OFFICIAL: Oil Analysis Report Thread ONLY
Discussion in '3rd Gen Tundras (2022+)' started by eddiefromcali, Jun 13, 2024.
  1. Jun 14, 2024 at 3:49 PM
    Sunstealer
    Sunstealer New Member
    2024 Platinum TRD HV Celestial Silver
  2. Jun 14, 2024 at 3:56 PM
    VCheng
    VCheng New Member
    Upstate NY
    Factory installed self-destruct device :D
    Here:
    https://www.blackstone-labs.com/tests/standard-analysis/
    As a novice myself, I just ordered their Quick Extract pump and a six pack of sample kits.
    Maine TRD PRO and raylo like this.
  3. Jun 14, 2024 at 4:53 PM
    jctmundra
    jctmundra New Member
    Northern VT
    '23 1794 Hybrid Stunning Mesquite/Cream
  4. Jun 14, 2024 at 5:40 PM
    ARB1977
    ARB1977 New Member
    Anthony
    DFW
    24 Tundra CM SR5 4x4 CSM build date 05/24
    Y’all rock. What oil are y’all running?
  5. Jun 14, 2024 at 5:50 PM
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    Dealer's choice
  6. Jun 14, 2024 at 5:51 PM
    eddiefromcali
    eddiefromcali [OP] New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    This isn't an oil discussion thread.
  7. Jun 14, 2024 at 5:58 PM
    ARB1977
    ARB1977 New Member
    Anthony
    DFW
    Certain oils can work better than others.
  8. Jun 14, 2024 at 8:46 PM
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    Oil analysis only please. Oil discussion has occurred at a rather lengthy discussion…
    Terndrerrr, DFS, 4genRunner and 3 others like this.
  9. Jun 14, 2024 at 11:55 PM
    PNW Tundra Mike
    Southern Cal
    MX4 Tonneau, Talon's Trans/Cat Shield
    Note on sampling and Blackstone form.
    - Be sure to sample hot oil that’s been driven on for 10-15 mins. to allow any fuel residual/vapor to evaporate from the oil. (ok to let it cool a bit after driving for safety). Otherwise you can easily get a higher than normal fuel contamination percentage and a lower flashpoint temperature.
    - On your Blackstone form, “Make Up Oil Added” is how much oil, if any, you had to add between oil changes to keep the level up. (not how much oil you used for your oil change)
    - Personally, it’s very easy to fill the sample bottle off the draining oil stream when it’s about 1/2 way finished. Not messy at all. I’d never bother with trying to pump a sample from the dipstick tube. That tubing would be messy and who knows where in the pan that sample is coming from.
  10. Jun 15, 2024 at 7:42 AM
    raylo
    raylo not so new member
    Frederick, MD
    DashCam, amp & sub, DIY rear seat delete, cat shield
    I got a pump off Amazon and took a sample and sent it off. Trying to get ahead of the big brown tidal wave of 0w-20 that this thread is sending to Blackstone. LOL.
  11. Jun 15, 2024 at 7:46 AM
    BoulderGT3
    BoulderGT3 New Member
    Glen
    2023 1794 4X4 BP/Saddle ADV Steps
    You're making a joke but they are going to have a really good sample universe.
    4genRunner, 303Gen3 and raylo[QUOTED] like this.
  12. Jun 15, 2024 at 7:54 AM
    raylo
    Frederick, MD
    But if you want intermediate samples between changes, you need a pump... or perhaps a Fumoto. But the pump makes this dead easy and clean and if you lay the tubing up against the dipstick and cut it at the 1-quart low line you won't be anywhere near the pan and any sludge there.
  13. Jun 15, 2024 at 7:56 AM
    BoulderGT3
    Glen
    And this is a person that's done this before. Solid advice.
  14. Jun 15, 2024 at 9:27 AM
    raylo
    Frederick, MD
    Indeed. I am not sure of all the ins and outs of who "owns" this data, but it would behoove Toyota to try to get a hold of it if they can. May not be definitive, but it should help their engineering analyses. And as an owner I'd be fine with them having mine.
