Anyone use this? Tired of the mess of oil changes
Discussion in '2.5 Gen Tundras (2014-2021)' started by snowball1794, Feb 18, 2024.
  1. May 18, 2024 at 1:50 AM
    #91
    pkeawe809
    pkeawe809 New Member
    PK
    Westside, Oahu
    2018 Super White TRD 4x4 CrewMax
    ~Chrome Delete interior AJT/Tuff skins ~Driver side Grab handle OEM ~Revesol Leather Steering Wheel ~Front Console upgraded to Limited Leather Trim ~Switched Center Instrument panel from silver to black ~Switched black molding trim pieces to Wood grain ~Wood grain Shift Knob ~LED interior lights- meso customs ~Husky X-act Front Driver and Passenger Floor-mats ~Clazzio Seat covers ~Pedal Commander ~Front Windshield heat protection clear film ~VLEDS Footwell LED light kit-driver and passenger sides ~ESP Under Rear Seat storage bins ~4- Door Speakers- JL C1-650 component speakers ~Front Dash Hertz Speakers ~Zapco ST-4X DSP III 100Watt Component Speaker Amp ~Zapco ST-500XM II 500Watt Subwoofer Bass Amp ~1-Rear 10” Subwoofer and Box enclosure ~Sail panel speakers-Hertz tweeters ~Noico 80 mil Sound deadener on all 4 door panels ~Morimoto Headlights-amber DRL ~Diode Dynamics SS3 Pro Foglights ~OEM Tail lights Hot Tails” option A upgrade by Hot Shot Offroad ~Anytime Front and Rear Camera-Trail Grid Pro ~Precision LED lights-rear bed light, lic plate light ~Retrax Pro XR Bed cover ~Auto Rear tailgate lock OEM ~Repaired rust spot and Repainted Roof 7/22 ~De-badged and removed Stickers ~TRD Dual Exhaust w/black chrome tips ~Valhalla Cat Security Shields-Black powder coated ~Black powder coated TRD skid plate ~Red powder coated front Tow Hooks ~Coachbuilder +2 Shackles 1.25” lift ~TRD Pro Grille ~TRD Pro Skid plate ~TRD front/rear Sway Bars ~Bilstein 6112 front shocks ~Bilstein 5160 rear w/resi ~Nitto Ridge Grapplers 35x12.50R17 ~Icon Alloys Rebound Rims 17x8.5 ~Window Tint
    OK, not to sound like an idiot but if I use wheel ramps for the front wheels, will it affect the oil draining out of the pan much? I know it will obviously, but do you think it will be significant? Im a bigger guy and can use whatever clearance I can get.
  2. May 18, 2024 at 4:41 AM
    #92
    bgdv1
    bgdv1 New Member
    Dave
    Butler,Pa
    2019 Limited CMSB
  3. May 18, 2024 at 5:03 AM
    #93
    agrestic1
    agrestic1 New Member
    2016 CrewMax
    AMP Research PowerStep, AMP BedStep Bumper Step, BedRug Carpet Bed Mat, Bazooka Powered Subwoofer Tube
    I've always used ramps or jacked up just the front before I made my ramps . No issue draining the oil. If there was any left in the the pan, it would be insignificant..
    pkeawe809[QUOTED] and Hammerdog like this.
  4. May 18, 2024 at 5:10 AM
    #94
    Hammerdog
    Hammerdog YCMTSUP
    Robbie
    Louisa VA
    2018 tundra sport crew max
    Tint Bed cover Red Tow Hooks TRD Intake 7 inch BDS 22x12’s 35 Toyo’s Rigid ditch lights RC light bar in bottom grille One bad ass stereo
    I use ramps too. Easy peasy.
    pkeawe809 likes this.
