How to add LED DRL's to 2014-2017 Tundra with factory amber Drls
Discussion in 'Lighting' started by thomasbus337, Sep 24, 2017.
  1. Jan 28, 2018 at 7:37 AM
    #271
    iHacker
    iHacker SW TRD PRO
    Mario
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    So your truck is a SR5 with Amber DRL right? What did the shop used a fuse tap to make your LED DRL work? Or what kind of harness they used for this, everything is ok with the Ballenger harness problem is with the othe part they used for DRLs
    Y0TA PR0 likes this.
  2. Jan 28, 2018 at 7:56 AM
    #272
    Anakin16
    Anakin16 New Member
    2016 Black Tundra TSS 4x4
    7” BDS lift 20” fuel wheels on 35’s
    Yes my truck is an SR5 with the Amber DRL. I don’t know what they used for the DRL’s Harness. I can see they placed the fuse tap on the wrong fuse slot. So the DRL Harness affects my headlights too?
  3. Jan 28, 2018 at 11:34 AM
    #273
    iHacker
    iHacker SW TRD PRO
    Mario
    Maybe if they wired on the wrong plug, red and pink wires in the Ballenger harness power your DRL strip if they wired different so that might be your problem
  4. Jan 28, 2018 at 11:36 AM
    #274
    iHacker
    iHacker SW TRD PRO
    Mario
    Check the connection and make sure red wire is the only one attached to the fuse tap since your harness is not properly wired for dimming yours will be on High mode all time
  5. Jan 28, 2018 at 12:03 PM
    #275
    Anakin16
    Anakin16 New Member
    So I’m wondering why it worked for a couple of days if it was wired incorrectly. If they wired it wrong should it have not worked at all?
  6. Jan 28, 2018 at 2:39 PM
    #276
    Anakin16
    Anakin16 New Member
    So the pink one should be cut for my application? Did I also need to do the DRL delete mod under the dash (cutting the small grey wire)? On Retrofit wholesale it states it’s required.
  7. Jan 28, 2018 at 3:00 PM
    #277
    sano502
    sano502 New Member
    17 Tundra TRD Pro Cement
    @thomasbus337 or anybody that got these ambers I need help
  8. Jan 28, 2018 at 3:02 PM
    #278
    iHacker
    iHacker SW TRD PRO
    Mario
    Yes to deactivate the Amber DRL gray wire in cab must be cut or get the terminal popped out of the connector, pink wire can be left in place in the Ballenger harness but no other connection going through it
  9. Jan 28, 2018 at 3:11 PM
    #279
    Anakin16
    Anakin16 New Member
    So just so I understand correctly, I need to cut or unpin the small gray wire for my Amber DRL’s in order for my new headlights and DRL’s to work
  10. Jan 28, 2018 at 3:20 PM
    #280
    iHacker
    iHacker SW TRD PRO
    Mario
    The headlights don’t have nothing related to the LED DRL they are powered by the Motocontrol, and gray wire is only to turn off the Amber DRL and doing so you only have the LED strip on you can still leave the gray wire in place untouched but this will leave you with Amber and LED strip at the same time as DRL
  11. Jan 28, 2018 at 3:23 PM
    #281
    iHacker
    iHacker SW TRD PRO
    Mario
    If you paid for the installation best bet is to go back with the installer and have them to do for what you have paid correctly
  12. Jan 28, 2018 at 3:40 PM
    #282
    Anakin16
    Anakin16 New Member
    I am tacking it back, I requested they just put it back to stock. I’m getting refunded by the shop. I’m just gonna have to buy the entire PNP kit so at least I will know everything works together. Then install it myself. Thank you for your help.
  13. Jan 28, 2018 at 3:43 PM
    #283
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Your talking about vleds? I put them on my 18 headlights finen
  14. Jan 28, 2018 at 3:56 PM
    #284
    iHacker
    iHacker SW TRD PRO
    Mario
    When they put everything back to stock do your headlights and turn signals work correctly? Maybe that weird things happening to you were related to where they plugged in the purple wire in your turn signals
  15. Apr 19, 2018 at 11:00 PM
    #285
    yosh2000
    yosh2000 New Member
    Denver
    '17 MGM CM Tundra
    i have a 17 with amber DRL and would like to maintain the amber DRL along with the LED DRL in the 2018 lights.
    am i reading this correctly that i can leave the gray wire connected, do the 1 relay harness and maintain my amber DRL along with the LED DRL. and if i signal, the LED DRL will not blink or anything funky?
    Thanks!
  16. Apr 20, 2018 at 5:05 AM
    #286
    iHacker
    iHacker SW TRD PRO
    Mario
    Yes, a lot of guys left the gray wire under dash in place and the LED strip don’t blink with turn signal just the Ambers
  17. Apr 20, 2018 at 6:55 AM
    #287
    yosh2000
    yosh2000 New Member
    Denver
    '17 MGM CM Tundra
    perfect, thanks for all your help!! i think i finally have a plan for my harness with LED DRL, diode for highs and no motocontrol harness!
  18. Mar 28, 2020 at 10:36 PM
    #288
    Hunkerdown1976
    Hunkerdown1976 New Member
    D
  19. Jun 5, 2024 at 6:30 AM
    #289
    Kataloots
    Kataloots 2014 1794 Edition
    Kathy
    2014 1794 addition
    Tundra grille and Installing Spec-D Tuning LED Sequential Signal Black Smoke Projector Headlights
    I have a 2014 Toyota Tundra 1794 edition and installed the Spec-D Tuning LED Sequential Signal Black Smoke Projector Headlights. I would like to get the LED DRL strip to work. Do you have a wiring harness for these headlights or know what I can do to get them working?
  20. Jun 5, 2024 at 6:39 AM
    #290
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Welcome to the forum.
    According to the website they are plug and play.
    2014-2021 Toyota Tundra LED C-Bar Projector Headlights w/ Sequential Arrow Turn Signals (Matte Black Housing/Clear Lens) - Spec-D Tuning (specdtuning.com)
    Do you have them installed and the big white DRL isn't working?
    It should be getting power from the DRL/turn signal connector..
  21. Jun 5, 2024 at 6:44 AM
    #291
    Kataloots
    Kathy
    2014 1794 addition
    Yes, I have them installed and that connection didn't have anything to connect it too. So I need to find out how to wire it in to get them working.
  22. Jun 5, 2024 at 8:01 AM
    #292
    Kataloots
    Kathy
    2014 1794 addition
    Yes, there was a connection unattached on the headlights. I'm hoping there is a fix for this.
  23. Jun 5, 2024 at 8:06 AM
    #293
    1lowlife
    DADA
    2014 MGM DC SR5
    I responded on your other thread.
    Can you take a pic and post that connection, I didn't see it on their website.
    Please respond in your other thread...
