Stock Battery...
Discussion in '2nd Gen Tundras (2007-2013)' started by TundraDan723, Sep 19, 2017.
  1. Sep 19, 2017 at 10:35 PM
    TundraDan723
    TundraDan723 [OP] Not as new as I used to be...
    2023 Celestial Silver Tundra 1794 TRD CM
    I have a 2011 with the stock battery. Other than the corrosion issue that seems to plague many people it has worked fine. We had a lot of hot weather this year and it was fine but with winter coming should I replace it anyway, or see how things go? It is 6 years old which seems like it's on the longer side of lifespan.
    TIA
    4x4_Angel likes this.
  2. Sep 19, 2017 at 10:49 PM
    Toyota batteries are under warranty for 8 years. However, that doesn't help when you hear the "click" of the solenoid on the starter and that is it.
    My other half has been stuck twice now because of factory Toyota batteries at about the 6 year mark.
    T-Rex266 and Patriot like this.
  3. Sep 20, 2017 at 7:21 AM
    Factory batteries suck. I replaced mine after 3 years with an Odyssey.
    smslavin and Patriot like this.
  4. Sep 20, 2017 at 7:25 AM
    Patriot
    Patriot Member
    Western NC, “Boondocks”
    Yep OEMs 3 yrs and replace with an upgrade.
    T-Rex266[QUOTED] likes this.
  5. Sep 20, 2017 at 7:28 AM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    i'll picking one up shortly
  6. Sep 20, 2017 at 8:07 AM
  7. Sep 20, 2017 at 8:16 AM
    Jaywhy
    Jaywhy Old Member
    Jeff
    2016 SW TRD Pro CM
    I'm a true believer in preventative maintenance, and never let a battery go past five years, regardless of warranty or if it passes a test.
  8. Sep 20, 2017 at 8:38 AM
    chphilo
    chphilo Tundra addict
    Western PA
    2010 Toyota Tundra TRD 5.7 4x4 CM
    My OEM battery died at after about 4 years. It died without any hint that it was going bad. Lucky for me, I was picking up my children from school not too far from home.
