General Supercharger Thread
  1. Jun 12, 2024 at 6:36 AM
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    I keep posting this hood, it'd be perfect for Turbo situations! It has a forced air inlet that dumps air over the Turbo area. As well as louvers to vent hot air towards the rear of the hood. I'm gonna beat this dead horse until I see it on a rig here lol
    @TurboKits.com drop ship this from your site as a recommended ad on, idk stage 3? lol
    https://amerihood.com/toyota-tundra-2014-2021-ssk-style-functional-heat-extractor-ram-air-hood.html
    ARES35, HulkSmurf14, Mdl and 4 others like this.
  2. Jun 12, 2024 at 6:47 AM
    TurboKits
    TurboKits New Member
    M3Tundra-JK[QUOTED] likes this.
  3. Jun 12, 2024 at 6:49 AM
    TurboKits
    I am actually going to cut a hole in the hood on our 2014, right here and see what it does!
    ARES35, reywcms, HulkSmurf14 and 4 others like this.
  4. Jun 12, 2024 at 6:50 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Now that you mention it I thought the Tundra does a temp check too or takes temps into account though I am not aware of an oil temp sensor.
    Mdl likes this.
  5. Jun 12, 2024 at 6:54 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    It does, I got a CEL when I installed the Mishimoto thermostat and housing. I can't recall what it was, but something to do with not getting to temp when expected.
    ARES35, Saltyhero13[QUOTED] and Mdl like this.
  6. Jun 12, 2024 at 6:57 AM
    TurboKits
    It's not checking the oil temp, but rather checking timing values, etc at 180* coolant temp. With a 160* thermo, it doesn't get up to temp in time for it to check, so it throws a code for bad Oil Control Valve. Nothing is actually wrong, other than the ECU not getting the temps it wants during the check.
    I bet it was OCV or some timing code.
  7. Jun 12, 2024 at 7:23 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I forgot I have a Mishimoto thermostat & silicon hoses to install when I get around to the Radiator that has been sitting for a year. I have no clue where in the garagehole they are.
    lol
    ZPhilip, M3Tundra-JK and HulkSmurf14 like this.
  8. Jun 12, 2024 at 8:23 AM
    Saltyhero13
    So is it that the sensor doesn't have a PID?
    It may be your situation I'm recalling about running too cool.
  9. Jun 12, 2024 at 8:32 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Not sure I follow?
    The CEL referred to something not being up to temp when expected, I should have taken a picture of the code like I usually do, but the gist was that the ECU cross-checks the ambient air temp with the coolant temp and if it doesn't get to temp when it should it trips the CEL.
  10. Jun 12, 2024 at 8:36 AM
    Saltyhero13
    Thank you for clarifying. Maybe throwing P0117 or related?
    RE: PID is the oil sensor readable? Does it have an address? I think some of the other engine temp reading are derived.
    armyoffoo[QUOTED] likes this.
  11. Jun 12, 2024 at 8:50 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    The oil temp is available as a channel in HPTuner's software, so it should have a PID, although not sure how it's derived since I thought there was only a pressure sensor. P0117 doesn't sound familiar, I don't recall it mentioning a sensor specifically...but it was a couple years back.
    Saltyhero13[QUOTED] likes this.
  12. Jun 12, 2024 at 8:57 AM
    Saltyhero13
    Not really talking about pressure but it is possible it could be used for some engine temp calc.
    I think it was noted the coolant or oil temps (don't remember which) are derived from something else, discussed on some of the OBD reader threads.
  13. Jun 12, 2024 at 9:05 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    I was just saying, to my knowledge, there is only an oil pressure sensor, and that I believe the oil temp is calculated instead of being reported by a sensor.
    There is a coolant temp sensor in the water crossover by the upper radiator hose.
  14. Jun 12, 2024 at 9:07 AM
    Saltyhero13
    Ahh. That clarified it. Yeah we were on the same page. The added information through me off, thought we were talking about different things.
  15. Jun 12, 2024 at 9:13 AM
    Saltyhero13
    armyoffoo likes this.