  15. Jun 15, 2024 at 9:43 AM
    stevesgraytundra
    stevesgraytundra New Member
    Stephen
    2021 MGM SR5 CM 4x4
    TGMO is very high on dimer moly. Lesser base oils and higher volatility than many other off the shelf oils.
    ARB1977 likes this.
  16. Jun 16, 2024 at 8:21 AM
    CactusTundra
    CactusTundra New Member
    FU
    There was some discussion that Toyota went to the europeans method of putting more moly into their Toy OEM oil partly because of the B58 BMW engine in the supras. In fact I use liquid moly oil in my Supra. Never even used the free dealership oil changes. Also even the American engine oil manufacturers have warmed up to moly in their oils in the past 15-20 years. Redline and other high end oil folks have been using it for years.
    Blackstone has had my first Tundra oil for a week....definitely backed up!
    dJunior and raylo like this.
  17. Jun 16, 2024 at 8:52 AM
    TundraTT
    TundraTT Full Send
    23 Taco Trail 97 FZJ80 68 Goat
    Not a lot of samples posted… did everyone bounce?
  18. Jun 16, 2024 at 8:56 AM
    raylo
    Frederick, MD
    This effort just started. My sample is in the mail as will be a bunch more soon. Not sure how fast they will turn them around.
    Jettster likes this.
  19. Jun 16, 2024 at 9:29 AM
    Dpoll995
    Dpoll995 New Member
    Houston TX
    2024 Tundra Limited
    Took mine like 2.5 weeks or so to get my report
  20. Jun 16, 2024 at 10:17 AM
    #50
    TundraTT
    TundraTT Full Send
    I’m with ya but im sure owners had samples ran pre-recall. I remember several posts from blackstone last year but can’t find them
    raylo[QUOTED] likes this.
  21. Jun 16, 2024 at 10:50 AM
    #51
    raylo
    Frederick, MD
    There are always a few folks who get theirs analyzed. But I didn't bother, because it is a Toyota and thought that the analyses would just be a waste of $... LOL. So, this issue got me to find my spare Blackstone containers and do one, and I suspect there are a bunch of newbies sampling, too.
    dJunior and TundraTT[QUOTED] like this.
  22. Jun 16, 2024 at 3:29 PM
    #52
    Slimwood Shady
    Slimwood Shady New Member
    Linwood
    San Antonio, TX
    ‘23 TRD Pro, 996 Turbo
  23. Jun 16, 2024 at 4:14 PM
    #53
    machd08
    machd08 New Member
    CLARENCE
    Sumter, South Carolina
    2025 Land Cruiser/Land Cruiser
    Toyota is using Mobil 1
  24. Jun 16, 2024 at 5:46 PM
    #54
    PNW Tundra Mike
    Southern Cal
    3 weeks seems average. Aircraft seem to get priority (my buddy get his in a week) which makes sense as they need it for re-certification.
    dJunior likes this.
  25. Jun 16, 2024 at 5:50 PM
    #55
    PNW Tundra Mike
    Southern Cal
    TundraTT[QUOTED] likes this.
  26. Jun 16, 2024 at 6:14 PM
    #56
    TundraTT
    TundraTT Full Send
  27. Jun 16, 2024 at 8:17 PM
    #57
    E45370
    E45370 New Member
    Erick
    2023 Tundra Limited CrewMax
    Limited with 8,000 miles. M1 0W-30 (GF-6A)oil used, changed the sparkly oil out at 3,000.
    stevesgraytundra likes this.
  28. Jun 17, 2024 at 11:47 PM
    #58
    PNW Tundra Mike
    Southern Cal
    Thx for sharing this. Q? Did you mention to them the sparkly oil at 3K?
  29. Jun 18, 2024 at 11:09 AM
    #59
    machd08
    machd08 New Member
    CLARENCE
    Waiting for my report to come back from Speed Diagnostix. Did it 500 miles, opened the filter and looked at the filter pleats, these were the few areas with debris. Will post results when I get it back.
    hagrid and TundraTT like this.
  30. Jun 18, 2024 at 12:40 PM
    #60
    machd08
    machd08 New Member
    CLARENCE
    Yes at 500 miles. At least the filter got it, not worried, have lifetime power train warranty, comes with the vehicle, South East Toyota/Dealership warranty.
