New Exhaust System
Discussion in 'Performance and Tuning' started by reywcms, Jan 27, 2024.
  1. Jun 1, 2024 at 3:27 PM
    #301
    RobertD
    Robert
    DFW, Texas
    TacomaTRD4x402 likes this.
  2. Jun 1, 2024 at 3:32 PM
    #302
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    Thank you
    RobertD[QUOTED] likes this.
  3. Jun 2, 2024 at 10:06 AM
    #303
    ARES35
    ARES35 New member for life
    Mile high
    Downpipes on order waiting on shipping confirmation. These sound a lot better then the patched up stockers I'm running right now
    reywcms[OP] and e30cabrio like this.
  4. Jun 2, 2024 at 11:49 AM
    #304
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
    Rc23, reywcms[OP], Rugerla1 and 12 others like this.
  5. Jun 2, 2024 at 11:51 AM
    #305
    2TunGet1
    2TunGet1 Tundra owner since 2000
    2020 Limited 4x4 CM QS / 2000 Limited 4x2 AC Black
  6. Jun 3, 2024 at 8:42 PM
    #306
    Kenny1794
    Kenny1794 New Member
    reywcms[OP] and JMGmanAZ[QUOTED] like this.
  7. Jun 4, 2024 at 2:02 PM
    #307
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    12 days, I just got shipping confirmation on my cat-back :bananadance:
    reywcms[OP], Mdl, Saltyhero13 and 9 others like this.
  8. Jun 4, 2024 at 4:06 PM
    #308
    2TunGet1
    Just got my shipping confirmation! Be here Thursday!:yes:
  9. Jun 6, 2024 at 12:00 PM
    #309
    PeruvianDemon
    PeruvianDemon New Member
    Bruno
    I just got mine after 3 weeks, thank you reywcms for starting the forum discount.
  10. Jun 6, 2024 at 7:49 PM
    #310
    2TunGet1
    Received, excellent packaging. I’ll have to install this weekend when it cools down. 104 outside today.
  11. Jun 7, 2024 at 5:53 AM
    #311
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Awesome, trade ya.
    2TunGet1[QUOTED] likes this.
  12. Jun 7, 2024 at 6:32 AM
    #312
    2TunGet1
    :bananadead:
  13. Jun 7, 2024 at 7:15 AM
    #313
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
    Yup, it's that time of year. Called in sick yesterday to go "Tubing in the Toilet" with out-of-town guests.
  14. Jun 8, 2024 at 9:31 AM
    #314
    2TunGet1
    The catback came with no instructions and I can’t see any online. I realize it looks straightforward but is there anything I should know before I crawl under there? @JMGmanAZ
  15. Jun 8, 2024 at 10:36 AM
    #315
    B.Ross
    B.Ross New Member
    Southern Utah
    2012 TForce CrewMax 4wd
    I used a small ratchet strap hooked onto the muffler to pull the x pipe into the pipes while everything was hanging. Used a rubber mallet and gently tapped the pipes until they seated completely into the X pipe, then tightened the clamps. Hope this makes sense.
    JMGmanAZ, texasrho83 and reywcms[OP] like this.
  16. Jun 8, 2024 at 10:49 AM
    #316
    2TunGet1
    Which section did you hang first?
  17. Jun 8, 2024 at 10:54 AM
    #317
    2TunGet1
    Running into an issue. The muffler section is tack welded to the down pipes.
    e30cabrio likes this.
  18. Jun 8, 2024 at 10:56 AM
    #318
    B.Ross
    B.Ross New Member
    Southern Utah
    I hung the muffler first, then pipes. Sprayed some lubricant on the rubber muffler hangers as well.
    Edit to add : looks like a grinder and cut off wheel is in your future.
    e30cabrio and 2TunGet1[QUOTED] like this.
  19. Jun 8, 2024 at 11:00 AM
    #319
    reywcms
    reywcms [OP] New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Grind those tacks off and continue
  20. Jun 8, 2024 at 11:00 AM
    #320
    reywcms
    Rey
    North Plains,Oregon
    I’m glad everyone’s enjoying the system as much as I am!!
    Mdl, e30cabrio, texasrho83 and 3 others like this.
  21. Jun 8, 2024 at 11:04 AM
    #321
    2TunGet1
  22. Jun 8, 2024 at 11:56 AM
    #322
    2TunGet1
    Got everything off. I noticed this metal strip thing on the ground after I pulled the muffler off. I must have been rolling my creeper over it back and forth. What is it? Do I need it?
  23. Jun 8, 2024 at 12:15 PM
    #323
    reywcms
    Rey
    North Plains,Oregon
    That’s the factory exhaust gasket. You shouldn’t need it as the new system has gaskets
    Mdl and e30cabrio like this.
  24. Jun 8, 2024 at 12:25 PM
    #324
    2TunGet1
    Do I reuse the stock bolts or use the included gold ones? Why did they include nuts? The stock down pipes have threads welded on already.
  25. Jun 8, 2024 at 12:54 PM
    #325
    reywcms
    Rey
    North Plains,Oregon
    you can use whichever you’d like. They included them incase the welded units are no good. Also you want to hang the full system loosely and make its all in place etc then tighten all the hardware from the front to the back
  26. Jun 8, 2024 at 1:05 PM
    #326
    2TunGet1
    Im tightening down and it seems like the flanges don’t want to seat together flush like stock. I can still see the silver gasket on the SPD side. Am I supposed to remove the gasket that was in the stock cat side?
  27. Jun 8, 2024 at 1:09 PM
    #327
    reywcms
    Rey
    North Plains,Oregon
    Yes you remove the stock gaskets
    Mdl, ARES35 and 2TunGet1[QUOTED] like this.
  28. Jun 8, 2024 at 1:17 PM
    #328
    2TunGet1
    I tightened down as much as I could. I can still see a slight gap. Is this okay?
    SC_Mike likes this.
  29. Jun 8, 2024 at 1:28 PM
    #329
    reywcms
    Rey
    North Plains,Oregon
    yes that’s ok
  30. Jun 8, 2024 at 2:43 PM
    #330
    2TunGet1
    Got it installed. Love it! Exactly the sound I wanted. Huge thanks to @reywcms for bringing us the discount and helping me through the install. Thank you @B.Ross as well.
    Silver17, Mdl, texasrho83 and 7 others like this.
