DIRTY SEVEN CLUB
Discussion in '2.5 Gen Tundras (2014-2021)' started by matictundra, Feb 18, 2019.
  1. Apr 5, 2024 at 7:52 AM
    #3301
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    Sounds like you're getting 37s :thumbsup:
  2. Apr 9, 2024 at 4:57 PM
    #3302
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    Don't fight the 37s.
    wife took the truck and text'd me "the 37s are useful on shortcuts"
    COTundra23, Deaner, Helo and 16 others like this.
  3. Apr 15, 2024 at 8:00 AM
    #3303
    bmtrujillo98
    bmtrujillo98 New Member
    Who’s running 37s on Rock Warrior wheels with factory upper control arms and no wheel spacers? Really, I’ll take tips from anyone running 37s on factory upper arms in terms of body mount clearance. Thanks!
    V3N0M and b6graham like this.
  4. Apr 15, 2024 at 11:44 AM
    #3304
    Mwray8909
    Mwray8909 New Member
    Chino Valley
    18 TRD offroad cement CM
    Well, I was given a 94 blazer/Jimmy with a swapped 454 and 4l80e. It's on 37s.... I think im going wait on the 37s for the tundra lol
    Mountun Goat likes this.
  5. Apr 22, 2024 at 4:45 PM
    #3305
    contenderv07
    contenderv07 New Member
    Will
    After seeing some of the pics, I really want to make the jump BUT I don't think I'll have enough money to re-gear. To offset some of the size and weight of a larger tire, I started looking at BFG KO2's, which aren't a true 37 (more like a 36) and compared to the wildpeaks, are 10 pounds lighter per tire. Is that enough to somewhat offset having to re-gear?
  6. Apr 22, 2024 at 4:53 PM
    #3306
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    KO2 is a nice tire the weight will help
    contenderv07[QUOTED] likes this.
  7. Apr 22, 2024 at 5:06 PM
    #3307
    Uhhhh....
    Uhhhh.... New Member
    Dave
    Virginia
    2016 Silver Limited DC
    7” BDS, 37s
    My experience…although I did notice loss of acceleration, I’ve been running on stock gears on 37s w/ 7” lift for the past 7 years. Ideally, yeah I would definitely like the power back. But it is very drivable without it. It’s not an absolute “need,” I guess, is what I’m saying.
    rockmup and contenderv07[QUOTED] like this.
  8. Apr 22, 2024 at 5:16 PM
    #3308
    contenderv07
    Will
    Thanks I’m not too worried about acceleration , but I had a wrangler with 37s 9 stock gearing) and whoa it was awful:rofl:
    Uhhhh....[QUOTED] likes this.
  9. Apr 23, 2024 at 9:17 PM
    #3309
    allen_rubin
    allen_rubin New Member
    Allen
    2016 SR5 TRD 4x4 Crew Max
    King 2.5's with Camburg Uniball UCA Deaver u748 w/ TC Shackle Fuel Hype 17X8.5 10MM 37X12.5-17 BFG KO2 "Stock Gears" Alpha REX Pro Headlight and Tail Lights Custom Carven Side Exit exhaust ADD Front & Rear Bumpers along with Side Steps Westin Topper / Westin Power side steps
    It’s really not that bad
  10. Apr 29, 2024 at 11:09 AM
    #3310
    hotchops777
    hotchops777 New Member
    Matthew
    EAST TEXAS
    2011 5.7 Silver Sky DC
    6" Procomp Stage 2 lift Black Rhino Sierra 20x10 0 offset on 325x65x20 Nitto Ridge Grapplers Smitty Built M1 front grill
    I recently re-did all my suspension. I'm getting a rear creak/squeak and i cant trace it down. Heres what i have done.
    I replaced the rear leaf springs w/ Deaver U748 and eliminated the lift block. The leaf was installed with the provided bushing for the front from deaver and the bushing provided by Coachbuilder for my Shackle for the rear.
    I also replaced the shock with RC Vertex.
    I've traced down everything on the above parts and have spoken with both build owners. Verified the correct bushing are installed.
    Is this a rear thing for break in period (installed Feb 24) or should i check anything else. Its def coming from the shock leaf spring area but its all brand new and greased. Ive re torqued the ubolts and bolts for both shackle and front of leaf, and the shock.
    I know i need to get a video uploaded but haven't had help to stand on bumper to promote the noise.
    brodesiansneverdie and coTony like this.
  11. Apr 29, 2024 at 11:15 AM
    #3311
    coTony
    Tony
    Montrose, CO
    Nothing common to your setup and mine except the Coachbuilder shackles. I have gotten noise from back there every since I installed everything for 5 years now
  12. Apr 29, 2024 at 11:21 AM
    #3312
    hotchops777
    Matthew
    EAST TEXAS
    Ahh bummer... i know lifts are noisy but this shouldnt be the case when everything is new. Thanks @azTony
    coTony likes this.
