Issues after oil change.
Discussion in '1st Gen Tundras (2000-2006)' started by CascadeSkyline, Jun 11, 2024.
  1. Jun 12, 2024 at 10:55 PM
    #61
    CascadeSkyline
    CascadeSkyline [OP] New Member
    Forks WA USA
    05 AC Tundra Limited 4x4
    Thank you for the info. I'll hold onto the sensors when I get them and change the oil/battery tomorrow. Then I will drive and screen record the drive and make a YouTube of it. If nothing weird I'll replace the maf alone first and see if there is a difference before doing the O2s.
  2. Jun 13, 2024 at 5:04 AM
    #62
    Considering you have no fuel filter, and your tank is poly, not metal, and you’re not a dumbass who sucked up Seagram thru a vacuum line which Seagram explicitly tells you never to do, I highly doubt it.
  3. Jun 13, 2024 at 5:24 AM
    #63
    Tundra Chief
    Tundra Chief New Member
    Wichita KS
    2021 SR5
    Just a FYI. The O2's have little to do with how it runs. They are watchdogs on your cats. They help make minor adjustments to fuel trims. The A/F's are the major players. Take your snapshot as the issues happens. You may need someone to drive while you capture.
  4. Jun 13, 2024 at 5:41 AM
    #64
    It can get a little confusing though, Denso doesn't use "a/f sensor" to describe all upstreams, in some cases using "O2 sensor" for all four. Generally speaking, you'll find people using "O2 sensor" in here (maybe for that reason), and just specify upstream/downstream so folks know what's being talked about.
  5. Jun 13, 2024 at 7:03 AM
    #65
    Tundra Chief
    Wichita KS
    2021 SR5
    Agreed. Denso isn't the only one still calling them O2's.
    shifty` likes this.
  6. Jun 13, 2024 at 8:58 AM
    #66
    CascadeSkyline
    Forks WA USA
    I just woke up. This is a little confusing the 4 sensors I bought are a/fs correct.
  7. Jun 13, 2024 at 10:44 AM
    #67
    Tundra Chief
    Wichita KS
    2021 SR5
    The front sensors are air/fuel ratio sensors. The rear are conventional O2 sensors. Some people and manufactures call the A/F sensors front or upstream O2 sensors.
    CascadeSkyline[OP] likes this.
  8. Jun 13, 2024 at 11:08 AM
    #68
    I'd over-simplify it: A/F Sensor = O2 Sensor.
    The sensors do roughly the same thing, but kinda have two different roles. "A/F sensor" is common term for the upstream O2 sensor specifically, for good reason.
    Upstream is measuring for oxygen content on the the freshly burnt exhaust to ensure the air/fuel mixture your ECU/ECM has mapped is producing an equally. Down stream (after the cat) is measuring what comes out the back side of the cat, where the ECU/ECM calculates the difference/delta in the two measurements, to ensure your cats are efficiently burning. It's all part of the larger system. This is oversimplifying again, but ....
    That in mind, think about it: If the upstream isn't reading the contents of your exhaust for oxygen/unburnt fuel/etc. coming out of the respective head/bank it's installed on properly, and it's askew enough that the ECU/ECM adds too much or not enough fuel into cylinders, you'd end up with detonation issues, where you're misfiring, burning rich, or burning lean. Misfires lead to rumbling/shaking/bucking/choking. Granted, so can a bad motor mount, but ...
  9. Jun 13, 2024 at 1:12 PM
    #69
    CascadeSkyline
    Forks WA USA
    https://youtu.be/ARs1QUxrKCk?si=A7e9GDglkHx0W2Tc
    I posted live data here. Let me know if i should stop scrolling annoyingly and record on only 1 specific section. This my first time screen recording.
    I am going to change my oil for a second time now. Although it feels like a waste and I should keep my drained 2 day old oil.
    metalpete likes this.
  10. Jun 13, 2024 at 1:29 PM
    #70
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    you got low oil pressure. Unless your gauge is fucked.
  11. Jun 13, 2024 at 2:08 PM
    #71
    CascadeSkyline
    Forks WA USA
    I posted a video on the first gen tundra fb group when I bought the truck and like 20 people said this was normal. If not then yes I need to figure out what's going on.
    https://youtu.be/8d7sgvAgGcg?si=-JSP17Tf_CZMr3v5
  12. Jun 13, 2024 at 2:15 PM
    #72
    Your oil pressure is fine.
    shifty` and FrenchToasty like this.
