I'm being intimidated by head gasket and camshaft removal
Discussion in '1st Gen Tundras (2000-2006)' started by USERidiculousNAME, May 30, 2024.
  1. May 30, 2024 at 12:58 PM
    USERidiculousNAME
    USERidiculousNAME [OP] ToyTurd
    Josh
    New Orleans
    250K on Early 2004 tundra DC 4.7 v8, SR5, RWD, A/T, LSD, w/ABS,TOW, OFF ROAD, ZERO RUST FRAME, BILSTIEN 5100, AAL, 17" 265/70
    Backup camera, camper shell, double din stereo, amp, sub, blind spot cameras, modest lift, newer Tacoma rims, large AT tires, interior lighting upgrades, in bed, under hood, as well as leds in cab, blue foot well strips (night driving)or bright white strips if need to see, 3 additional white leds on ceiling front L/ R and center, toggle switch's and added accessory fuse box.
    How to remove camshaft for head gasket replacement. I'm feeling this is beyond my skill level I can't find information on line and don't fully trust Haynes manual not to mention it seems a little vague on the subject anyways. Install bolt , then remove im sorry but how would I remove it if I bolted it in, I've never owned a clean engine anyways. Think I should stick with water pump and timing belt cam seals pre vvt and just start putting it back together
  2. May 30, 2024 at 1:07 PM
    2mchfun
    Buy a factory service manual, bought mine on ebay.
  3. May 30, 2024 at 1:35 PM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    Riverdale21, FrenchToasty and 2mchfun like this.
  4. May 30, 2024 at 1:38 PM
    Surprised the cam has to come off for head gasket replacement
  5. May 30, 2024 at 4:16 PM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Your engine is close (if not identical) to the 2003, so that FSM is appropriate for your head removal/replacement.
    2mchfun and JakeJake like this.
  6. May 30, 2024 at 6:23 PM
    JakeJake
    2000 Tundra AC 4X4
    yeah, I found this odd too, but admittedly I haven't been into a 2uz yet.
    After some brief looking the Headbolts are blocked by the camshafts.
    Here's a good shot with the camshafts removed revealing the 10x headbolt locations.
    No way your getting to those with the cams in.
    This probably doesn't bode well for @USERidiculousNAME if this is his first head gasket job.
    Also I have never really heard of a 2uz with a bad head gasket. Not saying it doesn't happen, but what makes you think this is the case?
    shifty`, 2mchfun and FrenchToasty like this.
  7. May 30, 2024 at 7:03 PM
    2mchfun
    My best guess is she got too hot, iron block, aluminum head.
    JakeJake[QUOTED] likes this.
