TPMS is not letting me set PSI; dirty collision sensor message
Discussion in 'Wheels & Tires' started by Big Bethany, Jun 10, 2024.
  1. Jun 11, 2024 at 7:03 AM
    Yes, Jomax is very hard to find. The only way you will fine one is if you run across another member who is selling one. The company will not provide any info what-so-ever on it. It was a big issue as to why production was stopped on them a few years back. I have pictures that I can send to both of you. The biggest issue that you will run into is the cover itself. It was a special material that worked with the sensor. I'm not positive but i think it was a type of Macralon or something to that effect. There are a couple of members that have extra covers for theirs but you would have to post a "WTB" to see if you get any hits.
  2. Jun 11, 2024 at 7:07 AM
    Big Bethany
    Big Bethany [OP] New Member
    Rich
    2021 Toyota tundra
    Got so even if I can 3d print something it probably won't work as the plate was a special material. Is there something I can plug in to bypass that feature and eliminate the error?
  3. Jun 11, 2024 at 7:16 AM
    18" TRD Off Road Wheels
    You can't eliminate the error without having it functional. It's a safety item so it's not easily bypassed.
  4. Jun 11, 2024 at 7:18 AM
    I should add, the "easy" fix is to get an OEM grille and cover. Not cheap, but that's the best bet.
  5. Jun 11, 2024 at 7:22 AM
    Dave8699
    Dave8699 Trackrat
    NJ
    04 Tundra AC, 2014 Tundra 1794 Crew Max
    Whole truck Raptor liner in olive green, leer camper cap, 5100 with OME, Wheelers AAL and Firestone Air bags.
    Yea I like the look of the aftermarket grill.
  6. Jun 11, 2024 at 7:28 AM
    Big Bethany
    Rich
    2021 Toyota tundra
    Yes sir I'm with my brother on this one
  7. Jun 11, 2024 at 7:39 AM
    owb2gp
    owb2gp New Member
    ID
    I have an extra Jomax cover I'm willing to part with.
    TacomaTRD4x402 and Tundra234 like this.
  8. Jun 11, 2024 at 7:40 AM
  9. Jun 11, 2024 at 7:47 AM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    Thanks, I've spent alot of time on that thread drooling over which route i want to take. Right now it's hard to justify the expense so it's probably in the middle of my wishlist. I have a spare grille grille that I bought from a part out that I've been using to experiment with. Considering going the cheap method by buying just the middle insert(new trd pro grille)and figuring out the cheapest TSS method which would probably be the garnish knockoff and cutting it.
  10. Jun 11, 2024 at 7:48 AM
    Big Bethany
    Rich
    2021 Toyota tundra
    Did the Jomax come with multiple front plates?
  11. Jun 11, 2024 at 7:50 AM
    It was an option to buy extras if I recall.
  12. Jun 11, 2024 at 7:50 AM
    TacomaTRD4x402
    Southern California
    Only 1 is needed though, right?
  13. Jun 11, 2024 at 8:02 AM
    Correct.
  14. Jun 11, 2024 at 8:07 AM
    owb2gp
    owb2gp New Member
    ID
    I bought the bracket and 3 covers because I wanted back up just in case.
  15. Jun 11, 2024 at 8:07 AM
    Big Bethany
    Rich
    2021 Toyota tundra
    Might be a dumb question, but why does it need a plate? From pictures it looks like a metal housing.
  16. Jun 11, 2024 at 8:09 AM
    owb2gp
    owb2gp New Member
    ID
    No clue. This is what I bought from Jomax years ago. Brand new, never installed. Not willing to sell the bracket at this point.
  17. Jun 11, 2024 at 11:58 AM
    Big Bethany
    Rich
    2021 Toyota tundra
    So back to the TPMS situation, I dropped of the truck at a toyota specialist not the stealership. The technician ran the reader and said the code that came up is for no spare wheel with TPMS. Never heard of that being an issue and not at least showing the reading for the other 4 wheels.
  18. Jun 11, 2024 at 12:39 PM
    Steel spares on the Tundra do not come with sensors. Tell him to try again...he failed at that one. Did he scan the other 4 wheels to see if sensors are installed?
  19. Jun 11, 2024 at 12:59 PM
    Big Bethany
    Rich
    2021 Toyota tundra
    Supposedly the spare TPMS is knocking the other 4 out. Doesn't make snice at all but not going to get onto it deeper snice I have to change tires by the end of the year.
  20. Jun 11, 2024 at 1:03 PM
    #50
    There is no spare TPMS. He is wrong on that part. If there are sensors installed in the 4 wheels, a scanner will detect them. Is there a Discount Tire close to you?
  21. Jun 11, 2024 at 1:10 PM
    #51
    Big Bethany
    Rich
    2021 Toyota tundra
    Yea I'll swing by and ask to scan the wheels and see if I have sensors.
  22. Jun 11, 2024 at 2:26 PM
    #52
    Big Bethany
    Rich
    2021 Toyota tundra
    So I mechanic texted me saying the car is almost ready to be picked up. So I just had to ask him again if he scanned each wheel for TPMS. He said wheels have no sensors. Now that's a better response and 100% the reason why the TPMS is on. Not because of no spare tire with TPMS.
  23. Jun 11, 2024 at 2:30 PM
    #53
    I called that one LOL.
