Door check problems
Discussion in '1st Gen Tundras (2000-2006)' started by slowdisco, Sep 27, 2018.
  1. Aug 4, 2021 at 7:25 AM
    matt kruckenberg
    matt kruckenberg New Member
    slc ut
    2015 Trd Pro Inferno
    ive replaced mine two times driver door i have a 1015
    des2mtn likes this.
  2. Aug 4, 2021 at 9:01 AM
    RR60
    RR60 New Member
    2003 SR5 Tundra long bed
    Lets us know how it works out. And if seems just as good as OEM. Hopefully even a little stronger. I always found the door checks to be one of the few weak parts on a Tundra.
  3. Aug 4, 2021 at 5:12 PM
    Wahoo155
    Wahoo155 New Member
    Lee
    Southside Virginia
    2008 Salsa Red
    Check out Timmy the Toolman Toyota video from YouTube. I installed the kit from Russia on the rear doors on my 2002 Sequoia. The doors would flop open or closed before the install and now the doors will hold open on a hill.
    https://youtu.be/u2LCa9WRYe0
  4. Aug 5, 2021 at 8:10 AM
    Bearbrew
    Bearbrew New Member
    Ben
    2000 Tundra 4X4
    Replaced the drivers door door check repair kit yesterday. I added the two thin shims and now the door takes some effort to open and close. Hopefully the new parts will wear in and be a little easier to open and close. It sure beats the door closing on you. After the door panel was removed I removed the door speaker for easy access. When I drilled out the spot welds I started with a smaller drill and kept stepping up to a large bit until most of the spot weld was removed. Then it was easy to get the two pieces apart. You need to pay attention when removing the old wear block and rubber block so everything goes back in correctly. When replacing the cover I found a pair of Channel Lock pliers were a big help to force the blocks back into position after I had gotten them started with a small screw driver. The parts are a really tight fit. Yes, it was a little extra work taking the door check apart, but $25.00 for the kit for 4 doors is a heck of a lot better than $40.00-$50.00 each for new checks. I am going to wait a few weeks to see if I need to add the thin shims to the other doors.
  5. Aug 7, 2021 at 3:45 PM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    Alright, got them installed. They do fit and only take a slight modification. The OE ones have the bolt tack welded to the body, the Camry ones just have open holes. I have an nut and bolt assortment from harbor freight and the 8mmx1.0 bolts threaded right into the body of the new ones. The OE nuts were the same thread pitch so they snugged right up.
    Now, how do they work? For $12, I’m not complaining. My original ones were so bad, they would close themselves on level surfaces, no joke. They now will stay open on their own, on flat surfaces. That’s about where the good stops. I parked on a few inclines and they still will shut on their own. It did fix my immediate problem of shutting on flat grounds but I think I’ll still by that $30 Mother Russia kit and rebuild my OE ones. To use that kit, you’ll have to cut the tack welds off to open them up. Any questions, feel free to ask.
  6. Aug 8, 2021 at 6:59 PM
    SouthPaw
    2000 Limited 4x4 AC
    The more I look into this, the more I think these things are universal. I looked at the old ladies 2014 GMC Terrain and I’m almost certain hers would fit my tundra. I think as long as they have two bolt mount and the third eyelet at the end, they would fit.
    GMC Terrain Door checks
    I
    did order the mother Russia kits so I will rebuild my old ones. I watch that YouTube video posted and they seem to work solid. I can’t wait to have this problem finally fixed.
  7. Aug 9, 2021 at 8:56 AM
    Bearbrew
    Bearbrew New Member
    Ben
    2000 Tundra 4X4
    Finally got all my door check repair kits installed and everything back together. When I rebuilt the passenger front door I noticed the arm on the door check was about an inch shorted than the drivers door, door check arm. Have no idea what the difference in length is for. Had to get up early and get a door finished before the mosquitoes woke up to attack me. Some of the photos of after market arm I noticed different length than the original. To be on the safe side I would make sure the door check stopped the door when opening before the door hinges stop the door. Using the door hinge for a stop would put a lot of wear and torque on the hinge.
    SouthPaw likes this.
  8. Aug 21, 2021 at 3:10 PM
    SouthPaw
    2000 Limited 4x4 AC
    Got mine put in today and they kick ass. Here is the full post in my build thread:
    https://www.tundras.com/threads/southpaw’s-2000-tundra-limited-4x4-build.53510/page-5#post-2373460
    Some tips for anyone that is going to use the same kit. Watch that video Wahoo posted, its spot on. Also read the directions from the ebay link as they are actually pretty good and show pictures on how to insert them.
    Tools needed:
    Phillips screw driver/bit
    T27 Torx
    Trim panel tool
    Vise
    Dremel with cut off wheel
    Drill with various sizes of small drill bits
    10mm, 12mm sockets/ratchet
    bmf4069 and daveeasa like this.
  9. Aug 23, 2021 at 12:23 AM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
  10. Aug 23, 2021 at 2:17 PM
    SouthPaw
    2000 Limited 4x4 AC
    Both can be used on either door. On one side it is stamped "LR" for left front but if you flip it over, it says "FR."
  11. Aug 23, 2021 at 9:23 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Gotcha. But they are the same length for sure
    SouthPaw[QUOTED] likes this.
  12. Mar 11, 2022 at 12:52 AM
    migx333
    migx333 New Member
    Reviving this thread.
    Due to the war, that same seller from Russia isn't in business anymore. Probably because no goods can come in from Russia.
    Does anyone have another seller or source for this door repair kit?