  13. Apr 29, 2024 at 11:23 AM
    #3313
    coTony
    Tony
    Montrose, CO
    FWIIW mine was new from the factory and sounded like that but I was told that is the nature of the beast with leaf springs
    CaptRussia253 likes this.
  14. May 11, 2024 at 1:56 PM
    #3314
    Branmuffin
    Branmuffin New Member
    2019 MGM TRD Sport
    Do you have any pictures that show how much poke you have, pretty much looking at this exact setup for my own truck
  15. May 17, 2024 at 9:33 AM
    #3315
    2TunGet1
    2TunGet1 Tundra owner since 2000
    2020 Limited 4x4 CM QS / 2000 Limited 4x2 AC Black
    Anyone know of a good shop in the NorCal area that could do re-gearing?
  16. May 18, 2024 at 5:56 AM
    #3316
    5.7TRDProm
    5.7TRDProm What's bothering you?
    Dara
    2018 Cement Tundra SR5
    All stock-ish. Powdercoated blue suspension.
    stellarbuilt?
  17. May 18, 2024 at 3:27 PM
    #3317
    Js18tundra
    Js18tundra New Member
    18 Tundra sr5 TRD 4x4
    Diamondback se tonneau
    I’m having stellarbuilt do mine, they have a great reputation
  18. May 18, 2024 at 5:42 PM
    #3318
    2TunGet1
    Have you scheduled it yet? Are you doing 5.29’s? What brand are you going with?
  19. May 19, 2024 at 5:24 PM
    #3319
    Js18tundra
    Not yet, still saving Pennie’s, yes I’m going 5.29’s with an auburn grip n loc in the rear
  20. May 22, 2024 at 9:12 AM
    #3320
    brodesiansneverdie
    brodesiansneverdie New Member
    2020 White Tundra SR5 CM
    Toytec Aluma 2.5/2.0 SPC UCAs U748s Method 705s Toyo AT3 285/75r17 RCI Aluminum skid OTT tune Softopper Decked V2 Diode Dynamics
    Just stumbled upon this. I just did basically the same swap you did about 1500 miles ago (MCM Shackles instead of Coachbuilt), and developed a noise at about the 1000 mile mark. I'm going to probably pull everything apart to see if I could have lubed any of the bushings/sleeves better in the next few thousand miles when I upgrade rear shocks, but it sounds like it may just be life with U748s.
    Just out of curiosity, what type of lube did you use on the bushings/sleeves?
  21. May 22, 2024 at 10:50 AM
    #3321
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
  22. May 22, 2024 at 4:38 PM
    #3322
    brodesiansneverdie
    Glad to hear it! That's what I'll be going with when I re-lube. I went with the same stuff I use for my SPC joints which energy suspension should work fine, but I suspect that's where at least some of my noise is coming from.
  23. May 22, 2024 at 5:48 PM
    #3323
    rockmup
    rockmup New Member
    Todd
    Greenwell Springs LA.
    Kings, 5:29's, E-lockers on 37's
    Define NorCal, I know of several good shops from Monterey to Auburn
  24. May 23, 2024 at 6:25 AM
    #3324
    2TunGet1
    Willing to drive anywhere in NorCal provided it’s a good shop. Preferably around Sacramento to Auburn.
    I drove to Las Vegas to have my suspension done.
  25. May 23, 2024 at 6:38 AM
    #3325
    BreyTundy
    BreyTundy Big 4Lo Guy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Stellarbuilt in Sacramento has an outstanding reputation in the Toyota community. Or Chance at Califab in Sacramento, a buddy of mine had some work done there and says Chance's work is absolutely second to none.
    2TunGet1[QUOTED] likes this.
  26. May 23, 2024 at 10:24 AM
    #3326
    rockmup
    rockmup New Member
    Todd
    WFO Concepts is in Auburn, great guys.
    Lavender Brothers in Seaside- Toby Lavender is the owner.
    Wayside Automotive in Seaside - My brother Sam owns 3 shops
    All of these guys have great reputations.
  27. May 23, 2024 at 12:06 PM
    #3327
    Downytide
    GTA
    That is a terrible vehicle, it'll give you a lot of problems, why don't you let me come pick it up and remove it off your property.
    V3N0M and CaptRussia253 like this.
  28. May 28, 2024 at 10:44 PM
    #3328
    jeri3EAR
    jeri3EAR New Member
  29. May 29, 2024 at 9:59 AM
    #3329
    hotchops777
    Matthew
    EAST TEXAS
    Im kicking myself, I have the deavers installed backwards. They were correct left and right but i had to flip both sides. Once i did that everything went whisper quite. They were installed wrong for 6 weeks. I work remote and hardly drive and deaver said it happens all the time. I just used a blue all purpose poly grease i had in the shop/ dont know the brand sorry.
  30. May 29, 2024 at 1:48 PM
    #3330
    brodesiansneverdie
    I've put some more miles on them and mine have actually gotten a lot quieter. Can't tell if that's good or bad lol, but self clearancing is still clearancing.
