Upgraded Alternator Question
Discussion in '2.5 Gen Tundras (2014-2021)' started by SpottedDog, Jun 1, 2024.
  1. Jun 1, 2024 at 9:24 AM
    SpottedDog
    SpottedDog [OP] New Member
    G
    Moab, UT
    2017 TRD OR
    Old Man Emu heavy 285/75R18 Toyo AT3’s
    My truck is also my office and seasonal housing. I’m field biologist and spend months on the road and living out of my rig and OVRLND camper.
    It’s setup with 200w of solar, 2000w inverter and 200ah LiPo batteries. All Renogy.
    When I’m running down the road and the ‘house’ system is charging off the alternator, my starting battery hovers at 13.1v.
    When it’s only charging via solar the starting battery is between 13.6-8.
    I’m wondering if I’m stressing my 2017 5.7’s w/ tow package charging system. Would I benefit from a higher power alternator from Tuscon Alternator or other company?
    Are they any dangers to my trucks overall health by using or not using a higher powered alternator?
    Wallygator likes this.
  2. Jun 1, 2024 at 9:36 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    How are you charging the battery off your alternator? Using a DC-DC charger for the lipo? I thought with those you can adjust the draw off the charging system/battery.
    Seems like an alternator upgrad would probably be a good idea, but you'd really have to crunch the numbers if its worth it to add a few extra hundred amps of charging. I dont remember reading about many people that have used HO alternators but i think @1UPPER had a Mechman Alternator, but i could be wrong.
  3. Jun 2, 2024 at 7:15 AM
    SpottedDog
    G
    Moab, UT
    2017 TRD OR
    It’s a DC- DC charger. I can’t adjust the draw, I don’t believe. It’s “smart”…
    I don’t mind spending the money on my work rig, I’m more concerned about whether or not a HO alt could/would, in some way, harm the charging systems long term health.
    Since this is my work rig, I just need thing to be as reliable and problem free as possible. Especially after last weeks left-rear wheel bearing debacle (Codes CO215 and OU129) that stuck me with a rental car and hotels while the dealer waited for parts….
  4. Jun 2, 2024 at 8:02 AM
    Danimal86
    Daniel
    Sacramento, CA
    Ohh dang.
    If you are able to consistenly have sunlight, i'd focus on solar.....but if not, you can get a 370a alternator for about $600
    https://www.mechman.com/2007-2021/
    I haven't read about many people that have added HO alternators, but i image that it would be just fine.
    I thought about going the HO route and just using it as generator for our travel trailer, but went a different route.
    AstroDude and 2mchfun like this.
  5. Jun 2, 2024 at 8:21 AM
    Dawoofles
    Dawoofles New Member
    Cheyenne, WY
    2021 Cement Tundra SR5
    TRD rear sway bar, SS3 Max Amber Fog Lights, Carthartt Seat Covers, Morimoto LED interior lights, Ihacker LED Headlights swap, Driver Side Grab Handle, Husky Floor Liners, Weathertech full SunShade, Cat Back Stainless Works Dual Exhaust, OEM metal Oil Canister, Bed Mat, Deck Rail System, OCD Center Console, Full RCI skid Plates(Engine,Transmission, Cat Guard, and fuel tank), 12” Fi Car Audio Neo 3.5 Subwoofer, Gately Box, Rear seat delete, Sundown Audio Salt 2 Amp, Stereo Integrity front stage, Pioneer DVD/CD/wireless Apple CarPlay Receiver
    2mchfun likes this.
  6. Jun 2, 2024 at 8:28 AM
    2mchfun
    I think @Cruzer runs this or similar
  7. Jun 2, 2024 at 8:38 AM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Yeah I’ve got this one. Works great with stock belt and never had issues with it.
    reywcms and 2mchfun[QUOTED] like this.
  8. Jun 2, 2024 at 11:45 AM
    Kenny1794
    Kenny1794 New Member
    I have a DC power 270amp alternator with gm upgrade... I love my alternator I needed it for my audio system. If u do decide to get one replace your belt when I got mine put on my belt squealed because it was old..... They also have an option to get a slightly smaller pulley for slightly more amperage @ idle.... All in All I love my dc power alternator...
    SpottedDog[OP] likes this.
  9. Jun 2, 2024 at 11:49 AM
    meagain
    meagain New Member
    I just picked up a new AGM (EverStart Platinum from Walmart). Can you explain to me the GM diode? What it does? Do I NEED it? What am I facing if I don’t have one? Thnx!
  10. Jun 2, 2024 at 11:54 AM
    Danimal86
    Daniel
    Sacramento, CA
    So the 5.7 with the tow package is 170a alternator?
    Now i'm tempted to upgrade to upgrade.
    Y0TA PR0 likes this.
  11. Jun 2, 2024 at 12:14 PM
    Pmac
    Pmac New Member
    South of Portland, OR
    2019 CrewMax TRD Off-road
    I thought the tow package was the 150 amp alternator vs 100 or 130 amp otherwise. But I could be all wet.
  12. Jun 2, 2024 at 1:27 PM
    Jowett
    Jowett New Member
    North Adams, MA
    2011 Regular cab long bed 5.7 Work Truck Package
    Many on the way.
    Tow pack Tundra is 150 amp, Sequoia and Land Cruiser w/ 5.7 receive the 180 amp.
  13. Jun 2, 2024 at 2:43 PM
    Kenny1794
    The gm upgrade are good for charging agm batteries being though they like between 14.4 and 14.8volts.... Having an agm is good to.
    There's another option along with the h/o alternator u can get a limitless retro 56 battery instead of a agm but the lithium is a bit pricey.....
  14. Jun 3, 2024 at 12:27 PM
    SpottedDog
    G
    Moab, UT
    2017 TRD OR
    I’ve got a Voltage Booster Pro on the way. We’ll see how that does before I pony up for an alternator.
    Thank y’all for all the advice!
  15. Jun 6, 2024 at 4:57 AM
    thealey
    thealey New Member
    Tyler
    Port Orange,FL
    2017 Toyota Tundra SR5 CrewMax XSP
    Build List: https://1drv.ms/b/s!Aq_KNysdW_0UmkIDSo7_prq_6418
    Ive got the voltage booster bro and it’s done everything I need so far. I don't have any crazy audio, just the OEM Audio plus w/dual subs. Hoping to redo it in the future so I might need a HO alt when I get to that. But the voltage booster pro is simple and effective for right now.
