Bmf's brake borking
Discussion in '1st Gen Tundras (2000-2006)' started by bmf4069, May 24, 2024.
  1. May 28, 2024 at 4:24 AM
    bmf4069 [OP] Michelob Ultra coinesour
    Bleeder, hardlines, and braided hoses ordered. I'll probably just pick up a battery from wallyworld.
    BroHon and Mr.bee like this.
  2. May 28, 2024 at 5:47 AM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    Im here to fling poo and do some mangling' and brother, Im all out of poo.
  3. May 28, 2024 at 5:58 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Cobble up a riser bracket for his lspv. If he's still got it.
    bmf4069[OP] and JakeJake like this.
  4. May 28, 2024 at 7:23 AM
    kentuckyMarksman
    kentuckyMarksman New Member
    I like that host clamp idea. When I bought my truck someone had zip tied mine on. The bolts are broken off on mine. I recently replaced the zip ties with new ones because I wasn't sure how old they were.
    BroHon[QUOTED] likes this.
  5. May 28, 2024 at 7:40 AM
    How do these bolts break off? Mine are still solid even though they’re rusty. You’d think it’d be a common occurrence here in the salt belt.
    BroHon and metalpete like this.
  6. May 28, 2024 at 7:49 AM
    metalpete
    metalpete New Member
    ID
    2001 Tundra 4.7 4x4 SR5
    Toytech 2.0 Coilovers Camburg UCA's JBA headers Dynomax cat-back exhaust 90-221HD Leafs
    ^^ Mine broke because they were rusted solid (and I'm not close to the rust belt). Gave them several PB baths and both snapped the second I tried to remove them. Not totally surprising, they're just stubby 10mm or 12mm bolts.
    Jack McCarthy and BroHon like this.
  7. May 28, 2024 at 7:55 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    when was the last time you had the calipers off?
  8. May 28, 2024 at 8:05 AM
    Never. Haha
    Actually A tech did the caliper upgrade back in 2008 to help solve the front end vibration issue which turned out to be a need for road force balancing the front tires down to 20 lbs of runout instead of the default 40 lbs for truck tires. That and the need for a front end alignment after he changed my front end wheels bearings.
    metalpete likes this.
  9. May 28, 2024 at 8:08 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Thats a long time on the same rotors. Color me impressed.
    Jack McCarthy likes this.
  10. May 28, 2024 at 8:38 AM
    Must be why they pulsate. Haha
    Original OEM rotors only turned once.
    Mr.bee[QUOTED] likes this.
  11. May 28, 2024 at 11:36 AM
    metalpete
    ID
    I was going to do the z36 upgrade, but I just sent them back to Summit. Been sitting in boxes for 6+ months, better to have the $$ back I guess :(
  12. May 29, 2024 at 11:04 AM
    Bleeders and hoses will be here tomorrow. Called my dealership to check on the order and they said they had the drivers side hard line in stock. Passenger, the one I need, could be 10-15 business days out. Fuck.
  13. May 29, 2024 at 11:08 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Plenty of time to rebuild your calipers.
  14. May 29, 2024 at 3:33 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    I'm going to replace my zip ties tonight!
    des2mtn and BroHon[QUOTED] like this.
  15. Jun 2, 2024 at 4:54 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Preventative zip tie changes, :rofl::rofl:
  16. Jun 7, 2024 at 12:39 PM
    JakeJake
    2000 Tundra AC 4X4
    bmf4069[OP] and shifty` like this.
  17. Jun 10, 2024 at 5:28 AM
    Yup, me, Jake, and Dale got the brake lines in. Replaced the hard and soft lines in the front, and the soft line in the rear. Went braided SS for the soft lines. Had to put a little heat on the pass side line, and the drivers side rear bleeder. Got the new bleeders in for the rear. Speed bleeders are pretty neat once you figure out how they work. As @shifty` says, RTFM. Replaced the battery as well. 6 years old with 2 years pushing 1200 watts of amps.
    We bled it 2-3 times and I took it around the block. Pedal did not feel good and braking sucked. Bled again. Drove again. Beld again and adjusted the prop valve up. Drove again. Did a final bleed and called it good.
    My brakes sucked before, and they're still not good, hence Jake's post above. I'm sure they're out of whack, and full of diff juice. But, Ironman is road worthy, and 2 15s still hit hard as fuck.
    Till next time fuckos, bmf out. Here's to the next mangling.