  16. Jun 12, 2024 at 9:35 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    There's also the heat exchanger, at least on the tow packages, down by the oil filter. That probably keeps the two fluids in relatively close temperature to each other. Maybe the oil temperature is inferred from the coolant temperature based on that and they just use that assumption for the non-tow packages too. Purely speculation.
    There's also a coolant temp setting in HPT in Engine > Spark > Retard > Knock Adaptive Learning >Enable > Min ECT that may or may not be applicable to what you guys are discussing. Heck if I know, just more speculation, and guessing.
  17. Jun 12, 2024 at 9:37 AM
    Saltyhero13
    Great! All the information helps IMO.
    Wynnded[QUOTED] likes this.
  18. Jun 12, 2024 at 10:16 AM
    TurboKits
    Did this on my lunch break, too about an hour, maybe less! I've been wanting to do it for a while, was actually way easier than I thought. Thank god for the THIIINNN hood metal stamping. LOL. I'll get some weather stripping on the edges and eventually find and add a proper scoop.
    reywcms, ARES35, B.Ross and 4 others like this.
  19. Jun 12, 2024 at 12:00 PM
    e30cabrio
    107 ambient sitting in the drive through
  20. Jun 12, 2024 at 12:40 PM
    e30cabrio
    Garagehole opened wide & spit out....
    Also forgot I have a fan, controller is around here somewhere.
    Mdl and M3Tundra-JK like this.
  21. Jun 12, 2024 at 1:01 PM
    NatesNightMare
    NatesNightMare Is what it is
    Pinetop Az
    Thinking about doing it before I head out of state tomorrow. Esp through NV. Temps are already decently warm and ill be towing
  22. Jun 12, 2024 at 1:45 PM
    bflooks
    bflooks New Member
    Metrowest MA
    My scroll had stopped at only the top half of the first picture and I had to reread your post a few times because I read Garagehole, saw your photo and the brain said Gloryhole.
  23. Jun 12, 2024 at 1:55 PM
    bflooks
    bflooks New Member
    Metrowest MA
    Don't think I'm not seeing your posts. lol
    True story - I think the wife will murder me if I tell her my splurge now requires another splurge that may or may not be the equivalent of a weekend away. So, if I one day end up with this hood, please call for a wellness check.
  24. Jun 12, 2024 at 3:05 PM
    carn_dogg
    carn_dogg i don't think so
    Pat
    Eastern Shore MD
    2013 Black Tundra Platinum
    Orrrr, now hear me out. Double down…. Weekend getaway plus the splurge. Everyone is happy.
    Plus…Father’s Day is right around the corner, so you can broach the topic from a mental higher ground lol
  25. Jun 12, 2024 at 3:22 PM
    Saltyhero13
    Different kind of blower and sucker.
    bflooks[QUOTED] likes this.
  26. Jun 12, 2024 at 3:29 PM
    e30cabrio
    Viktors reservoir came, it's awesome! Gotta figure out the fittings to get.
  27. Jun 12, 2024 at 7:56 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    Dropped off my truck at a local shop to have them ship the trans to IPT for a rebuild. Got about the same 11 hours as well. Getting a transmission cooler installed at the same time. Very curious how differently the truck drives and hopefully actually lasts this time vs Ive lost 2/3 shift+reverse twice now. Then Ill be back to being a menace.
  28. Jun 12, 2024 at 8:15 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Good choice!
  29. Jun 12, 2024 at 10:03 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Those 2nd gear clutches get burnt. Happened to my first trans. Your one up on me. But not in a good way.
  30. Jun 12, 2024 at 11:41 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    Haha yes. Toyota replaced one transmission for free, but I was nervous the same thing would just happen again lol. Now we're doing it right! Plus now that I know how weird the transmission shifts with the gear overlap, slow shifts and flex lock makes sense why these fail with lots of extra power. Throwing in some Caltracs too!
    ARES35, Wynnded and Mdl[QUOTED] like this.