  13. Jun 13, 2024 at 2:16 PM
    #73
    Here’s mine at idle
    metalpete and FrenchToasty like this.
  14. Jun 13, 2024 at 2:18 PM
    #74
    FishNinja
    Lee
    06DC2wd
    So a wonky gauge? Mine is nearly half way up at idle. And will go past half way when on the gas. IMG_4620.jpg
    you also got a 00' while me and OP got 05-06's. My assumption maybe different read outs? I could be wrong
  15. Jun 13, 2024 at 2:21 PM
    #75
    I watched his video. His behaves just like mine. Around a quarter at warmed idle. Never much over 1/2-3/4 space when on the gas. Send a pic of yours at idle after warmed up.
  16. Jun 13, 2024 at 2:24 PM
    #76
    CascadeSkyline
    Forks WA USA
    Thank God cause I was trying to prevent myself from having a panic attack when he mentioned grenading the motor.
  17. Jun 13, 2024 at 2:25 PM
    #77
    FishNinja
    Lee
    06DC2wd
    Here's my oil gauge at idle.
  18. Jun 13, 2024 at 2:25 PM
    #78
    The internet is fun. We are all trying to help, I promise. Sometimes we get distracted, this place is a great resource, I’ve learned a lot being on here.
  19. Jun 13, 2024 at 2:28 PM
    #79
    After the truck is warmed up and the idle drops?
  20. Jun 13, 2024 at 2:29 PM
    #80
    FishNinja
    Lee
    06DC2wd
    yup. The truck is well beyond warm right now. It's been running since 8am.
  21. Jun 13, 2024 at 2:30 PM
    #81
    your oil pressure is high, you should get that checked out!
    :D:D:D
  22. Jun 13, 2024 at 2:32 PM
    #82
    CascadeSkyline
    Forks WA USA
    Oh I'm not taking offense to anything. If anything I realize I'm being annoying with all the back and forth. But I really can't do shit in my tiny driveway. It's like 7ft wide between the fence and house. And I'm real sick of going to parks or down what we call the A road (a logging road) with no service to work on my vehicles on my days off. That's why I can't just take the axle out and reboot so easily.
    FishNinja and KNABORES[QUOTED] like this.
  23. Jun 13, 2024 at 2:32 PM
    #83
    FishNinja
    Lee
    06DC2wd
    it gets checked once a week. When I put the throttle to the floor and run through 2-3 gears redlining my truck.
    I'd also like to add my truck is NOT the one dying after an oil change. As a matter of fact, last week I did the seafoam treatment in both my tank and crankcase. Damn well exactly like OP. 6oz in the crank, dumped the rest in the fuel tank.
    KNABORES[QUOTED] likes this.
  24. Jun 13, 2024 at 2:39 PM
    #84
    CascadeSkyline
    Forks WA USA
    Also you guys haven't see how fucked my hands are. Doing anything is painful even picking up hot food. They're actually pretty healed right now. Adds a level of irritation to everything I'm doing.
  25. Jun 13, 2024 at 2:40 PM
    #85
    Ouch.
  26. Jun 13, 2024 at 2:45 PM
    #86
  27. Jun 13, 2024 at 2:45 PM
    #87
    Sweet Malone, what did you stick them in?
  28. Jun 13, 2024 at 2:48 PM
    #88
    CascadeSkyline
    Forks WA USA
    You're mother.
    Lmao just a product of the job. That or psorasis/dysochrotic eczema. I don't know the medical facilities out here are worse than the truck shops. All blood work and allergy tests were normal. Started in 2020 on one thumb and spread to this over 4 years. Could be auto immune I really have no answers after 10 visits and multiple tests. Probably gonna have a short life from the inflammation tho.
  29. Jun 13, 2024 at 2:53 PM
    #89
    FishNinja
    Lee
    06DC2wd
    bmf4069 and FrenchToasty[QUOTED] like this.
  30. Jun 13, 2024 at 2:55 PM
    #90
    FishNinja
    Lee
    06DC2wd
    lotion goes a long way my guy. You should probably see a dermatologist.
