General Supercharger Thread
  1. Jun 11, 2024 at 8:14 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    Those that have it....does it lower average temps?
    @PolishedTRD - I expect nothing less than a full report.
    I run 194 degrees....no matter what. and like @Saltyhero13 said, is it good to run this thing at 170-ish degrees?
  2. Jun 11, 2024 at 8:14 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    You can have your torque converter lockup in 4th gear and lower apply rpms a few 100 in 5th in tow/haul. That will lower temps.
  3. Jun 11, 2024 at 8:18 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Here's my Taurus fan, Volvo relay and BMW thermostat. I removed my a/c relay as it was having issues. It's a Frankenstein setup but works...
  4. Jun 11, 2024 at 8:24 AM
    bflooks
    bflooks New Member
    Metrowest MA
    Oh, I'm talking coolant temps, not trans temps. Trans is well managed at this point, though I do want to change the location of the cooler after this towing season.
    Mdl[QUOTED] likes this.
  5. Jun 11, 2024 at 8:41 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    @bflooks gotcha!
    There is a temp I believe 190 deg to keep engine oil at where it will still burn off water and other impurities. Could be 200 like @Saltyhero13 stated.
  6. Jun 11, 2024 at 8:44 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Yes burning off the water is one aspect. Activating the additives package was the other. Lake Speed Jr/Oil Geek just has a vid on it. Some of the techs can talk to the engine's opitmal operating temp range. I've seen it posted just don't remember off hand.
    Mdl[QUOTED], Wynnded and PolishedTRD like this.
  7. Jun 11, 2024 at 8:57 AM
    Saltyhero13
    So 180 seems fine. Range looks like 180 to 220.
    Edit Worth noting oil temp lags behind engine temp by ~20 mins.
    reywcms and Mdl[QUOTED] like this.
  8. Jun 11, 2024 at 9:08 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    My air to engine oil cooler is 164-168 deg at the outlet. Engine coolant 190-195 deg with 185deg thermostat. Trans at 150-170 deg at the pan. Ambient air 80deg.
    Saltyhero13[QUOTED] likes this.
  9. Jun 11, 2024 at 10:42 AM
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    When i was speaking with Mishimoto about aftermarket cooling on my M3 (that engine runs HOT), they had mentioned that a lower temp thermostat, and all aluminum radiator would keep the coolant temps low, BUT would increase the under hood temps. So that may effect the IAT...hood louvers are huge with the E46 M3 crowd because of it.
  10. Jun 11, 2024 at 11:32 AM
    ssmokedz
    Shelton CT
    Damn sir, you build some cool Shit!
  11. Jun 11, 2024 at 11:34 AM
    mralanle
    mralanle New Member
    What intake is everyone running? Has anyone purchased the AFE that’s out to fit with the 1900?
  12. Jun 11, 2024 at 11:38 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    No gain over the maggy box really. I'd stick with that. Custom prospeed here
    ssmokedz, Mdl and Saltyhero13 like this.
  13. Jun 11, 2024 at 12:32 PM
    carn_dogg
    carn_dogg i don't think so
    Pat
    Eastern Shore MD
    2013 Black Tundra Platinum
    I’m with you. 194 idling in 100 degree heat in traffic and 194 at 20 degrees in the winter. Doesn’t matter how hard I run the truck she stays at 194
  14. Jun 11, 2024 at 1:58 PM
    NatesNightMare
    NatesNightMare Is what it is
    Pinetop Az
    Man I hit 200, maybe a few over at times but will drop when it opens.
    I was about to ask what are the temp ranges of coolant, oil and ATF? That way I can input it on my reader to keep an eye on when I head out of state this thurs while towing
  15. Jun 11, 2024 at 2:28 PM
    carn_dogg
    Pat
    Eastern Shore MD
    I wouldn’t worry one bit about 200. Towing and low mountain passes can easily get up passed 205-210
  16. Jun 11, 2024 at 2:37 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    200 is def normal
  17. Jun 11, 2024 at 2:41 PM
    snivilous
    SW UT
    300k+ Supercharged 2008
    I usually have 220 be my point of starting to worry about stuff. At 220 nothing bad is happening, but you know temps are beginning to run away so should start getting cautious. That goes for all three fluids.
    TurboKits, koditten, Wynnded and 4 others like this.
  18. Jun 11, 2024 at 2:42 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    My Sequoia runs at 194-206.
  19. Jun 11, 2024 at 4:36 PM
    NatesNightMare
    Pinetop Az
    Has anyone cut through the hood bulge to let air flow through that way other than for a light bar lol?
  20. Jun 11, 2024 at 4:40 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    yep we did this on the old man’s rig before going to the vented hood
  21. Jun 11, 2024 at 4:41 PM
    bflooks
    bflooks New Member
    Metrowest MA
    Not here, but I'm starting to research water management of louvers since I'm debating putting one directly over the turbo, solely for heat exhaust.
    TurboKits, NatesNightMare and Mdl like this.
  22. Jun 11, 2024 at 4:49 PM
    NatesNightMare
    Pinetop Az
    Nice, I was thinkin about it today. How did it work out other than water getting through?
  23. Jun 11, 2024 at 5:05 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
  24. Jun 11, 2024 at 5:55 PM
    Land Bruiser
    Land Bruiser New Member
    2018 Lexus 5.7
    Harrop 2650, 285/70r20
    You have a turbo blanket on it?
    bflooks[QUOTED] likes this.
  25. Jun 11, 2024 at 6:04 PM
    bflooks
    bflooks New Member
    Metrowest MA
    Yes, and while the blanket is cool enough to place a hand on, I'd still like the evacuate the radiant heat as much as possible, especially when stopped/parked. Long term plans. It'll take me a while to figure out which way I want to go.
    TurboKits, Mdl and Saltyhero13 like this.
  26. Jun 11, 2024 at 6:26 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Worked well! Definitely recommend but getting heat out is the key hence we went vented hood
  27. Jun 11, 2024 at 7:16 PM
    NatesNightMare
    Pinetop Az
    Cool, wish I had more time. Leaving thurs to go up north, esp with the warm weather right now and going through NV. Maybe while im up there or when I get back
    ARES35, ssmokedz and reywcms[QUOTED] like this.
  28. Jun 11, 2024 at 7:17 PM
    NatesNightMare
    Pinetop Az
    Maybe flip the hood scoop backward and cut that out lol:rofl:
    HulkSmurf14 and reywcms[QUOTED] like this.
  29. Jun 12, 2024 at 4:15 AM
    ssmokedz
    Shelton CT
    That might look a bit funny but if it works hey why not!
  30. Jun 12, 2024 at 5:46 AM
    TurboKits
    TurboKits New Member
    Yeah gotta be careful about running too cool, we had an issue on a customer's build (different platform), but the stock ECU did all of its timing checks IIRC at 180*, he had put a 160* thermostat in and kept getting OCV and cam timing codes. He pulled the motor apart 2 or 3 times before we all finally caught the issue. So no reason not to try it, but only one variable at a time, in case something odd happens, you'll know exactly what it is and can revert back. Not to mention oil operating temp and proper viscosity.
