Tire wear- camber issue?
Discussion in 'Suspension' started by Supertech1, Jan 11, 2023.
  1. Jan 11, 2023 at 5:53 PM
    Supertech1
    Supertech1 [OP] New Member
    I’ve had my TRD Pro for a little over a month. Early on, I noticed when looking at the truck from the front, the tires appear to be leaning out at the top. Drove fine, so wasn’t concerned.
    On December 21st I had a new set of tires installed. Today I ran my hand over the front tires, and the outer tread is wearing on both driver and passenger side. Feels cupped or high/low from one lug to next. This is after 1200 miles.
    I’ve seen posts regarding the positive camber. Has anyone had the dealer check the alignment? Did they correct as a warranty issue, or say it’s within spec?
  2. Jan 11, 2023 at 6:29 PM
    kilocharlie106
    kilocharlie106 mmmm Bourbon
    TRD Pro in LR
    Yes. Same issue. Toyota checked alignment for free. Said it’s in spec. Falken said to take back to dealer so they can work something out? I need to get that done.
    but yeah not crazy about the camber/can’t that front tires have.
  3. Jan 11, 2023 at 6:37 PM
    Supertech1
    Is the spec different for the Pro? I believe the only comments I’ve seen regarding the camber, are Pro owners.
    My previous ‘22 SR5 did not have noticeable positive camber. It held the road and tracked great.
  4. Jan 11, 2023 at 6:40 PM
    Odin43
    Odin43 YNWA
    Rich
    NJ
    2021 MGM Platinum, 2015 Lexus LX 570
    I had positive camber after installing 6112 and the same tire wear issue. I had that adjusted to a more neutral camber. Wear issue seems to be resolved now and the truck looks better from the front view.
    Supertech1[OP] likes this.
  5. Jan 11, 2023 at 6:40 PM
    kilocharlie106
    TRD Pro in LR
    I think the track is different on the pro but I believe the alignment specs are same.
    When it’s visibly cambered inward by eyesight I can’t see how they say it’s ok
  6. Jan 11, 2023 at 6:45 PM
    Too much toe in will also give the same cambered look. How’s it drive?
  7. Jan 11, 2023 at 6:48 PM
    Supertech1
    It drives fine. Doesn’t wander, or pull. Ive had the toe issue before and could feel/hear the scrubbing. Not feeling anything like that.
    I’ll have Toyota check it out and report back. Will make sure they acknowledge the visual cant.
  8. Jan 12, 2023 at 4:16 AM
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    2022 SR5 TRD Sport Crewmax White
    Looks like the TRD pro has different alignment according to the spec sheet. It runs just over 1 degree of positive camber with a tolerance of +\-0.75 degree.
    Other 4WD models runs only half a degree with same amount of tolerance. So can get 0 degree with other 4WD model and still within spec.
    TRD pro it would show out of spec if you were to adjust to 0 degree of camber. The alignment spec sheet:
    kilocharlie106 and porterbc like this.
  9. Jan 12, 2023 at 4:48 AM
    porterbc
    porterbc New Member
    Brandon
    2022 Tundra Crewmax Limited TRD OFF-ROAD
    Perfect timing! I’m going back in to have mine redone this morning. I had installed the aftermarket springs from @GeneralSpring which gives me a 35% payload increase. So buddy had done the same to my truck leaving too much camber. It tracks fine but the minute you start to corner it really takes off. Plus a visible positive camber just looking at it. I prefer a little extra caster as it makes it track much better especially once you add 8-10,000 lbs with a trailer, that will take all your caster away once you squat the back end.
    thanks for the spec sheet @TakiEvo
  10. Jan 12, 2023 at 4:50 AM
    pursuit2550
    pursuit2550 New Member
    2020 Tundra SR5 Maggie 1900
    I don’t even bother with the dealer. They think that because it’s with in spec or all green that it’s fine. I take my truck to an independent alignment guy, that’s all he does. He’s told me dealers bring him tundras to align because of tire issues from factory. Reason number 1,287,459 why I stay away from dealers.
    Soupbean77 likes this.
  11. Jan 12, 2023 at 4:56 AM
    porterbc
    porterbc New Member
    Brandon
    amen! As long as they show green on screen they don’t care. I got to coast tire here. Dedicated tire shop and they have the newest laser alignment rack from hunter. He’s done my last 2 Toyotas which has always eliminated the rounding off of the front tires that Toyota is infamous for. Outside and inside shoulders are scolloped and down to wear bars, and centre of tire still has 12/32’s tread left.
  12. Oct 2, 2023 at 11:04 AM
    Lynnster2
    Lynnster2 22 TRD PRO
    California
    2022 TUNDRA TRD PRO
    Slider Boards
    I have the same issue with my falken tires on a 22 Trd pro. Falken tells me it’s Toyota‘s fault Toyota is telling me it’s Falkens fault. Any chance you can give me the dealership name that is aware of the alignment spec change? Falken said Toyota admitted to having an alignment spec problem and that they were rectifying in May of this year. Had a significant blowout on the freeway this weekend at 20k miles.
  13. Oct 2, 2023 at 11:06 AM
    Dang. That’s straight sidewall failure. TPMS would surely tell you if you were u fee inflated which is the only thing that would normally increase the risk of this. Those factory Falkens look like weak sauce.
  14. Oct 2, 2023 at 4:48 PM
    SWB Tundra
    SWB Tundra New Member
    T
    Cenral Arkansas
    2024 Tundra Platinum 4x4 CM Hybrid
    Check for nail hole anywhere on that tire. Looks to me like it has been run low on air and is a run flat.
  15. Oct 2, 2023 at 6:11 PM
    ArticTundra
    ArticTundra New Member
    Cold
    My truck, not a Pro, is having the same problem. My local dealer offered me a rental car and said they'd take my truck for an entire day while they research the issue. Straight front the service manager: Toyota is aware of the issue with extreme outside tire wear and is trying to research solutions.
  16. May 12, 2024 at 1:43 PM
    DEboater
    DEboater New Member
    2021 DC SR5
    My tires are wearing. I drive in northern VA/wash DC and do turn lazy/sharp sometimes, not all the time I go slow in the neighborhood and on base. This truck had the steering rack replaced when I bought new in Dec 2021, 5k miles later rack was loose and a dealer fixed the rack and did an alignment. I don’t tow with the truck. Rotated every 5k miles. At 27k miles, would like to get 40-50k out of these tires, thoughts?
  17. May 12, 2024 at 3:22 PM
    Polo08816
    Polo08816 New Member
    2014 BMW 335i
    Needs more negative camber.
  18. May 27, 2024 at 7:13 AM
    jb trd
    jb trd New Member
    22 Tundra CrewMax Limited 6.5
    My '22 doing the same thing. added negative camber. Agree w many if technician see's it in green he thinks he's done. The fact that there is a range within green that can be used to optimise your alignment is missed by many. Installed new tires. Went with a stiffer 10 ply Yokohama Geolander also. Was a little concerned ride might be too harsh but it's good. Stiffer tire should help with tire rolling over too. Time will tell.
