Driver’s Side Grab Handle...
Discussion in '2.5 Gen Tundras (2014-2021)' started by sbbrown333, Feb 2, 2019.
  1. Feb 27, 2024 at 8:47 AM
    #121
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    Crash test for BOF is bit of a trial and error, we have to keep in mind that second gen XK50 Tundra was more or less designed in the early 2000s, you can see why they removed the driver's side handle during the facelift.
    https://youtu.be/9iZnUqGX6oA?si=M6b-NmnN68ixbAuN
    vs why 2022+ has the handle back.
    https://youtu.be/I4frai-5qa4?si=-cyf4ncBC0XDMlkb
    The a-pillar deformation is minimal compare to the 2nd gen.
    BoyHowdy likes this.
  2. Feb 27, 2024 at 2:15 PM
    #122
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    :monocle:
  3. Feb 27, 2024 at 2:16 PM
    #123
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    The A pillar deformation was only an issue on the crew cab. The DC did better.
    https://youtu.be/rAe6fBAJoMw?si=YxchfVpSU-ObCCY8
    Gene_in_FL likes this.
  4. Mar 21, 2024 at 11:53 AM
    #124
    JohnWhicker
    JohnWhicker New Member
    Just got mine for $150 brand new
    sudobash, mgrs, BoyHowdy and 3 others like this.
  5. Mar 21, 2024 at 1:23 PM
    #125
    FISHN43
    FISHN43 New Member
    Ohio
    2020 Super White TRD Pro
    Must have had a nice discount code!?!?
  6. Mar 21, 2024 at 3:00 PM
    #126
    JohnWhicker
    No, they just had a sale or something, discount by default I guess.
    FISHN43[QUOTED] likes this.
  7. Apr 20, 2024 at 9:30 AM
    #127
    101ABNAASLT
    101ABNAASLT New Member
    2021 Tundra Limited 4x4
    I don't know why everyone hypes Sparksparts.com. I always end up finding it cheaper via the Toyota Online Parts store by choosing my local dealer. Sparks charges way too much for shipping when Toyota gives free shipping.
    Ceezurin likes this.
  8. Apr 24, 2024 at 8:06 PM
    #128
    mgrs
    mgrs New Member
    '20 OR
    Great post. Ordered Saturday at that price from Fred Anderson and had parts in hand/installed today.
    To note:
    The 2014+ garnish has a wiring cutout on the dash tab that the grab handle garnish does not. You'll need to modify the garnish to match.
    Additional parts you'll need are:
    - 20-25mm bolt/washer (M6x1.0 matches the existing upper bolt) M6, M8, 1/4, 3/8 will fit
    - Threaded clip nut to match above. The lower grab handle mount tab is present, but you will need a clip nut unless you intend to tack weld a nut on the tab
    I used an M6x1.0x20 JIS Bolt with washer and spring washer and M6 threaded clip nut from Advance auto parts to meet the missing hardware requirement.
  9. Apr 25, 2024 at 3:49 AM
    #129
    Bergy24
    Bergy24 New Member
    Thanks for listing the Metric parts to match the existing. My order from Fred Anderson should be delivered tomorrow and I ordered it last Thursday. Took advantage of the sale and free shipping they had last week. Did you get all the hardware from Advance Auto and if so, do you happen to have the part numbers and costs?
  10. Apr 25, 2024 at 4:30 PM
    #130
    mgrs
    mgrs New Member
    '20 OR
    IIRC is was Dorman P/N 961-315D
    The JIS M6x1.0x20mm bolt I got from overland metric. I have tons of those fasteners in various sizes sitting around from another project.
    Any M6x1.0x20-30mm would work. JIS just matches (exactly) what's already on the truck with a 10mm convex bolt head.
    You could got 1/4" SAE like the sparks kit, but that's low rent and more than your truck deserves.
    Bergy24[QUOTED] likes this.
  11. Apr 25, 2024 at 4:33 PM
    #131
    UnderTundra
    UnderTundra New Member
    FL
    2021 Limited Crewmax 4x4
    Mine came in from Fred Anderson yesterday. Best 20 minute mod there is.
    Bergy24 likes this.
  12. Apr 25, 2024 at 4:50 PM
    #132
    Bergy24
    Bergy24 New Member
    What hardware did you use
  13. Apr 25, 2024 at 5:09 PM
    #133
    UnderTundra
    FL
    I used a 1/4-20x1.5” hex bolt, flat washer, and speed nut.
    If I had to do it again, I would use M6 hardware instead of SAE. The 1.5” length bolt is also overkill, you could probably use a 1” just fine.
  14. May 3, 2024 at 11:44 AM
    #134
    Gene_in_FL
    Gene_in_FL SUPER genius
    FLORIDA
    2016 SR5 DC 5.7 2021 SR5 DC 5.7
    I just made off with handle and trim for $12 bucks!
  15. May 3, 2024 at 8:01 PM
    #135
    ttundra10
    ttundra10 New Member
    Terry
    2021 Midnight Black Tundra Sr5 4wd
    3" level kit, American Outlaw rims, Blackout badge's.
    Thats a steal. Good for you.
