  1. Jun 18, 2024 at 10:59 AM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    Lightning
  2. Jun 18, 2024 at 11:00 AM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    :p I know but it was a loaded question with a lot of baggage.
    bmf4069[QUOTED] likes this.
  3. Jun 18, 2024 at 11:02 AM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Thundra :D
    Voss and The Black Mamba like this.
  4. Jun 18, 2024 at 11:04 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    With an ass like that, you know it was a fart.
    bmf4069 likes this.
  5. Jun 18, 2024 at 11:07 AM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    And its blue, official racing color of the French.
    The Ford probably had a hole in the hood after the burnout from the 5.4 launching a spark plug.
  6. Jun 18, 2024 at 11:29 AM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    There used to be a “pump and run” during the Portland Marathon years and years ago. You could sign up beforehand to enter a bench press challenge during the middle of the race. I would have given it a shot, but it takes me a LOT longer than 90 minutes to run 26.2 miles.
    There’s an older guy at the gym who i’m friends with. He used to be about a 2.30 marathon runner (back when he was much younger). His body type didn’t fit the distance runner norm at all. 6’ 3”, 175lbs. Mile pace for his marathons were about 5:45 minutes AND he could bench press 275lbs! That’s pretty much unheard of for a fast distance runner.
    daveeasa[QUOTED] likes this.
  7. Jun 18, 2024 at 1:01 PM
    inv3ctiv3
    inv3ctiv3 New Member
    Jim Bob
    255/85/16
  8. Jun 18, 2024 at 1:26 PM
    daveeasa
    Yeah, he would be the type to be in the club. I've done 305 in my 20's and 2:31 in my 30's so I'm pretty comparable to your gym pal, I'm just 5" shorter and maybe 5 lbs lighter at race weight and probably his PR beyotch unless he's embellishing and he really ran 2:33 or something. Get his info and have him reach out to me, if he can still go sub 3, maybe he can be a founding member of this unless he's too old to bench. Or maybe we can just do a category for lifetime BPM while I work on the one week version. But lifetime is just too easy I think.
    The pump and run sounds like something I would be into. Looks like there are still a few lingering events of that genre:
    https://www.arnoldsports.com/sports-and-events/dance-and-fitness/5k-pump-and-run/
  9. Jun 18, 2024 at 1:38 PM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    Running smooth with zero leaks.
    Cam seals
    Crank seal
    Timing belt-tensioner-tensioner pulley-idler pulley
    Water pump
    Thermostat
    Front water crossover and gaskets
    Radiator
    A/C Compressor
    A/C Condensor
    Hayes 678 Trans cooler
    Valve cover gaskets
    Throttle body cleaned and new gasket
    There's probably somethings I forgot.
    I still need to fab a third mount for the trans cooler, extend some horn wiring for their slightly different location, and figure out my blend door problem as the defrost vents are always getting air. I'll re-torque the valve covers after a few heat cycles.
    Hayes 678
    https://www.tundras.com/threads/upgraded-trans-cooler.48516/
    Don't forget this when doing valve cover gaskets:
    I did the first time. It makes sense with the sharp corner of the gasket there, and the added velocity of oil slinging off the timing gears.
  10. Jun 18, 2024 at 1:43 PM
    Fuck yeah dude! I'll be ready for mine when the heat chills the fuck out.
  11. Jun 18, 2024 at 1:55 PM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    Sounded like black
  12. Jun 18, 2024 at 3:06 PM
    Weird, it doesn't mention doing the half moons in that. FSM showed that for mine, removal, cleanup, and how to install/smooth. I swore it did at least.
    I believe the ones I picked up off someone on here came with 650# in the box. I'm running 700# on my AC/4WD in the Toytec coilovers, w/E-rated tires and it's pretty painful on pavement.
  13. Jun 18, 2024 at 4:05 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    :D Just finished a 10 minute talk with her about it (It was years before we met) and she had a crazy twinkle in her eyeso_O. Yep it was SC.
    She isn't hard/abusive on cars, but it apparently ate up 2 transmissions :eek2::rofl:
    455h0le_dachshund likes this.
  14. Jun 18, 2024 at 5:40 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    FTFY.
  15. Jun 18, 2024 at 5:58 PM
    Does that mean you have a big rear end?
  16. Jun 18, 2024 at 6:01 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  17. Jun 18, 2024 at 6:11 PM
    It’s made some people instafamous!
    @AZBoatHauler
  18. Jun 18, 2024 at 6:23 PM
    AZBoatHauler
    So.Arizona
  19. Jun 18, 2024 at 6:27 PM
    AZBoatHauler
    So.Arizona
    First gen appreciation post - last week I spent around $40 and a couple hours putting a always on 12v plug in my bed of my truck to run a fridge - just noticed today the 12v in the back of the Sequoia stays on all the time from the factory.
    I hate new stuff.
    Voss, des2mtn, Tundra2 and 3 others like this.
  20. Jun 18, 2024 at 6:36 PM
    Even with out the key in or not on? That’s fancy! Ancient shitboxes for the win!
    Tundra2, bmf4069, FirstGenVol and 3 others like this.
  21. Jun 18, 2024 at 6:44 PM
    AZBoatHauler
    So.Arizona
    Yes, yes, and yes!
  22. Jun 18, 2024 at 7:21 PM
    TXTundraGuy23
    Dallas
    2004 DC 4.7L 4WD
    Yesterday and today:
    Cleaned off the Colorado dirt from the road trip and changed the oil. I forgot I had actually put the oil filter on with one of those stupid wrenches so I couldn’t get it off by hand. So this filter’s gonna have to go 10k miles instead of just 5k. Also noticed the crossmember under the skid plate is a little oily. Gonna pretend I didn’t see that. And I joined club where you torque down the skid plate with a cordless and it grabs and swings the battery end around and whacks you in the lip. Just blood, no stitches though.
  23. Jun 18, 2024 at 8:54 PM
    Hutcheson
    Hutcheson New Member
    Caleb
    2004 DC Limited
    Feels good to fire out my first post. Been tackling a frame restoration job on my 00’ Access cab, mid-frame is the only area that’s concerning. Have auto-rust mid frame sections en route and I’ll get some new stiffeners made up. IMG_9306.jpg
  24. Jun 18, 2024 at 9:01 PM
    Two tone!
  25. Jun 18, 2024 at 9:04 PM
    Be sure to post the mid-frame sections when they’re done. I’m really curious how they look.
  26. Jun 18, 2024 at 9:08 PM
    Hutcheson
    Caleb
    2004 DC Limited
    You betcha!
  27. Jun 18, 2024 at 9:10 PM
    Hutcheson
    Caleb
    2004 DC Limited
    Absolutely, once finished I’ll probably make a thread going over the full process.
  28. Jun 18, 2024 at 9:12 PM
    Two tone best tone.
    Weejub, Voss, JakeJake and 5 others like this.
  29. Jun 18, 2024 at 9:19 PM
    Hutcheson
    Caleb
    2004 DC Limited
    Very clean build Hoping mine will get there one day
  30. Jun 18, 2024 at 10:36 PM
    ToyotaDude
    ToyotaDude Member
    That POR15?
