General Supercharger Thread
  1. Jun 3, 2024 at 7:23 AM
    koditten
    Kirk
    Midland of the Mitten
    Must be a joy to start. I've always hated how loud our trucks are at cold start. The mechanical fan makes a lot of noise.
    Mdl, snivilous[OP] and helidave like this.
  2. Jun 3, 2024 at 7:49 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
    I like this idea without compromising A/C.
    Mdl and Silver17[QUOTED] like this.
  3. Jun 3, 2024 at 8:01 AM
    Jowett
    Jowett New Member
    North Adams, MA
    2011 Regular cab long bed 5.7 Work Truck Package
    Many on the way.
    Have a look at the various front mount heat exchangers Toyota and Lexus use for their newer turbocharged vehicles. Granted, they cool both the intake charge and turbocharger bearings… but simply massive. The unit on my mother’s little 240hp 2.0l NX200T is 27” x 17” x 5/8”. The 300 Series LC and 3rd Gen Tundra show how it’s done with parallel plumbed side mount units, so as not to preheat cooling air for the ac and radiator.
    Perhaps a bit old school, I wouldn’t mind belt driven pump for circulating the coolant. Simple, reliable, and flow that is proportional.
    Saltyhero13, Mdl, e30cabrio and 2 others like this.
  4. Jun 3, 2024 at 8:03 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    belt driven intercooler pump.
    I'd consider that.
  5. Jun 3, 2024 at 8:54 AM
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    I'm surprised more people don't go to electric fans. From all the noise the one on our trucks makes, it must be a ton of drag.
  6. Jun 3, 2024 at 9:52 AM
    Abell207
    Abell207 New Member
    Anthony
    Maine
    2020 Army Green TRD PRO
    I’ve been looking at going the electric fan route. The biggest thing is getting the correct controller to control the fans and when the AC kicks on plus a good shroud for a decent seal.
    Saltyhero13, Mdl and helidave[QUOTED] like this.
  7. Jun 3, 2024 at 10:24 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    It had some traction and a few put them on back in 2012 or so on other forums. They were not reliable as the mechanical fan. I still have the mechanical fan in case. I went a different route when they were selling kits and used the factory shroud with a Lincoln mk8 fan bolted in with a Volvo relay and BMW thermostat. The a/c relay went out and still have to install a new one. It's a Frankenstein build but works.
    Saltyhero13 and helidave[QUOTED] like this.
  8. Jun 3, 2024 at 11:28 AM
    NatesNightMare
    NatesNightMare Is what it is
    Pinetop Az
    What if you were to add an external intercooler much like the turbo systems
  9. Jun 3, 2024 at 11:36 AM
    snivilous
    SW UT
    300k+ Supercharged 2008
    It'd have to go between the blower and heads, so for a setup like ours that packaging doesn't really work. And if you put the cooler before the throttle body, you're not cooling it since that air hasn't been heated up yet.
  10. Jun 3, 2024 at 2:17 PM
    Saltyhero13
    So what you are saying is we need a pre pre cooler?
  11. Jun 3, 2024 at 2:24 PM
    snivilous
    SW UT
    The real answer for intake cooling is nitrous :D
  12. Jun 3, 2024 at 2:37 PM
    blenton
    blenton New Member
    Wait, weren't we just talking about NOT blowing motors up...??
    Saltyhero13 likes this.
  13. Jun 3, 2024 at 2:40 PM
    snivilous
    SW UT
    Just do a little bit to cool the intake charge. In regards to IATs there's probably diminishing returns at some point, so just scoot close to that point and don't enter the part of making mad horsetorques :D
    Fastlane47, Wynnded and reywcms like this.
  14. Jun 3, 2024 at 2:45 PM
    blenton
    blenton New Member
    Sure. Ask us to exercise responsibility, moderation, and restraint... o_Oo_Oo_O :burnrubber::burnrubber::burnrubber::burnrubber::burnrubber::burnrubber::burnrubber::burnrubber::burnrubber:
  15. Jun 3, 2024 at 2:55 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    C'mon man...just a taste...just for the IATs...you know you want it!!! All your friends are doin it!!!
  16. Jun 3, 2024 at 2:58 PM
    bflooks
    bflooks New Member
    Metrowest MA
    Didn't @ViktorG recently share photos of how little impact a <50% water/methanol mixture had while still providing benefit? Asking because the install is rather simple and not very intrusive to the limited space in the nose. Obviously comes with a rather significant sustainment tail, but it's not terrible, especially at the boost levels you guys are looking for the benefits at.
  17. Jun 3, 2024 at 3:10 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Saltyhero13 and HulkSmurf14 like this.
  18. Jun 3, 2024 at 3:24 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    That doubles your area of cooling capacity...it's a great upgrade and even better if you have a larger reservoir tank!
    Saltyhero13 and reywcms like this.
  19. Jun 3, 2024 at 3:28 PM
    e30cabrio
    So, I'm back to wanting a bigger tank?
    :p
    lol
    reywcms likes this.
  20. Jun 3, 2024 at 3:32 PM
    Saltyhero13
    Yes but it was reserved for track use so probably not enough to evaluate long term impact on the rotor coating.
    e30cabrio and bflooks[QUOTED] like this.
  21. Jun 3, 2024 at 6:33 PM
    NatesNightMare
    Pinetop Az
  22. Jun 3, 2024 at 6:37 PM
    B.Ross
    B.Ross New Member
    Southern Utah
    2012 TForce CrewMax 4wd
  23. Jun 3, 2024 at 6:45 PM
    snivilous
    SW UT
    Only if you come wire power to the other half of the shop so I can stop using an extension cord for the machine tools :rofl:
  24. Jun 3, 2024 at 6:49 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Where them new throttle bodies!? lol
  25. Jun 3, 2024 at 6:51 PM
    snivilous
    SW UT
    I was thinking about it. I went to make some bushings and then realized I could sneak in a last minute McMaster order for tomorrow delivery, so bought more delrin instead. And now I'm just sitting here staring out the door debating whether to work on the throttle body or finish welding some shit, or just browse the forums :D
    M3Tundra-JK, ARES35, ZPhilip and 7 others like this.
  26. Jun 3, 2024 at 6:54 PM
    e30cabrio
  27. Jun 3, 2024 at 6:54 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Oh boy! Decisions....decisions haha
  28. Jun 4, 2024 at 7:44 AM
    Vendeta2k
    Jay
    Bozeman, Montana
    2018 Limited Cement CM
    Just got the PSB-1 installed at the local shop. Just curious if these numbers look correct for those of you that have this same gauge? Photo was taken at idle at a stoplight. The highest boost I’ve seen during acceleration is 3.x. Just wondering if everything seems to be calibrated/working correctly? As always any info is greatly appreciated!
    snivilous[OP] and HulkSmurf14 like this.
  29. Jun 4, 2024 at 7:49 AM
    HulkSmurf14
    2014 Tundra Limited
    That's legit...I typically grab 4.6psi max...I have slightly more air with the SABM...that's why you need the Sniv pullies!! And injectors...and....and...lower elevations will net you more boost...
    reywcms, Mdl, snivilous[OP] and 2 others like this.
  30. Jun 4, 2024 at 7:50 AM
    Vendeta2k
    Jay
    Bozeman, Montana
    Thanks for the info! Also updated the post to show the photo was taken at idle at a stoplight
    HulkSmurf14 likes this.
