General Supercharger Thread
  1. May 24, 2024 at 11:34 AM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Mdl and HulkSmurf14 like this.
  2. May 24, 2024 at 11:37 AM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    We have to remember that all of those HP calculators are based on redline peak HP. Most don't account for drivability and lower rpm scavenging from smaller exhausts.
    koditten, Saltyhero13 and HulkSmurf14 like this.
  3. May 24, 2024 at 11:52 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    I replaced my stock basket venturi with this, I cut off the bottom inlet nipple and enlarged the hole to fit a fuel tube through for the siphon. With my engine idling it overflows the basket. I had the basket spaced off the tank with 2x4's with everything connected and engine running, trying to see if I had a leak in the basket connections...one of the many hoops I jumped through trying to run down my pressure drop at high RPM.
    https://www.radiumauto.com/Venturi-Jet-Pump-Kit-P760.aspx
  4. May 24, 2024 at 11:54 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
    My understanding is the exhaust system is tuned to support specific bands of power; by exhaust system I include both header and cat back.
    Look at shorty tri "y" vs long 4 in 1s, power shift from one end to another. No simple exhaust will do it all across all bands. I've only seen a variable exhaust design on motorcycles, changes restriction to optimize power across more RPM band.
    This is where I think not all exhausts are created equally. Crappy exhaust design can clearly hurt power; wrong diameter, poorly formed bends, restrictive muffler, lack of crossover/balance pipe or poor transition into one etc.
    Is it gobs of power on the table? Not likely at the larger pullies most of us are running on unbuilt engines. Probably proportional to total engine output so it may matter more as power output climbs. General trend is the gains are always on the big end unless you run shorties.
    As long as the total power isn't hampered, lower PSI is a good thing as discussed before. Chamber temps are purportedly lowered by good exhaust flow too but not sure it is possible to measure on a stock set up.
    I would be curious to see dyno#s for different set ups. Most of the stuff posted here or the market place is for NA and the gains are almost always up top.
    I'm tempted to get redynoed once I get my exhaust sorted and possible retune.
    Mdl and blenton[QUOTED] like this.
  5. May 24, 2024 at 11:59 AM
    Saltyhero13
    Exactly why I don't think dyno numbers tell the full story.
    Same holds true for going too big with throttle body. I couldn't find a hard and fast rule for sizing but too big can cause drivability issues.
    Using the rule of thumb for min intake exhaust CFMs is probably a good starting point to root out restrictions unfortunately most vendors don't have CFM ratings for intake/exhaust parts like you see on some of the higher end custom parts shops.
    VWTim[QUOTED], blenton and Mdl like this.
  6. May 24, 2024 at 12:03 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Nice setup and good use of injector clamps instead of hose clamps!
    armyoffoo[QUOTED] likes this.
  7. May 24, 2024 at 12:12 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Thanks! Those were a pain, but also done to make sure nothing came loose. In the end, bypassing the fuel pump control module and upgrading wiring was the key to keeping my pressure stable. Now pressure is where it is supposed to be and climbs with the boost.
    Mdl and Fastlane47 like this.
  8. May 24, 2024 at 2:20 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Finally installed my fleabay engine oil cooler. Will see how it holds up. Able to get 9.5 quarts in.
    Fastlane47, Jowett, Silver17 and 9 others like this.
  9. May 25, 2024 at 9:07 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
  10. May 25, 2024 at 12:19 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    Just don’t floor it on an incline below like 1/3 tank, it’ll run dry! I do like the simplicity of the 274 with holes as the pump is only pumping and not doing a secondary venturi to fill the basket, this likely maximizes the stock wiring and hoses. Don’t use regular hose clamps as they can’t get tight enough and the 274/system will slow leak when off and make for hard starting (second photo hose clamps : bad).
    snivilous[OP] and Mdl like this.
  11. May 25, 2024 at 2:06 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    He also is FFV which is supposed to have a larger venturi system to handle the ffv high pressure. I installed a ffv tank used a walbro 450 model 267 with no hole drilling and venturi system.
  12. May 25, 2024 at 2:08 PM
    mralanle
    mralanle New Member
    Gotcha, fuel pump and hardwire in. Gonna install the fuel rails soon and fingers crossed no more fuel pressure loss
    Mdl likes this.
  13. May 25, 2024 at 2:08 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Since you couldn't get the vsv relay to kick in high psi. You can try hot wiring the pump. You'll give it the full 14.2 or so volts.
