2005-2006 tundra TRD lift 3" or 4" suspension
Discussion in '1st Gen Tundras (2000-2006)' started by Jokeywest1128, Jun 6, 2024.
  1. Jun 6, 2024 at 8:52 AM
    Jokeywest1128
    Jokeywest1128 [OP] New Member
    2005 tundra 4 door
    Led headlights. Lasfit switchback fog lights
    So I have a 2005 toyota tundra TRD RWD. And I am looking to get new suspension for it. Not to expensive but not pricey either. I have currently just spacers on it with rear leaf spring 2.5" took the mud flaps off. Currently running 285/70/17 tire size. But I want a suspension that is decent that will get me 3" - 4" of lift. What are my best bets. Don't want it to soft nor to stiff also
  2. Jun 6, 2024 at 9:07 AM
    ATBAV8
    ATBAV8 Mr. Bentley-He builds fast trucks.~Ettore Bugatti
    Tempe, AZ
    Bilstein 5100s with OME 2884 springs, Firestone RideRite airbags.
    I think this means the same thing...What's your budget? I think you'll get a more accurate response if you disclose what you're actually willing to spend. I honestly don't think you're going to get 3"-4" lift on a tight budget. Have you read this?>>https://www.tundras.com/threads/so-you-wanna-buy-just-bought-a-1st-gen-tundra-eh.115928/
    Specifically the suspension section? If not, do so.
    shifty` likes this.
  3. Jun 6, 2024 at 1:59 PM
    Yeah, if you go more than 3", to do it properly without ultimately doing thousands of dollars in damage, you're not going to get off "not expensive, not cheap". Once you start lifting that high, you've got to replace a lot of other things. There are shitty companies out there that advertise kits to do it, like Rough Country, but it's all garbage and I'll never forget the one dude who showed up here after installing their stuff, with bent knuckles and all kinds of other fun stuff.
    The thread @ATBAV8 linked, check the "Wheels/tires/suspension" section, that thread is a community collab, not my personal work/opinion. It'll tell you most of what you need to know and be aware of. If you're looking for a truck to lift 3-4", I feel like you picked the wrong truck. Unless you're throwing on a 3" kit, then bodylifting. Next move from there is 5" or 6" lift kit that requires irreversible cutting.
    ATBAV8 likes this.
  4. Jun 6, 2024 at 2:54 PM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    be more specific. My truck has only been lifted 2.5" but overall I got about a 6" jump in height due to my 285/75's.
    are you just trying to clear tires? Off-roading? Daily driver? are you just trying to find some decent suspension to match the dog water spacers you have right now?
    ATBAV8 likes this.
  5. Jun 10, 2024 at 8:40 AM
    Jokeywest1128
    2005 tundra 4 door
    Hi guys thank you for the responses. So I already have tires 285/70/17. With just an eBay spacer kit 2.5" . I only do light off road when I go camping or dirt bike with my buddies and shooting. But want a decent lift also. Looking for a solid 3" but not a stiff suspension nor a bouncy suspension. Something decent in the price range of $1,000 & 1,300. Not trying to lift it more then 3" if i have to modify more stuff and cut things. Hope this helps you guys guide me in the right direction thank you all again
  6. Jun 10, 2024 at 8:47 AM
    FishNinja
    Lee
    06DC2wd
    Bilstein 4600's on 2885's will basically give you what you're looking for. 4600's are softer shocks and will ride more OEM. While 5100's run slightly stiffer for better overall handling.
    I have a 2WD DC as well and the 2885's on 5100's yielded almost exactly 2.5" of lift
    and Hotshot Off-road can definitely get you that for the $ you're looking for. PM @memario1214 he works there
  7. Jun 10, 2024 at 8:49 AM
    ATBAV8
    Tempe, AZ
    Get rid of that junk.
    Use this. Solid.
  8. Jun 11, 2024 at 7:57 AM
    Jokeywest1128
    2005 tundra 4 door
    That's why i am looking around for new suspension. Anyone know anything about Eibach suspension or old man emu suspension. I really want to go for a 3" lift.
  9. Jun 11, 2024 at 8:11 AM
    FishNinja
    Lee
    06DC2wd
    2wd or 4wd?
  10. Jun 11, 2024 at 8:17 AM
    2wd
  11. Jun 11, 2024 at 8:22 AM
    FishNinja
    Lee
    06DC2wd
    Coilovers then.
  12. Jun 11, 2024 at 8:26 AM
    I concur.
  13. Jun 11, 2024 at 11:47 AM
    I doubt you're actually getting a full 2.5" lift out of the puck/spacer. But realistically speaking, even if you were, grab a ruler. Mark off half an inch. It's basically two lines of text in a reply on this forum on a regular LCD screen. Look at it carefully and think about it.
