  1. Jun 3, 2024 at 1:31 PM
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    I'm jealous! I keep meaning to camp one of these weekends but keep deciding to finish off truck projects first. "Get them all done then you'll have the whole summer!". Deadline is the last weekend of June when there's a big campout bluegrass jam I go to with the camper. I will be ready by then.
    And I went ahead and ordered a new wiring harness and 4 to 7-pin adapter for the Tundra. Somewhere in the system the driver side blinker has failed and I'm sick of trouble shooting. Don't like throwing money at things rather than doing the work to track down the actual problem, but 99% chance the problem is in the aftermarket wiring. Too many reviews of trailer wiring harnesses say "works great for 2 years"...Mine is almost definitely original from '02.
    I think I effectively ruled out the trailer wiring.
  2. Jun 3, 2024 at 1:32 PM
    VR6T
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
    This is also a thing now.
    @JakeJake I have every intention on rewelding that hook in and reinforcing the rest of the welds.
    Mr.bee likes this.
  3. Jun 3, 2024 at 1:33 PM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    Shiiiit
    artsr2002 and VR6T like this.
  4. Jun 3, 2024 at 1:34 PM
    VR6T
    Funny I was pointing shit out to my nephew in the store and that little shit said just that, crossed his eyes and everything. Lmfao
    I mean it's all machine welded, I'd just feel better with two more covers on each of the balls, and the hook welded all the way around.
  5. Jun 3, 2024 at 2:55 PM
    VR6T
    I did this as well
  6. Jun 3, 2024 at 2:59 PM
    Chrisfrom1986
    Chrisfrom1986 New Member
    Central CA
    06 AC SR5
    So why didn't you buy Toyota?
  7. Jun 3, 2024 at 3:00 PM
    VR6T
    Cause I did all of that work before 1 I knew about this forum and 2 before I learned moog isn't the moog I grew up with.
  8. Jun 3, 2024 at 3:05 PM
    #teammoog #unlikelysurvivors #dangerbros
  9. Jun 3, 2024 at 3:08 PM
    VR6T
    They're now own and manufactured by a Chinese investment firm. All their ball joints, all of them and anything that takes a ball joint, is no longer an all metal construction; but now uses a low density plastic socket liner and the cheapest rubber possible
    oscardog86 and Jack McCarthy like this.
  10. Jun 3, 2024 at 3:23 PM
    metalpete
    metalpete New Member
    ID
    2001 Tundra 4.7 4x4 SR5
    Toytech 2.0 Coilovers Camburg UCA's JBA headers Dynomax cat-back exhaust 90-221HD Leafs
    You'll be there soon enough! Did you order 08921-34850 *pushes up nerd glasses*
    I'm feeling confident that replacing the breakaway module fixed my latest electrical woes, but there isn't a piece of wood big enough I could knock on right now...wait a minute...
  11. Jun 3, 2024 at 3:27 PM
    Chrisfrom1986
    Central CA
    06 AC SR5
    Still doesn't tell me why you ordered Moog again
  12. Jun 3, 2024 at 3:51 PM
    Now you can swap out the Moogs under their limited lifetime warranty and pay it forward by donating them to someone else.
  13. Jun 3, 2024 at 4:04 PM
    Damn dude, go easy. It's his life.
  14. Jun 3, 2024 at 4:06 PM
    I believe @VR6T ordered Detroit Axle tie rod ends as a replacement, not Moogs.
    BroHon, VR6T and FrenchToasty like this.
  15. Jun 3, 2024 at 4:27 PM
    VR6T
    I did I did
  16. Jun 3, 2024 at 4:29 PM
    VR6T
    Lol
    oscardog86, Voss and FrenchToasty like this.
  17. Jun 3, 2024 at 4:52 PM
    MT-Tundra
    Montana
    Well my impulsiveness and lack of research does it again. I didn't realize Toyota made an adapter. And for less than I paid! But what I ordered will do the trick. I don't remember what I bought for my Tacoma, but I got them off etrailer, and they've lasted 9 years.
  18. Jun 3, 2024 at 5:06 PM
    VR6T
    Why would anyone in their right mind ordered part that failed them?? And how did you even come to that conclusion?
    455h0le_dachshund likes this.
  19. Jun 3, 2024 at 5:07 PM
    VR6T
    Lol yeah pay it forward with Moogs is like saying, "hey there buddy, fuck your truck" lol. I would never
    Also they don't have a life time ware tee anymore it's failure inside 3000 miles, which with my ball joints we found out isn't true
  20. Jun 3, 2024 at 5:21 PM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    Spindle gussets showed up. Probably going to keep stacking parts and wait till I install LT. Right now the truck boogies for what it is.
  21. Jun 3, 2024 at 6:25 PM
    Chrisfrom1986
    Central CA
    06 AC SR5
    Right and it has a generic moog/duralast part number and says made in china. Just curious as to why he would continue to buy the same junk instead of buying Toyota when he knows better.
    des2mtn, oscardog86, shifty` and 2 others like this.
  22. Jun 3, 2024 at 6:45 PM
    BroHon
    BroHon Bitch in the Mitten
    Bro
    2000 SR5 AC 4x4 4.7
    Sketchy street barnacle
  23. Jun 3, 2024 at 6:52 PM
    metalpete
    ID
    Oh okay. I almost bought that curt kit, too. Looks simple. You're basically just replacing toyotas converter and downstream wiring to the 4way. Fingers crossed it does the trick for you!
  24. Jun 3, 2024 at 7:01 PM
    VR6T
    Do you have an idea of how much stuff is made in China. 90% of what you consume every day is made in China or has products or parts globally sourced from China to make it.
    With that said seeing as apparently you just don't understand stuff. Some things are made to a higher standard at a different factory. These are not moves they're not duralasts. Detroit Axle has an exceptionally good reputation for their parts. The stampings probably came from China and then it was probably finished being made here in the United States on assembly line.
    So here's an idea just click on my profile name and block me because I've determined from this interaction that you're just a jackass that has never had his teeth knocked in. And it clearly shows.
    Start paying mine and or any of our weekly salaries and then you can dictate what brands of parts we buy here.
    MT-Tundra likes this.
  25. Jun 3, 2024 at 7:05 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Interesting, Why wouldn't they repackage them in their own branded bags.... esp since Moog has turned to shit.
    edit: I kinda get it.
  26. Jun 3, 2024 at 7:06 PM
    VR6T
    IDK I'm not that company
  27. Jun 3, 2024 at 7:10 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Yeah but do you even get a chance to drive your truck with all your jetsetting?
    FrenchToasty and Jack McCarthy like this.
  28. Jun 3, 2024 at 7:10 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Hey, I don't even have a cotter pin on one (might even be 2) of mine.... If I can barley get shit loose with a fkn torch they aint goin nowhere. Because salt :rofl:
    Jack McCarthy and VR6T like this.
  29. Jun 3, 2024 at 7:13 PM
    About 2500 miles a year or so
  30. Jun 3, 2024 at 7:14 PM
    Headed to Austin in the morning btw
