OFFICIAL: MY22+ Toyota Tundra - Throttle Lag/Hesitation From Stop Issue(s) - T-SB-0111-22
Discussion in '3rd Gen Tundras (2022+)' started by southdunes, Apr 18, 2022.
  1. May 21, 2024 at 2:01 PM
    #631
    CO_Native
    CO_Native New Member
    Englewood, CO
    2024 Limited CM Silver/Nightshade
    Interesting you mention this, I did a quick search on the forums and it seems I'm not crazy. I bought my 24 about 2 weeks ago (granted, it only has about 200 miles on it now) and noticed it's very inconsistent. Sometimes like you said, it'll snap your head back and it's hard to regulate from a stop with very bumpy roads for a smooth take-off, while others (usually rolling stops) I press the throttle and get nothing for a second. Like it's between 1st/2nd gear & can't decide? Almost feels like my old Jeep when the torque converter was going out, though I can't imagine that's the case with a new truck.
    Is it just that it hasn't finished "learning" (having only 200 miles) or something else? I guess time will tell, but I was really thinking I was crazy noticing the inconsistencies.
    Spartanfam[QUOTED] likes this.
  2. May 21, 2024 at 2:06 PM
    #632
    Coronerrpm
    Coronerrpm New Member
    Bob
    22 tundra red sport
    Non yet
    Had dealer do the flash and no more lag!
    CrayCray and CO_Native like this.
  3. May 21, 2024 at 2:17 PM
    #633
    Breathing Borla
    AZ
    ya , Im still going through the re-learn, getting a few rough shifts, etc, I just haven't been able to drive much yet.
    need to go out and letr rip, HA :burnrubber:
    ryanwgregg[QUOTED] likes this.
  4. May 21, 2024 at 2:31 PM
    #634
    Breathing Borla
    AZ
    ya, they tweaked things I think as well from what I can tell so far, the lag is all but gone for now as others have experienced
    well see as we get some miles
  5. May 21, 2024 at 3:27 PM
    #635
    sandiegosteve
    sandiegosteve New Member
    San Diego
    24 Limited TDR Lunar Rock
    I asked dealer to look at it during my last service. They said since it is worse cold, they can only look if I leave it overnight. They said they couldn't even check software versions.
    I got it back, and it seemed better for a few days. Now it is coming back. So maybe there was a battery disconnect that flashed the TCM memory. No idea. Something changed and it is evolving for sure, so there may be some adaptation going on.
    ryanwgregg likes this.
  6. May 21, 2024 at 3:30 PM
    #636
    rlc177
    rlc177 Data Logger
    Northeast PA
    I'm pretty confident that the issue isn't completely solved yet, it does seem like once and I while I'll get some major delay, but nothing I can replicate right now. The only times its happened its been a cooler mornings and right in the first few minutes of a drive cycle.
    Kap1, kirkb and ryanwgregg like this.
  7. May 21, 2024 at 6:25 PM
    #637
    ahaug
    ahaug New Member
    Andrew
    2022 Tundra Limited
    After the update, I found the street in town with the most stop signs, like 1 every block, and tried "training" in my transmission. Initially it seemed to help, but if I don't keep doing it, then it goes right back to its old self. I would say the last update lowered the speed where it downshifts from 2 to 1 coming to a stop but I still naturally mastered finding this point during a rolling stop. It seems like it never fails to delay if there is a car coming and I need it to get up and move. Manually shifting it, and forcing it down to first still seems better, except then I forget to upshift as I drive.
    ryanwgregg and rlc177 like this.
  8. May 22, 2024 at 5:55 AM
    #638
    rlc177
    rlc177 Data Logger
    Northeast PA
    2 of the 11 Logged complaints for 2024 at NHSTA seem to be for this issue. Probably a good idea to take a few minutes to log in over there and log this issue.
  9. May 22, 2024 at 3:47 PM
    #639
    TundraDan723
    TundraDan723 Not as new as I used to be...
    2023 Celestial Silver Tundra 1794 TRD CM
    I took my truck in last week for the second time regarding the “lag” issue, which he documented as a “driveability issue”. Below is the transcript from the voicemail he left me when calling to come pick up my vehicle. Does anyone know what “parts” he may be referring to?
    "Hello this is Gary calling from Toyota just wanna let you know we got your vehicle complete and ready for pick up unable to duplicate your compass issue today but there's actually a technical service Bulletin came out about your drivability issue and we got parts ordered for that once parts come in we will need your vehicle for two days technicians to find a day we could drop it off with us one morning and we get it back to the following afternoon to do this to Bulletin and we'll go from there so otherwise your vehicles to complete and ready for pick up we are here till six hopefully we'll see you before then and then when parts come in will call and reschedule get you back in for that drivability issue thanks and have a good day..."
  10. May 22, 2024 at 3:58 PM
    #640
    rlc177
    rlc177 Data Logger
    Northeast PA
    Ask them for the TSB number then maybe we can figure out something.
  11. May 22, 2024 at 8:28 PM
    #641
    Kap1
    Kap1 New Member
    San Francisco, CA
    Just some bs reason for dealer to do more work and charge Toyota Corp more for unnecessary work
  12. May 23, 2024 at 11:25 AM
    #642
    TundraDan723
    I’ll try to contact them and ask. Frankly, I don’t have high confidence in this dealership, but it’s the closest one to my house. The others are several hours away.
