Airbag code B1 905
Discussion in '1st Gen Tundras (2000-2006)' started by limited4.7, Jun 1, 2024.
  1. Jun 1, 2024 at 8:04 AM
    limited4.7
    limited4.7 [OP] New Member
    2005 Gray Tundra Limited
    Stock
    I have been looking everywhere for a fix to my airbag code. I only have the code b1 905 and I wanted to know if anyone out there has had this problem and knows the solution. Anything helps thank you!
  2. Jun 1, 2024 at 8:12 AM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Has the truck ever been in an accident ?
  3. Jun 1, 2024 at 8:14 AM
    limited4.7
    Stock
    yes it has, idk anythuing about the accident all ik is that its a salvage title that I'm trying to fix up
  4. Jun 1, 2024 at 8:37 AM
    jerryallday
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    That code is for the passenger side seat, seatbelt, seatbelt retractor area I believe. Try checking all the airbag connections under the seat and on the door.
    im guessing it’s the seatbelt retractor was never replaced or fix after the accident
  5. Jun 1, 2024 at 8:55 AM
    limited4.7
    Stock
    Thanks for the info. Let me go check it out when I can. Btw where did u go to see the codes and what the problem/solution is?
  6. Jun 1, 2024 at 9:05 AM
    jerryallday
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Just googled B1905 Toyota, you might have been looking up B1(space)905
