    des2mtn
    SW
    Tonto cover
  19. Jun 22, 2024 at 8:10 AM
    artsr2002
    'Yonder
    Toyota could've made it so much simpler and went with the half moon universal stereo and ac knobs shaft that many many others use but no, they had to go an Toyota-ize the mounting shaft for those knobs. LOL
    bmf4069 likes this.
  20. Jun 22, 2024 at 8:18 AM
  21. Jun 22, 2024 at 8:29 AM
    VR6T
    Berchwood Casey Cold Blue. 3 to 5 coats should do you. And then a non reactive clear coat to protect it
    des2mtn and shifty`[QUOTED] like this.
  22. Jun 22, 2024 at 9:18 AM
    JakeJake
    2000 Tundra AC 4X4
    Yep. A hundred milesish on it now and I'm still dry. I'll have to start taking a look at the later manual for process updates.
    bmf4069 and shifty`[QUOTED] like this.
  23. Jun 22, 2024 at 10:29 AM
    I think as long as you spiderweb that right-angle, you could paint clown faces with the FIPG and it'd still work.
    When I got into my heads, there were remnants of both white and black FIPG in that corner, so whoever was in there last didn't even bother cleaning out what was there prior before reapplying the last time they were in there. It wouldn't surprise me one bit if the 2nd owner (he only had the truck maybe 8-10k miles) may've done it, and when he saw how much crust there was in the driver's head, he bailed and traded it in. Mine was arguably as-crusty as yours, but I'm sure your driver head wasn't quite as varnish-char'd as mine. But that dbl-FIPG stupidity led to my VCs leaking.
    JakeJake[QUOTED] likes this.
  24. Jun 22, 2024 at 3:45 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    I put a small piece of adhesive lined heat shrink around mine to keep them together.
    One had already cracked pretty good.
    des2mtn likes this.
  25. Jun 22, 2024 at 5:07 PM
    artsr2002
    'Yonder
    Every time I have to remove them for whatever reason one usually loses units small clip. One was cracked so I replaced it with some cheap Amazon replacements.
    The Black Mamba likes this.
  26. Jun 23, 2024 at 4:19 AM
    The Black Mamba
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Same. I have at least 3 spares in my garage spares box
    455h0le_dachshund likes this.
  27. Jun 23, 2024 at 7:22 AM
    2006 Tundra AC
    2006 Tundra AC Slowly upgrading my grandfather's old truck
    Andrew
    Cedar Park, Texas
    '06 desert sand 4.0 V6
    Alumas, Alcans, TuRD Pro wheels, 285/70/17 Falken
    I was working installing a new water pump, thermostat, fan clutch, and radiator yesterday and everything was going great until it was time for the new radiator. I dropped it in and realized the nipple for the reservoir had broke off. I unboxed it and looked it over when it showed up about a week ago but I was mostly looking for screwed up fins and I missed this. I won't be able to get a hold of anyone from Mishimoto until at least Monday so I'm stuck using dad's truck or mom's car until they can send me a new one.
    des2mtn likes this.
  28. Jun 23, 2024 at 7:51 AM
    bfunke
    bfunke Tundra Curmudgeon
    Dorman makes a nipple repair kit for about $20.
    shifty` likes this.
  29. Jun 23, 2024 at 8:15 AM
    2006 Tundra AC
    Andrew
    Cedar Park, Texas
    Just looked that up, pretty cool. I'll probably just have them send me a new one because I don't really want to spend $20 a brand new part. Thanks for the idea.
  30. Jun 23, 2024 at 8:42 AM
    Openbaffle
    Openbaffle New Member