  13. May 24, 2024 at 4:02 AM
    #643
    rlc177
    rlc177 Data Logger
    Northeast PA
    I have a hunch they are preforming an older TSB that relates to bank2 running lean and due to a fuel Rail Pipe issue. "Poor Acceleration and/or MIL ON With DTC(s) P017400, P117B00, and/or P043000"
    The TSB is really mushy about what poor acceleration is and the conditions where they code would not be set.
    Black widow TRD likes this.
  14. May 24, 2024 at 12:06 PM
    #644
    TundraDan723
    Was this TSB helpful in anyway with the problem, or were they just throwing parts at it?
  15. May 31, 2024 at 6:12 AM
    #645
    zcardoza1
    zcardoza1 New Member
    Zack
    2022 Tundra Ltd.
    Yesterday’s TSB, related?
  16. May 31, 2024 at 10:00 AM
    #646
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    I had the fuel rail TSB performed a month or two ago and it didn't help with throttle lag. Had the lag TSB performed on Saturday and it got rid of the issue completely.
  17. May 31, 2024 at 1:39 PM
    #647
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    What TSB is that? I’ve had a code once for bank 2.
  18. May 31, 2024 at 2:15 PM
    #648
    eddiefromcali
    Eddie
    100% Stock
  19. May 31, 2024 at 2:26 PM
    #649
    Black widow TRD
    Manuel
  20. Jun 13, 2024 at 6:03 PM
    #650
    Sankster
    Sankster Loving life!
    Paul
    Arizona
    2023 Blueprint Tundra Platinum 4x4
    TRD 3' Lift Kit, 34" Nitto Recon Grapplers
    I still have the lag and surge issue with my '23 Platinum, and it has almost gotten me into accidents when trying to get out into traffic. The local dealer checked and verified that the '22 TSB doesn't apply to my VIN (it was built after the fix was released). They test drove it on a couple of follow-on visits and said it's "normal operation". They told me I should call Toyota Corporate and tell them about the issue so they can open a case. Seems to me Toyota should probably know about the continued problem by now with all the complaints I've seen. I did go in for the previous recall (vehicle rolls when transmission is in park) and they did an update; didn't help the lag / surge at all.
  21. Jun 13, 2024 at 6:29 PM
    #651
    Kap1
    Kap1 New Member
    San Francisco, CA
    These were the good days...
    Throttle lag issues...
    Wind noise...
    Rear differential whine...
    Now I just hope that my truck's engine won't blow up and I'll be VERY happy with my ride!
  22. Jun 14, 2024 at 4:23 AM
    #652
    rlc177
    rlc177 Data Logger
    Northeast PA
    I wish Toyota would as much effort into these issues with as much effort as they put into monitoring for copyrighted materials. I don't think any dealer or tech department can help with this one it really takes someone that knows the ECU/TCU logic to figure out what bug(s) exists. The Newer TCU update that was pushed out with the recall did change some of the dynamics, but I've seen some really bad hesitation on a few occasions as well.
    CO_Native and Kap1 like this.
  23. Jun 28, 2024 at 10:53 AM
    #653
    sandiegosteve
    San Diego
    I think I discovered something with my lag... and maybe it is more a transmission thing.
    Normally I back out of my driveway, shift into drive... and things get interesting. Nothing, nothing, big rev and a lurch. After things warm up, I'm good. Sometimes it is a little soft after a stop sign.
    The other day I backed into a spot and the truck sat all day. So, when I went to leave, it was cold. I pulled out. No lurch or lag.
    Yesterday I started to back out, stopped and shifted into drive with my foot on the brake. Big attempted lurch as the transmission engaged. After I finished backing out, it went into drive fine with no problems. It is just that first cold R -> D shift. If I do it before backing into traffic, things seem fine.
    So, I think what I've been calling lag is more of an issue with initial shifting from reverse to drive on a cold start. That could be more transmission than throttle.
    Anyone else notice similar?
  24. Jun 28, 2024 at 1:18 PM
    #654
    TRD-JP
    TRD-JP New Member
    Winnipeg, Canada
    2023 Tundra CM Limited TRD OR Midnight Black
    I would agree with this. I also notice a tiny bit harder shifting in the first few gears (0-25mph or so) when transmission is cold.
    sandiegosteve[QUOTED] likes this.
  25. Jun 28, 2024 at 2:01 PM
    #655
    cruiserhead
    cruiserhead New Member
    I only notice a lag after backing up then switching to drive. I don't know if its the same thing others are experiencing. Its more noticeable after backing down my driveway (which is slightly downhill).
  26. Jul 3, 2024 at 7:27 AM
    #656
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    AFe makes throttle boosters (think Pedal Monster or PC) for the 3rd gens. They also have CAIs.
    Check it out.
  27. Jul 3, 2024 at 7:32 AM
    #657
    eddiefromcali
    Eddie
    100% Stock
    they dont help
    daverxa likes this.
  28. Jul 3, 2024 at 7:41 AM
    #658
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    You tried em?
  29. Jul 3, 2024 at 7:50 AM
    #659
    eddiefromcali
    Eddie
    100% Stock
    Ive had the Pedal Commander, BMS and Banks...none of them address the issue...they simply add additional throttle % after the lag is gone. I had the TSB performed and sold the Banks unit...no need for it, at least for me.
    sudobash likes this.
  30. Jul 3, 2024 at 7:52 AM
    #660
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    10-4 thanks for the input.