  16. May 27, 2024 at 12:17 AM
    #136
    Matty33
    Matty33 New Member
    2017 Tundra Limited CM
    Driver side grab handle, Phoenix Automotive Tesla style head unit, center console wireless charger, console safe, TRD Pro grille, Form led projector head lights, grille parking lights, Caliraised Amber fog lights, Caliraised front bumper color match caps, color match mirror caps
    Foothills Toyota Burlington WA, online store has the parts in stock and 20% Memorial Day discount. ~$175 shipped. FYI
  17. May 27, 2024 at 3:21 AM
    #137
    Bergy24
    Bergy24 New Member
    Fred Anderson has 25% off and free shipping on orders $75 until May 30th.
    Begbie likes this.
  18. May 27, 2024 at 8:55 AM
    #138
    Matty33
    Matty33 New Member
    I went to the website and neither of the parts would add to my cart. The " add to cart button " would turn dark red and then the website would just hang.
  19. May 28, 2024 at 10:16 PM
    #139
    Begbie
    Begbie The big yellow one is the sun!
    Wilmington, NC
    2020 White Tundra Limited
    I was able to add both parts to my cart, but I have the beige. I'm noticing gray seems to be the more in demand.
    $151 but the shipping wasn't free...it only brought it to $164 though. Now to head to the hardware store for the screws/bolts.
  20. May 29, 2024 at 2:43 AM
    #140
    Bergy24
    Bergy24 New Member
    Get the metric hardware if you can find it. No difference in the way it works, but it keeps all the hardware metric on your truck so you don't have to switch back and forth to SAE.
    Begbie[QUOTED] likes this.
  21. May 29, 2024 at 7:39 AM
    #141
    seydou
    seydou Distinguished Member
    I understand your point, but in this application it is virtually meaningless. Who is planning on removing the handle after they have added it? And for a situation like this, you can still remove the bolt by using the closest sized SAE socket if you don't have the metric, or vice versa.
    Stumpjumper and Bergy24[QUOTED] like this.
  22. May 29, 2024 at 3:42 PM
    #142
    GLaDOS
    GLaDOS Engineer
    Central Oregon
    2014 Tundra SR5 Double Cab
    That crushing feeling you get when you wait for over a month for a part to arrive… only for it to be the wrong one. :pray:
    What I ordered on 4/21:
    What I received on 5/29:
  23. Jun 4, 2024 at 7:04 AM
    #143
    Begbie
    Wilmington, NC
    Fred Anderson shipped my grab handle yesterday and it's due to arrive today :), so I guess I'll head to the Depot of Homes in a little to get the bolt, washer, u-nut. Hope it's the right color!
  24. Jun 4, 2024 at 7:35 AM
    #144
    101ABNAASLT
    I got two OEM bolts and washers from my local Toyota dealership for less than $2.00 - they actually had them in stock. I got the extruder clip from the Tractor Supply Company. Install is very easy and I have used my grab handle many times since.
    Bergy24 and Begbie[QUOTED] like this.
  25. Jun 10, 2024 at 9:59 PM
    #145
    Nova1967
    Nova1967 New Member
    Maryland
    2021 tundra crew max, 1794, Smoked Mesquite
    Rear Sway bar, TRD dual exhaust, storage unit under rear seat, cargo mate, 10 spoke aftermarket 21" rims (Lexus), weather tech mates, Morimoto headlights, HR hood bar light, Chrome deleted: bulge, grille surround, valance, bumper end caps, mirrors. Replaced all parts with smoked mesquite, and L.E.D bright interior lights.
    I found a driver side grab handle in the junkyard and sold it after receiving my new handle from Sparks Part. These handle will fit 2014 - 2021 Toyota tundra but the color will sometime have a different tint.
  26. Jun 11, 2024 at 7:08 AM
    #146
    Begbie
    Wilmington, NC
    I've had mine installed for over a week and I forget it's there, so I haven't used it to get in/out of the truck. I let out an audible, "Oh man, I forgot to use my new handle to get in the truck!" and the wife thought I was crazy. :D She's like, "You didn't need it before!"...but now that it's installed and new I want to use it. :rofl:
    Pig Rig likes this.
  27. Jun 11, 2024 at 10:56 AM
    #147
    Big Bethany
    Big Bethany New Member
    Rich
    2021 Toyota tundra
    So any pillar or handle from 2014 - 2021 work?
  28. Jun 12, 2024 at 7:48 PM
    #148
    GLaDOS
    GLaDOS Engineer
    Central Oregon
    One “oh sh!t” handle installed!
    If anyone wants some metric hardware for their handle, send me a DM, as I have plenty on hand…
    • M6-1.0 x 30mm DIN 933 A4-70 Stainless Steel Hex Cap Screw
    • M6 6.4mm x 18mm DIN 9021 A4 Stainless Steel Fender Washer
    • M6-1.0 x 23.50mm x 12.50mm Phosphate “U” Spring Nut (made for GM & Ford)
    sudobash and Begbie like this.
  29. Jun 17, 2024 at 4:18 PM
    #149
    SpeshulED
    SpeshulED New Member
    Sandy Eggo/Chula Vista, So Cal.
    2015 Mag Gry Ltd. CM TRD Tundra
    TRD Pro Grill | AMP Steps | Husky Floor Mats | SnugTop Sportsman Super Sport Shell | 55w 5k HID Headligts | Method Racing NV Bronze 18x9 | BFG KO2 35x12.5r18
    is there junk yard the only place I can find one of these handles now? looks like everyone online is sold out
  30. Jun 17, 2024 at 4:42 PM
    #150
    JohnWhicker