    HulkSmurf14 likes this.
  14. May 25, 2024 at 2:09 PM
    mralanle
    mralanle New Member
    I bought the DW hardwire kit, wiring it straight to my battery!
    Mdl[QUOTED] likes this.
  15. May 25, 2024 at 6:33 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Decided to do my trans fluid a little early as I was being a bit rough on it lately. Not too bad.
    Was going to try havoline world atf but came across an ad for ws fluid at 1/2 off. Guy sold his tundra and had a case of ws fluid. So I grabbed that. Removed my trans thermo and coolant puck. Straight lined it. It was a slow day...
  16. May 25, 2024 at 6:34 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Any luck with your afr's and fuel pressure?
  17. May 25, 2024 at 6:44 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    What fittings are those in place of the puck? Where are the lines to the trans fluid cooler?
    Mdl likes this.
  18. May 25, 2024 at 7:37 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    They are elbows that John at ipt mentioned in a video. They don't come with o-rings but found some to fit. Just going straight to cooler and back. The coolant lines I removed and joined it with an 3/4 hose elbow.
  19. May 25, 2024 at 7:46 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    @armyoffoo. I used your idea with the Greddy thermostat on the Baxter performance adapter. I used a smaller filter to reduce the weight but it seems pretty stout. I don't have the mechanical fan to worry about the oil line placement. It opens fully at 176 deg. Seems ok for now. Thanks for the idea. I'll throw on the wix 51516 later.
  20. May 25, 2024 at 7:47 PM
    mralanle
    mralanle New Member
    Tbd, still getting everything installed and will test. If it’s still losing pressure, I have no idea what else to do
  21. May 25, 2024 at 7:48 PM
    e30cabrio
  22. May 25, 2024 at 7:50 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Well. You tested everything in order and as a last resort was dropping the tank and changing pump with it hard wired.
    This will do it! Sending positive vibes...
  23. May 25, 2024 at 8:15 PM
    Jowett
    Jowett New Member
    North Adams, MA
    2011 Regular cab long bed 5.7 Work Truck Package
    Many on the way.
    In some markets, the LC w/ AB60F does not use the t-stat or warmer ( they do have the lower radiator tank cooler, though). The elbows are factory correct, o rings are part # 90301-11030.
  24. May 25, 2024 at 8:22 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Thanks. I forgot about ordering the o-rings. At first I thought it was a crush washer but nope...need those o-rings.
    Thanks for your help with the engine oil cooler ideas. I just went with the least expensive and easiest route. But if I do come across a RC F cooler...haha
    e30cabrio likes this.
  25. May 25, 2024 at 8:27 PM
    Jowett
    Jowett New Member
    North Adams, MA
    Many on the way.
    No problem. One of these days I’ll finish the oil cooler and write it up. What size lines did you run?
  26. May 25, 2024 at 8:33 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    10AN hose, .56 ID, and the cooler is open at 176 deg. I found that the stant coolant thermo pills will fit in if I need to increase the temp.
    reywcms and e30cabrio like this.
  27. May 26, 2024 at 7:09 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    You might want to do some full lock turns in both forward and reverse to see if your sway bar contacts the assembly...my TRD sway bar made contact with the filter and leaked oil everywhere when I used that Baxter adapter...which is why I wanted to try that alternate oil cooler assembly that positioned the filter horizontally. I ended up getting the Baxter remote oil adapter and a remote filter mount, but I haven't installed it yet.
  28. May 26, 2024 at 7:13 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    The adapter seemed to have plenty of room when installed, but came into contact at some point over the course of that weekend. No offroading, no wild driving, only thing that comes to mind is a couple hard U-turns while accelerating to clear traffic. Stock motor mounts and swaybar bushings at this point.
    Dent in the filter
    Wynnded and Mdl like this.
  29. May 26, 2024 at 7:19 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Thanks for the heads up!
    I did a few turns on my way to the store but not fully locked, went over 2 speed bumps.
    I'll give it a good run through before fully committing!
    Has any other Baxter Performance users experienced this? Wonder if company heard comaints...thanks again for the info. Will keep an eye on it!
  30. May 26, 2024 at 7:25 AM
    e30cabrio
    I have the Baxter & TRD Sway, no contact ...YET :(
    lol
    Mdl likes this.