  13. Mar 11, 2022 at 5:54 AM
    shifty` You can call 1 (800) PP5-1-DooDoo
    Just buy it from scAmazon, search for B098QXKQZ6 and you'll find it quite easily.
    WFD473 likes this.
  14. Mar 11, 2022 at 9:14 AM
    Teutonics
    Teutonics BestGen Member
    2005 DC SR5 4WD
    Thanks for this... it's been on my long-term list (once I get the big stuff done), but went ahead and ordered while they're available. I did notice that the Amazon kit does NOT include the graphite lube that is mentioned in the other kits and in the linked youtube video. I'll plan to use Slip Plate or some other graphite or dry lube instead.
    Since they're for multiple Toyota models, the Tundra guys may want to get them while they can still be had.
    shifty`[QUOTED] likes this.
  15. Mar 24, 2022 at 8:14 PM
    zech
    zech New Member
    2006 Maroon Tundra 4WD DC
    I tried searching for this, but nothing. Did you have a different result?
  16. Mar 24, 2022 at 8:20 PM
  17. Mar 24, 2022 at 10:38 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
  18. Mar 24, 2022 at 11:27 PM
    zech
    zech New Member
    Reading the comments and questions/answers, it seems their selection is smaller than before. They should have a Type 1 selection, but they do not. I suspect it is due to low supply and the war. Their Type 2 says it works for Tundras, but the parts look different than the kit in previous posts.
    I gotta get these doors fixed, so I may be the guinea pig on if this kit works.
    shifty` likes this.
  19. Mar 29, 2022 at 2:01 PM
    tokolosh
    tokolosh Serial procrastinator
    J
    SF Bay Area
    05 AC V8 SR5 Phantom Grey
    new driver
    https://www.amazon.com/Check-Repair-Stopper-Replace-Toyota/dp/B095LT69S2?crid=Y0HXUQR7Q30C&keywords=B095LT69S2&qid=1648587684&sprefix=b095lt69s2%2Caps%2C160&sr=8-1
    i think this is the right one?
  20. Mar 29, 2022 at 5:58 PM
    #50
    zech
    zech New Member
    tokolosh[QUOTED] likes this.
  21. May 23, 2022 at 12:44 PM
    #51
    richsadams
    richsadams New Member
    Northwest
    2000 SR5 AC 4x4 4.7L
    Was hoping @SouthPaw, @FrenchToasty or really anyone would report back on how the Camry (or Corolla?) door checks worked on the first-gen Tundra. Have a '00 SR5 AC and need to do the same ASAP.
    TIA!
  22. May 26, 2022 at 9:47 PM
    #52
    richsadams
    Northwest
    I ordered one of the Camry door checks mentioned above and unfortunately can confirm that they do NOT work on the 1st gen Tundras. They look similar, but have a slight angle to them and will not fit. Worth a try.
    I would really like to replace the door checks since they're worn out and useless. I bought the repair kits for them, but it turns out the ones on our Tundra were repaired before and someone spot welded the casings completely closed for whatever reason making it impossible to open them without destroying them.
    Don't feel like paying $83 for OEMs since they'll likely fail the same way.
    I suppose I could buy used ones and repair them when they go bad.
    If anyone comes up with a better option, please post it.
    TIA!
  23. May 28, 2022 at 9:42 PM
    #53
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
  24. May 29, 2022 at 11:10 AM
    #54
    richsadams
    Northwest
    That's great news! I took a look at your post. Very creative. :thumbsup:
    As mentioned, the door checks on ours were repaired by the previous owner. The casings are spot welded shut but based on your post I should be able to make them work with the Dorman bits. Just ordered two so I'll post back with results.
    Thanks again!
    artsr2002[QUOTED] likes this.
  25. May 29, 2022 at 12:07 PM
    #55
    artsr2002
    'Yonder
    That second link I posted shows the Dorman part used along with the leg from the factory door check and includes pictures. The Dorman leg is a bit too short. You just have to take them apart and switch the parts. Keep us posted.
    richsadams likes this.
  26. Jun 2, 2022 at 9:10 AM
    #56
    richsadams
    Northwest
    Received them today. Now just have to find the time to pull them and the door apart to put them in!
  27. Jun 7, 2022 at 7:44 PM
    #57
    artsr2002
    'Yonder
    I wish 'Yota had designed them with the studs attached to the door skin instead of the door check. That would allow us to change the door checks out without having to pull the door panels off and remove the door checks thru the speaker holes.
    Weagle, bfunke, RUSTYNUTS and 2 others like this.
  28. Jun 8, 2022 at 5:23 AM
    #58
    Teutonics
    2005 DC SR5 4WD
    Great write up and creative solution. It's nice to know there's a second way to solve this issue, especially since the Russian kits are now unobtanium.
  29. Jul 24, 2022 at 4:39 PM
    #59
    richsadams
    Northwest
    From the other thread (https://www.tundras.com/threads/06-dc-daily-driver-2wd-to-4wd-conversion.48447/page-3#post-2562288):
    So I finally found time to get the new door check's end cut off but I'm not clear about how to remove the "squeezy bits" from the new door check and/or how to hammer them onto the OEM door check.
    I tried hammering the shaft of the new one out from the top but it seems to be unmovable. I didn't want to do any damage so I wanted to check with you to get your feedback. Maybe I just need a bigger hammer?
    TIA!
  30. Jul 24, 2022 at 5:41 PM
    #60
    artsr2002
    'Yonder
    Bend those 4 little tabs straight and the two pieces will separate, exposing the squeezy bits inside. Gently bend them back. They will most likely break anyway, its not very strong metal. Then pry apart the pieces along the red line as I've drawn it.
