No Right side trailer turn / stop. Need a Cluster
Discussion in '2.5 Gen Tundras (2014-2021)' started by Pete2021, Apr 19, 2024.
  1. May 16, 2024 at 5:55 AM
    Pete2021
    Pete2021 [OP] New Member
    Pete
    2021 Tundra Sport
    my truck is the 2021 sport premium.
    Im trying to search other trims to see if I can see what options that cluster came in.
    2mchfun likes this.
  2. May 30, 2024 at 2:19 PM
    Pete2021
    Pete
    2021 Tundra Sport
    New used cluster fixed the issue.
    Found a used part for $350 exact same part# and trailer right side is working properly again. decided to replace the 30amp fuse with a 15 amp fuse.maybe that will protect the circuit if I plug in to a shorted trailer.
    Thanks Pete.
    Tunrod, RainMan_PNW, lerbud1 and 2 others like this.
  3. May 30, 2024 at 3:00 PM
    2mchfun
    Screenshot_20240530-171025.png One could always add inline fuses for each trailer wire. Something like this might be the answer to prevent blowing the cluster.
    Pete2021[OP] and 1lowlife like this.
  4. May 30, 2024 at 3:14 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Glad you got it fixed.
    Perhaps your thread will help someone out in the same situation..:thumbsup:
  5. May 30, 2024 at 7:47 PM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    What did you do to get the odometer correct?
  6. May 30, 2024 at 9:00 PM
    Pete2021
    Pete
    2021 Tundra Sport
    the odometer is a problem. truck has 90k km on it. new od reads 13k km I'm thinking it's a dealer only re programing. was thinking the pcm would display the logged km, but the memory is in the cluster?
  7. May 30, 2024 at 10:02 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    You correct that the odometer has to be reset at the dealership. You might want to get in touch with them. Your probably going to have a problem when it comes time to renew your registration and have to disclose the odometer reading. Definitely don't through the old cluster out.
  8. Jun 2, 2024 at 8:00 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Not sure that most dealers can even do that without sending it out to be programmed. When I did the optitron swap in my 2008, none around here could do it. One of them finally gave me the name of a business that could do it, but they couldn’t do it in house.
    And record the exact mileage that was on the old one when you took it out (picture is even better) and the exact mileage on the new one when you put it in. That way you have record of the difference. There’s technically (at least down here) a legit way to record that and fix it to the vehicle B-pillar by the VIN sticker to be considered “legal” (i.e. not falsifying the mileage).
    1lowlife and 2mchfun like this.
  9. Jun 2, 2024 at 9:01 AM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    The dealership can correct it. Only a Toyota master tech can do it. When I was at the dealership I watched the master tech perform an instrument swap and correct the mileage. It requires a call to Toyota for security reasons. I'm in Ontario and I know the problem is that when the vehicle goes through a safety check which is required when a vehicle changes ownership, the odometer reading for the instrument cluster has to be recorded on the safety check paperwork. You should make a call and see what is required just to make sure.
    RainMan_PNW[QUOTED] and 2mchfun like this.
  10. Jun 2, 2024 at 10:02 AM
    RainMan_PNW
    Casey
    Clark County, WA
    Would love to have been able to figure out how to do that with techstream… a hell of a lot easier than pulling the coaster apart and hooking up an EEPROM read/writer to the solder leads on the PCB. :spy:
    2mchfun likes this.
  11. Jun 2, 2024 at 11:44 AM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Yeah but it's not going to happen because of the security for good reason but like you mentioned there is other options. Just got to know "a guy".
  12. Aug 22, 2024 at 11:04 AM
    cmcstotts
    cmcstotts New Member
    2019 white tundra TRD Crewmax
    I took my 2019 tundra in for no left blinker issue. They told me the cluster and that it was probably caused by short in my trailer. This is a bad design if the circuits are not fused protected. It has a 30 amp fuse but that does not provide adequate protection if the cluster fries before the fuse. I guess I will fuse all of my circuits on each trailer I own.
  13. Aug 22, 2024 at 11:59 AM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    Damn! now I'm going to be scared shitless everytime I plug in a trailer:(
    Awesome thread!
    Ruggybuggy likes this.
  14. Aug 22, 2024 at 12:19 PM
    cmcstotts
    I know!!
    I just ordered some weather proof inline fuses to put on my trailer. I was surprised that the truck circuits were not protected any better than that.
    Tunrod likes this.
  15. Mar 29, 2025 at 11:54 AM
    Elfie101
    Elfie101 New Member
    2018 Tundra
    car-part.com shows 18 different clusters for my 2018 SR5. Same problem with my right and left turn signals.
