GEN 3 (2022+) Wheels and Tires Photo thread
Discussion in 'Wheels & Tires' started by Tsquare, Jan 16, 2022.
  1. Jun 19, 2024 at 10:59 AM
    #4951
    SilveradoSwap
    SilveradoSwap New Member
    2024 1794 Edition Tundra
    Yeah, i almost got -44 offset wheels. And at a 22x10 and a 12.5 tire, it was around 4.25” of difference, way too much imo.
  2. Jun 19, 2024 at 12:28 PM
    #4952
    Kbeens
    Kbeens New Member
    2024 Tundra SR5
    TRD lift
    Take it easy on me as I am new here lol. Anyone running 20x10s or 18x9s with a negative offset? Currently running the OEM 3inch TRD lift with stock 18s and 35 12.50s. It seems I want a little more poke then most guys here
  3. Jun 19, 2024 at 1:50 PM
    #4953
    SilveradoSwap
    Welcome to the forum, its a good question. Plenty of people here running similar setups. How much poke you looking for? Stock offset is 58, and tires should be 8” in width, should be similar on the TRD.
  4. Jun 19, 2024 at 2:14 PM
    #4954
    Kbeens
    Kbeens New Member
    2024 Tundra SR5
    TRD lift
    Looking to be in the 2.5in to 3inches of poke range. Planning to run the NYTOP fender flares as well. Just hoping to see some more pics of these setups as well as finding out what guys are trimming to make them run
  5. Jun 19, 2024 at 5:12 PM
    #4955
    SilveradoSwap
    I have a 12” tire on a 10” wide wheel at +20 offset and have plenty of clearance with 1.5” of poke, but that is running a 33”. I could go up in size and still be fine i am guessing.
  6. Jun 19, 2024 at 7:32 PM
    #4956
    Eurodriver
    Eurodriver New Member
    I want no poke on factory 18” TRD wheels, but want to go bigger. I have a 3” lift what size should I get?
  7. Jun 19, 2024 at 8:01 PM
    #4957
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    Are those 8.5 wide?
    How big is "bigger?" (I thought you weren't going 37's again?) 33? 35?
    295/70/18 = 34.26 diameter
    That's my personal 18" tire sweet spot if I decide to ditch the TRD 20's.
  8. Jun 20, 2024 at 7:43 AM
    #4958
    Kbeens
    Kbeens New Member
    2024 Tundra SR5
    TRD lift
    I have a 3inch lift on factory wheels with 35x12.50s and still tucked. No poke
    Bnewman077 likes this.
  9. Jun 20, 2024 at 6:09 PM
    #4959
    damsamuel
    damsamuel New Member
    Huntsville, AL
    2022 Tundra SR5 TRD Sport 4x4
    Getting these put on Monday.
    Fuel Flux 18x9 +20mm
    Yokohama Geolandar AT G015 295/70/r18
  10. Jun 20, 2024 at 6:10 PM
    #4960
    SilveradoSwap
    I like those, post up once mounted.
  11. Jun 21, 2024 at 6:40 AM
    #4961
    knewcomb
    knewcomb New Member
    This is exactly what I did. No regrets at all.
  12. Jun 23, 2024 at 4:18 AM
    #4962
    Tartar88
    Tartar88 New Member
    Steven
    24 trd pro
    Westtcot lift 37s
    Something smooth about 37s!!
    lavern23, COTundra23, akira and 7 others like this.
  13. Jun 23, 2024 at 2:17 PM
    #4963
    az 3rdGen
    az 3rdGen New Member
    Arizona
    2022 Black Tundra SR5
    I see you got the westcott lift on a trd pro.. what else did you need to do to fit 37s with the factory BBSs?
  14. Jun 23, 2024 at 2:31 PM
    #4964
    dadrocz
    dadrocz New Member
    Ny
    23’ TRD Pro. 18’Platinum
    Wow. And I thought my 35’s looked big.
    Nice!!
    Tartar88[QUOTED] likes this.
  15. Jun 24, 2024 at 8:50 PM
    #4965
    damsamuel
    Huntsville, AL
    Fabtech 1.5” leveling kit
    definitely rubs at full lock and little less than, gonna need to trim it up. I have the sport, which is lower to begin with, but feels/looks level to me. Very little poke.
    IMG_1841.jpg IMG_1839.jpg IMG_1834.jpg IMG_1827.jpg IMG_1828.jpg IMG_1829.jpg
  16. Jun 25, 2024 at 11:10 AM
    #4966
    tundrabobbob
    tundrabobbob New Member
    I have searched through dozens of pages on this thread and I'm getting mixed info.
    I have a stock 24 limited trd off road. I purchased the AGP pro rep wheels. Specs are 18x9 +12.