  5. May 18, 2024 at 5:30 AM
    #95
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    I use ramps as well. Have changed the oil three times by myself. Takes me less than a half hour and that is with prep and cleanup. I use the fumoto and have rci skids. No issues at all. I order the oil from Costco when they have their rebate - I get 20 quarts for $65…..that’s almost three oil changes (take about 7.5-8 quarts per change). I buy oem filters from the local dealership. The first time I put he o-ring on the wrong part of the housing, started the truck and backed out of the garage while oil was spraying everywhere!!!!! Haven’t made that mistake again - the correct positioning is listed right on the box. I have a backup housing kits in case I crack one.
  6. May 18, 2024 at 6:20 AM
    #96
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    I have a short nipple version with steel RCI skid. Lost one plastic clip in snow and another one in muddy waters. In snow it was a bit scary, because later I found the lever partially disengaged. Fixed the lever with a piece of solid core copper wire now, like 18 or 20 GA.
    coTony likes this.
  7. May 18, 2024 at 6:57 AM
    #97
    coTony
    Tony
    Montrose, CO
    I am not a fan of the plastic piece living in the Arizona heat so I use a pig ring to put in the slot. I was afraid wheeling that a tree branch or whatever debris on the trails could get jammed up in the skid plate and just worried me. The pig rings are thick, solid and will not fall out. I have a tool to help insert and take out when changing oil. call me paranoid but they have been on for 5 years and still holding strong
    jrjordan and vtl[QUOTED] like this.
  8. May 18, 2024 at 7:31 AM
    #98
    Sunnier
    Sunny
    San Diego, CA
    Tony, can you please post a link or a pic of this, for those of us that don't know this term?
  9. May 18, 2024 at 7:39 AM
    #99
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Pig ring?
    Hog ring? :)
    Sunnier and coTony[QUOTED] like this.
  10. May 18, 2024 at 7:41 AM
    #100
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    This is hog rings pliers
    The rings can be round.
    Sunnier[QUOTED] and coTony like this.
  11. May 18, 2024 at 7:57 AM
    #101
    coTony
    Tony
    Montrose, CO
    Pig ring hog ring… you know. I used them to put wire under chain link fence and for barb wire connections to fences when I was in High School. I worked weekends for years before I graduated and the hog rings were what I used. I will take a pic when I get out to the garage
    vtl and Sunnier like this.
  12. May 18, 2024 at 9:13 AM
    #102
    PomDad
    PomDad we having snacks?
    Conrad
    Atlanta
    2021 Cement Limited
    Fumoto sells a lever lock to hold the valve shut instead of using the plastic bit. That's what I use and I need a pair of clamp pliers to get it on and off (it would require a catastrophic failure to come off on its own)
    Here's the link for it - https://www.fumotousa.com/all-products/f-lock.html
    coTony and FrenchToasty like this.
  13. May 18, 2024 at 10:38 AM
    #103
    coTony
    Tony
    Montrose, CO
    Ok, so the F-lock is exactly what I ended up buying a box of and that picture shows exactly what my EZ kit looks like. I just have a rubber cap over the nipple
  14. May 18, 2024 at 10:58 AM
    #104
    shawn474
    MoCo, Maryland
    I haven’t had one issue with my fumoto valve and haven’t been concerned about it opening……but now you guys have me thinking I need the f lock. Damn my ocd…..
    A $2 part with $5 shipping?!?!?!
  15. May 18, 2024 at 11:30 AM
    #105
    Clemsonman14
    Clemsonman14 New Member
    2020 SR5 Crewmax 4x2
    I have the valve but haven’t switched it yet. The valve accidentally opening under some crazy circumstance is my biggest concern. I just bit the bullet and paid the shipping after seeing there is a better lock out there for the valve over the plastic piece
    coTony likes this.
  16. May 18, 2024 at 11:36 AM
    #106
    shawn474
    MoCo, Maryland
    the plastic piece clips and locks in ; I would find it hard to believe that it could be lodged loose unless installed improperly. That said, I may get the f lock just to be sure
    Clemsonman14[QUOTED] likes this.
