Double cab rear door opening
Discussion in '1st Gen Tundras (2000-2006)' started by Kimosabe, May 28, 2024.
  1. May 28, 2024 at 7:18 PM
    Kimosabe
    Kimosabe [OP] Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    I have upgraded (yes a double cab is an upgrade) to a double cab and it feels like the rear doors don’t open as wide as they could or should.
    I’m curious if anyone else has noticed this and if anyone has upgraded the door check to allow them to open wider?
    artsr2002 likes this.
  2. May 28, 2024 at 7:46 PM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    They definitely don't open to a full 90*
    FrenchToasty and Weagle like this.
  3. May 28, 2024 at 10:47 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Disconnect the door check at the cab end and open the door as far at it will go without causing any damage and see if you can find a longer door check. If you find one, let us know. They open wide enough for me.
  4. May 29, 2024 at 4:56 AM
    Weagle
    Weagle I survived my timing belt change
    Prattville, AL
    2006 Tundra SR5 DC 4.7 2WD LSD towing pkg
    Bilstein 5100's with 2883's - close to 2" Replacing the 2883's and going back to the bottom perch ASAP -mobile/apple play stereo with sub and backup cam -Power stop HD front calipers and rotors for towing -20" wheels with 32" tires (305/50's) Toyo AT 3's with no rubbing -Westin nerf bars -Detroit axle new (not rebuilt) steering rack with poly bushings, inner and outer TRE's -Suspension Maxx extended front sway bar links -Overland tuning - medium level -Power front leather seats and steering wheel from 06 Sequoia -fully de-chromed/blacked out trim -all light housings incl 3rd brake light and tag lights replaced with smoked lenses, LED where appropriate -mini projector headlights -fully rebuilt trans and new torque converter -new complete drive shaft with spicer u-joints and carrier bearing -all LED interior lights including backlighting -new lower window seals for all 4 doors -all new hardware and clips for tailgate Next: Dirty Deeds racing exhaust with LT headers, yellow box, 12 hole DD fuel injectors, redo or replace door panels
    Are there heavy duty Door checks that work for these trucks?
    I read a post sometime back where somebody modified Another check to work on this truck. Sure would be nice to have better ones.
    My front driver door had to be welded with a little fabrication to repair it after my door check went bad. I guess these could've potentially prevented that:
    HBTundra likes this.
  5. May 29, 2024 at 7:21 AM
    FishNinja
    Lee
    06DC2wd
    I wanna say it was a titan?
    Weagle[QUOTED] likes this.
  6. May 29, 2024 at 7:23 AM
    noahrexion
    noahrexion New Member
    Washington
    2005 4WD DC
    I think it was a early 90's Camry that worked.
    Weagle and The Black Mamba like this.
  7. May 29, 2024 at 7:28 AM
    The Black Mamba
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
  8. May 29, 2024 at 7:52 AM
    artsr2002
    'Yonder
  9. May 29, 2024 at 9:49 AM
    Kimosabe
    Sun Valley, Idaho
    I'll have to play around with it. I would love the doors to open to 90*. The rear driver side needs replacement, so maybe I'll play around and see if there is another part that will work and allow the door to open further.
    I like the camry idea. I also thought about Sequoia or 4runner rear door, but maybe I'll order a few and try them out.
  10. May 29, 2024 at 9:50 AM
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    I've been eyeing those for a while for my DC.
    My doors are in fine condition . . . I was considering them for 'preventative' maintenance.
    I haven't searched on here for reviews, installs, thoughts, etc , but it seems like a good concept.
    Any feedback would be welcomed.
  11. May 29, 2024 at 10:01 AM
    Kimosabe
    Sun Valley, Idaho
    They aren't too pricey. I'm considering them as preventative too. My son is only 1 right now, but I'm sure in about 4 years he'll be slinging doors open and slamming them.
    Weagle likes this.
  12. May 29, 2024 at 10:19 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    I've had them for quite awhile now as preventative maintenance. Nothing bad to say about them. Install is not very intensive, with only three bolts per door. Should only take a couple of minutes to do each one.
    Weagle and HBTundra[QUOTED] like this.
  13. May 29, 2024 at 12:31 PM
    And it doesn’t stop for a long time. I finally got the 13yo to remember 90% of the time. The 11yo hasn’t gotten there yet. I try and drive the Highlander with them as much as possible.
  14. May 29, 2024 at 12:47 PM
    I cringe when my youngest opens the car doors because he isn’t tall enough to pull straight out, it’s a very sharp downward angle he’s pulling at them
    shifty`[QUOTED] likes this.
  15. May 29, 2024 at 12:54 PM
    noahrexion
    Washington
    2005 4WD DC
    "Son, you have to pull UP and back at the same time"
    shifty` and FrenchToasty like this.
  16. May 29, 2024 at 1:15 PM
    That’s tough when they’re not tall enough. My 11yo has so much trouble with the back door specifically and I cringe every time.
  17. May 29, 2024 at 2:39 PM
    FishNinja
    Lee
    06DC2wd
    Tell them instead of "hand over the handle" go with the "hand under the handle" it'll facilitate the upwards pull you're looking for
  18. May 29, 2024 at 2:55 PM
    Thanks, I’ll try that!
  19. May 30, 2024 at 12:58 AM
    artsr2002
    'Yonder
    Y'all be jelly of my Ferd Supercab suicide doors. They open all the way back against the bed. LOL :D
    Just like this.