    My question is, what is the largest tire I can run without any rubbing or modification.
    I have seen people run 295 70 18 and I have seen people say that's too large for no level/lift.
    I would like to run a ko2 295 70 18. Can I do it with no rub? Will I only have to pin back the felt liner a bit and maybe take off that metal piece with 2 bolts behind there?
    Should I be safe and go with 285 70 18?
    The last thing I want is to have clearance issues when I'm offroad.
    Thanks everyone.
    Yaboy and damsamuel like this.
  17. Jun 25, 2024 at 12:30 PM
    #4967
    damsamuel
    Huntsville, AL
    I think you’ll have less trouble with your TRD Offroad than the TRD Sport. The sport has preload in the coils and the nose is lower than yours to start. Only speaking for the sport suspension, 295/70/r18 will require some trimming. It’s not unbearable but it’s noticeable.
    Big40 likes this.
  18. Jun 25, 2024 at 12:45 PM
    #4968
    tundrabobbob
    Thank you for the reply. I didn't know there was a difference between trd sport and trd offroad in relation to the front suspension. Mine is a 24 limited trim with the trd off road package but not the 3 inch trd lift to be clear. So I should be ok with 295 70 18 and a little bit of trimming?
  19. Jun 25, 2024 at 1:19 PM
    #4969
    Wood-Dro
    Wood-Dro New Member
    2023 Platinum. I have 295/70-18's. Icon +25. Mine do not rub on stock suspension.
  20. Jun 25, 2024 at 1:43 PM
    #4970
    tundrabobbob
    Thank you for the reply. How much does this setup poke out?
  21. Jun 25, 2024 at 1:49 PM
    #4971
    Wood-Dro
    Wood-Dro New Member
    Bryzzo and tundrabobbob[QUOTED] like this.
  22. Jun 25, 2024 at 1:52 PM
    #4972
    tundrabobbob
    Thank you again for the pics. I just pulled the trigger on 295 70 18 ko2's to go on my 18x9 +12 trd pro rep wheels. I've read ko2's run smaller than other tires so that info with your pics gives me hope that this will be a solid setup for a stock suspension truck. I'll post pics when they're mounted up tomorrow afternoon. Only thing I'm slightly worried about is too much poke with a +12 offset and 295's when compared to your set up of 295's with +25 but we shall see..
    damsamuel and Wood-Dro[QUOTED] like this.
  23. Jun 25, 2024 at 6:03 PM
    #4973
    Chomponthis
    Chomponthis New Member
    Billings, MT
    2023 Tundra Limited Cremax 4x4, TRD OR
    Does anyone know if the Falken Wildpeak A/T4W 35x11.5R18 paired with TRD Pro wheels will fit without rubbing? Per Falken's website they're 34.9 which is larger than 35x12.5R18 KO2's.
  24. Jun 25, 2024 at 6:13 PM
    #4974
    SilveradoSwap
    How is a 34.9” tire larger than a 35”?
  25. Jun 25, 2024 at 6:16 PM
    #4975
    drewpweinerMD
    drewpweinerMD MPG’s are for your moms Prius.
    Jeremy
    2024 Limited TRD OR
    RB20 Slims, BAK X4s, Fabtech Level, Cooper 35's
    The diameter of the ko2 is 34.5
  26. Jun 25, 2024 at 6:18 PM
    #4976
    drewpweinerMD
    Jeremy
    2024 Limited TRD OR
    yes, they will likely rub at stock height. I put 295’s on my pro and they rubbed slightly on the well liner at full lock.
  27. Jun 25, 2024 at 6:20 PM
    #4977
    SilveradoSwap
    I dont see KO2s in that size per the BF Goodrich website. Are you sure they make an 11.5” wide in a 35”?IMG_1804.jpg
  28. Jun 25, 2024 at 6:37 PM
    #4978
    Chomponthis
    Billings, MT
    Sorry about that I meant 35x12.5R18
  29. Jun 25, 2024 at 8:17 PM
    #4979
    BlackNBlu
    Rich
    MN
    The difference in offset is 25mm minus 12mm or 13mm, which equals just over 1/2". You will have that much more poke due to the rim. Hopefully your KO2's are a bit skinnier and you won't gain the full 1/2".
    This assumes @Wood-Dro ICONs are also 9" wide.
    Looking forward to seeing how yours looks with the AGP's!
  30. Jun 25, 2024 at 8:22 PM
    #4980
    donproline
    donproline New Member
    Donny
    2023 White Tundra TRD Pro
    Stock 2023 Tundra TRD Pro
    2023 Tundra TRD Pro with Toyo Open Country AT3 35x12.5R18 on stock rims. No lift or level kit.
    ytank1, SWFL23TRDOR, Siblue and 5 others like this.
