New Exhaust System
Discussion in 'Performance and Tuning' started by reywcms, Jan 27, 2024.
  1. Jun 19, 2024 at 9:00 PM
    #451
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Nice looking trout!
    ARES35[QUOTED] and Mdl like this.
  2. Jun 20, 2024 at 10:49 AM
    #452
    ARES35
    ARES35 New member for life
    Mile high
    Haha thanks man!
  3. Jun 20, 2024 at 12:37 PM
    #453
    bflooks
    bflooks New Member
    Metrowest MA
    Late to the party on this one, but if you are removing the entire driver's side pipe from manifold to cat back flange, you aren't doing that on your back without either a very tall jack/jack stands or a lift. I ended up having to cut mine at the joint by the cat and get it out in 2 pieces, with everything going out toward the front (and over the crossmember). I chose to keep it clean since I didn't know if I'd need to reinstall them. Passenger side is a breeze. Good luck and enjoy!
    ARES35, e30cabrio, Mdl and 2 others like this.
  4. Jun 20, 2024 at 1:05 PM
    #454
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Thanks! This is the kind of info I was looking for. I’m trying to keep the stock downpipes totally intact with no cutting. It sounds like I may be better off having this done for me at my usual shop if I want that to be the case. Pay a few hours labor and spare the busted knuckles and frustration.
    nobodyintexas, e30cabrio, Mdl and 2 others like this.
  5. Jun 20, 2024 at 2:39 PM
    #455
    bflooks
    bflooks New Member
    Metrowest MA
    Definitely! To drop a preemptive "twss" joke, 6-8 more inches would have been perfect.
    Mdl and Silver17[QUOTED] like this.
  6. Jun 20, 2024 at 7:58 PM
    #456
    ARES35
    Mile high
    Said F it tired of looking at the box. Old shit catted stocker vs SPD's
    PolishedTRD, Mdl, Silver17 and 4 others like this.
  7. Jun 21, 2024 at 4:05 PM
    #457
    ARES35
    Mile high
    DPs in was bitch because I stripped one exhaust mani bolt smh. This thing sounds gnarly ASF! And I'm running just the DD 10! Also notice mad amounts of oil smoke, DPs must have had a lot of oil in them for they're clearing out now.
  8. Jun 21, 2024 at 4:10 PM
    #458
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Was that smoke with the "break in procedure"?
    Mine go in in the AM (hopefully)
    ARES35[QUOTED] likes this.
  9. Jun 21, 2024 at 4:46 PM
    #459
    Silver17
    Eastern PA
    Any other differences you’ve noticed with these other than the sound? Think you’ll need much for tuning adjustments?
  10. Jun 21, 2024 at 5:43 PM
    #460
    ARES35
    Mile high
    The pipes had oil in them probably from the bending procedure. It burn pretty damn good had me scared for a second but went away after long idle and some driving around.
    e30cabrio[QUOTED] likes this.
  11. Jun 21, 2024 at 5:45 PM
    #461
    ARES35
    Mile high
    Logged data around and it seems to be running a little leaner on WOT. Not much since I was running the stock 2 cats but these bitches flow way more. I'll dig into the data once I get a chance but I was seeing 10.6-11 on the psb1
  12. Jun 21, 2024 at 5:53 PM
    #462
    reywcms
    reywcms [OP] New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Correct oil from the fab procedure and it should lean out a tad since it's flowing more.
    ARES35 likes this.
  13. Jun 21, 2024 at 6:38 PM
    #463
    ARES35
    Mile high
    Not bad overall but a bit off target when building boost off the start and a tad leaner up high. Granted only to 54% InjDC max I did not do a 4th gear wot log until I get to my dragstrip in Mexico tomorrow
  14. Jun 22, 2024 at 4:46 PM
    #464
    e30cabrio
    Cats are in! Moar powa! Sounds rowdy!
    I had never seen north of 9lbs over 90 degrees, it's 111!
    I have 1/4 tank, gassed it turning left, had the starvation & sounded like several M16s! lol
    Mdl, texasrho83, PolishedTRD and 5 others like this.
  15. Jun 22, 2024 at 5:03 PM
    #465
    reywcms
    Rey
    North Plains,Oregon
    Powwaaaa
    Mdl and e30cabrio[QUOTED] like this.
  16. Jun 23, 2024 at 8:31 AM
    #466
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Are you header-ed?
  17. Jun 23, 2024 at 8:31 AM
    #467
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    @reywcms do you know if SPD sells those flange gaskets separately?
  18. Jun 23, 2024 at 8:39 AM
    #468
    e30cabrio
    No, I had Crawford long tubes, between the hardship of installing them & the fact Keith @ DD said they won't give an appreciable power increase, I sold them.
  19. Jun 23, 2024 at 9:13 AM
    #469
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    The sound would've been interesting to hear...
    It's rowdy AF without being SC'ed. I'd kill to hear with all of that together
  20. Jun 23, 2024 at 9:24 AM
    #470
    e30cabrio
    It sounded great just on the DD cat back, better now. I'll work on a video
    reywcms[OP] and texasrho83 like this.
  21. Jun 23, 2024 at 9:34 AM
    #471
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Get a cold start video in the AM
    reywcms[OP] likes this.
  22. Jun 23, 2024 at 9:48 AM
    #472
    reywcms
    Rey
    North Plains,Oregon
    I believe so shoot them a call or email.
  23. Jun 23, 2024 at 9:52 AM
    #473
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Sent an email.
  24. Jun 23, 2024 at 11:33 AM
    #474
    Cruiserpilot
    Cruiserpilot New Member
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    I've got 2010 5.7 RCSB 4wd. Haven't touched it yet. I've noticed alot of these exhausts - SPD - seem to have
    room designed in for DC's. Who have exhausts decidedly shorter for the RCabs? I also just can't leave exhaust
    exiting under my truck so do any have single or double pipe but single side exits?
  25. Jun 25, 2024 at 12:25 PM
    #475
    BigAl
    BigAl New Member
    2014 SR5 Magnuson SC
    For those with Dp's, any CEL's? New bolts for connecting to the manifolds probably wouldn't hurt either. I might have to order some.
    Saltyhero13 likes this.
  26. Jun 25, 2024 at 12:51 PM
    #476
    reywcms
    Rey
    North Plains,Oregon
    No CEL's
  27. Jun 25, 2024 at 1:21 PM
    #477
    e30cabrio
    I'm not poking the bear......
    Qft
    Lol
    Also, I can't believe how much rowdier the tree is with these.
  28. Jun 26, 2024 at 4:03 AM
    #478
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    quick question...for those with this exhaust system and a S/C;
    dose is drone @ 62mph? or any other regular hwy speed?
    I spend most of my time @ 62mph.
    my TRD drones @ 1300 rpms, and I luckily don't live near that rpm range.
  29. Jun 26, 2024 at 6:04 AM
    #479
    reywcms
    Rey
    North Plains,Oregon
    Negative
  30. Jun 26, 2024 at 6:07 AM
    #480
    Ryuu
    Ryuu Hwat!?
    Oz
    SouthEast, TX
    2017 TRD PRO Barcelona Red
    a few
    @reywcms Any details on if they still plan to release the version with a resonator on the x-pipe? Assuming that’s the milder version?