  17. May 18, 2024 at 1:59 PM
    #107
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    I lost two of them. They are picked up by snow, sand, brushes easily.
    shawn474[QUOTED] likes this.
  18. May 18, 2024 at 2:11 PM
    #108
    Mountaineer
    Mountaineer New Member
    TN
    2019 MGM Platinum
    I've had the Fumoto on other vehicles and currently have the ValvoMax on my truck. I really like its design. It doesn't stick out from the oil pan as much and has a cap on it should the valve fail. If you're worried about the Fumoto accidentally opening (which I don't think is very likely), then you should probably keep the standard plug or go with something like the ValvoMax.
  19. May 18, 2024 at 4:51 PM
    #109
    agrestic1
    2016 CrewMax
    Agree. Very unlikely that the Fumoto valve would open on its own with out the plastic lock... I have the plastic lock. It hasn't come off yet , been on about 3 years ..
  20. May 18, 2024 at 5:42 PM
    #110
    Doxiedad
    Doxiedad Distinguished Member
    James
    Charleston, SC
    2020 Tundra SR5 TRD Off Road Cavalry Blue
  21. May 18, 2024 at 8:12 PM
    #111
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    I remember I once drained the pan and only then figured out there's no beer in the fridge. That was the most awful oil change ever. Ever.
    Gene_in_FL likes this.
  22. May 19, 2024 at 4:23 AM
    #112
    Doxiedad
    James
    Charleston, SC
    Fair point LOL. Though the oil hitting the drain pan and splashing out everywhere is a close second
  23. May 19, 2024 at 4:32 AM
    #113
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
    Doxiedad likes this.
  24. May 19, 2024 at 12:09 PM
    #114
    Bergmen
    Bergmen New Member
    Ukiah, California
    I use a 5 gallon bucket (made for oil changes) with the front wheels on ramps. Never spilled a drop.
  25. May 19, 2024 at 12:13 PM
    #115
    Bergmen
    Bergmen New Member
    Ukiah, California
    That's gotta be a first. Since about 1970, I've always had beer in the fridge. Often, no food (when I was dirt poor), but ALWAYS beer.
    Hammerdog and vtl[QUOTED] like this.
  26. May 19, 2024 at 9:13 PM
    #116
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    It’s moments like this that I’m reminded why I have a 50L Dometic fridge permanently mounted in the bed of my truck. I haven’t shut it off in years, and there’s never not beer in it. Just in case.
  27. Jun 4, 2024 at 6:54 AM
    #117
    Rockpig
    Rockpig You did what?
    08 Limited
    So the valve with the hose end is $40.83 Amazon.com: EZ-103(12mm-1.25) EZ Oil Drain Valve with removable Hose End Combo : Automotive
    The valve alone without the hose end is $21.80 Amazon.com: EZ-103 EZ Oil Drain Valve : Automotive
    The hose end is $7.62 Amazon.com: EZ Oil Drain Valve (H-001) Straigt Hose End - 3/8" Straight, Small, Silver : Automotive
    So to buy them separately instead of together as a kit the total is $29.42, a savings of $11.41, use that savings to buy 3/8 hose to go on the end of the drain or better yet if you're worried about the drain lever being hit by something causing it to open get this, better than the wire ring clamp. $6.99
    The Hillman Group 59737 11/16-Inch Spring Action Hose Clamp, 12-Pack - Amazon.com
    Silicone hose $5.99: Amazon.com: Rebower 1m(3.3ft) 10mm(3/8") ID x 13mm(1/2") OD Silicone Tubing Clear Industrial Plastic Tubing Pure Silicone Hoses for Pump Siphoning Draining Irrigation Brewing : Industrial & Scientific
    Get these 4 items together instead of paying $40.83 for the drain and hose end together and it's $42.40, a whole $1.57 more and all you need is a pan to drain the oil into.
  28. Jun 6, 2024 at 6:14 AM
    #118
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I don't use ramps. A pair of 2x6s screwed together gives me the clearance I need.