    Basically, the last line I wrote and this line combined. Is that half-inch really doing something extra or special for you? Do you really think someone standing 20ft away is going to be, like, **GASP**! OMG I CANNOT BELIEVE HE LIFTED 2.5" AND NOT 3.0"!!!
    No. They won't. Don't get hung up on half an inch, suspension isn't a dick measuring contest. That's basically not even the thickness of a small pinky finger. If you don't have a solid reason to do the extra half-inch, just go with what everyone else has found works extremely well, with good handling. i.e. 5100 w/2885 on a double cab. We have enough unique people floating around, the world won't miss having another snowflake who just had to be different :rofl:
    EDIT: I just took a digital caliper to my pinky finger for fun. It's 15/32", just shy of half an inch, at the skinniest part. Really puts things into perspective, to me at least.
    FishNinja and ATBAV8 like this.
  14. Jun 11, 2024 at 12:37 PM
    Jokeywest1128
    2005 tundra 4 door
    Its a 2wd.
  15. Jun 11, 2024 at 12:40 PM
    Jokeywest1128
    2005 tundra 4 door
    Hahahaha lol thanx. I get what you mean. Thank you guys for all the info
  16. Jun 11, 2024 at 12:46 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
  17. Jun 11, 2024 at 12:53 PM
    FishNinja
    Lee
    06DC2wd
    5100's and 2885's if you wanna go the route that requires the least amount of $$$ for quality.
    If you decide you wanna big dick it (like yours truely) get some 285/75/17's or 305/70/17's that's gonna be somewhere in the neighborhood of 6-8" of total lift.
    I got 285/75/17's, I'm 5' 11" and I gotta do a little toe hop to get into my seat.
    you just gotta remember our fender wells aren't really meant for THAT large a tire. So you'll be cutting and using a sledge hammer 100% and probably still rub. You'll also need new UCA's and maybe even spacers or a more aggressively offset wheel. Then you'll have to determine what needs to be cut. You'll also wind up having to pull out the fender liner so that leaves your intake having to be re-routed in order to avoid water getting sucked in.
    Weeeeeeeeee:rofl:
  18. Jun 11, 2024 at 1:25 PM
    You bring up a good point.
    2.5" lift with 2" taller tire is nearly 5" more lift. That's basically where I'm at right now. And the kids gotta put forth some effort to get in the truck now.
    Jokeywest1128[OP] likes this.
  19. Jun 11, 2024 at 2:51 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    3.5" or almost 4" taller (half the diameter of the tire is on the top).
  20. Jun 11, 2024 at 2:57 PM
    By math yes, all I can say is my running board sits ballpark 4.4" higher than pre-lift. Unless I measure as badly on vehicles as I do with wood.
  21. Jun 11, 2024 at 3:37 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    sounds like something someone with tiny suspension would say.
  22. Jun 11, 2024 at 3:39 PM
    That defies logic. The guy with the tiny one would be doing everything he could to get that extra half inch, my friend.
    FishNinja and Mr.bee[QUOTED] like this.
  23. Jun 11, 2024 at 5:24 PM
    FishNinja
    Lee
    06DC2wd
    holy fuck. I lol'd way too goddamn hard at this.
    whodatschrome likes this.
  24. Jun 11, 2024 at 5:28 PM
    FishNinja
    Lee
    06DC2wd
    Straight up 6" gain on 5100/2885 and 285/75/17
    it's maybe settled a bit. So probably more around the 5.5"-5.75" now. But it was a noticeable jump. Nobody under 6' has an easy time getting in my truck.
    Tlar25 and Jokeywest1128[OP] like this.
  25. Jun 11, 2024 at 5:46 PM
    I’m a little over 6’ tall and typically have to use the step to get in the truck. I typically do that because even laterally, I’m squashing the side bolster in the seat lower sliding up and in.
  26. Jun 12, 2024 at 6:38 AM
    FishNinja
    Lee
    06DC2wd
  27. Jun 12, 2024 at 10:37 AM
    Pretty much. We just got back from a long hike, my ass is enjoying the A/C currently. I'll snap a pic when I head back downstairs in a bit.
  28. Jun 13, 2024 at 6:37 PM
    As promised, @OhFishyWarrior
    Mind you seats were already ripped/worn when I got the truck here. But the curved lines to the lower holster are from me sliding in and out. Seat belt is hiding a full-on rip. I need to recover the front driver. Front passenger is near-mint, same as the rears
    bmf4069 and des2mtn like this.
