  1. May 24, 2024 at 2:48 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I haven't tried to go over 95, but I know my new redline is 5900rpm with my buddies PowerThirst tune
  2. May 24, 2024 at 6:22 AM
    metalpete
    metalpete New Member
    ID
    2001 Tundra 4.7 4x4 SR5
    Toytech 2.0 Coilovers Camburg UCA's JBA headers Dynomax cat-back exhaust 90-221HD Leafs
    I want some of those :( . I have the 2010SJT.
  3. May 24, 2024 at 6:34 AM
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    I wonder. I'll just check it any time it's wet.
    BroHon[QUOTED] likes this.
  4. May 24, 2024 at 7:04 AM
    KingSequioa007
    KingSequioa007 Dreaming of URD S/C
    San Diego, CA
    07 Sequoia SR5
    Current mods: AFE Cold air intake, AFE TB Spacer,JBA Long tube headers, DD full cat back race exhaust, pedal commander pedal controller, URD MAF Calibrator tuned by Mike @ Autowave, DD 12 hole 320CC injectors, R9K ECU reflash,Solid Off road mounts. Future upgrades: 4.8 gears and LSD, ,long travel kit.
    I hit 112 on a nice straight but got scared for more lol. My 3rd Dyno session, guy hit 125-135. 5900 Redline is scary, but I wouldnt mind a 6500-7K redline with some cams and upgraded valve train.
  5. May 24, 2024 at 7:08 AM
    shifty` You can call 1 (800) PP5-1-DooDoo
    TWSS
    Or just use a water hose and spray inside the cowl?
    PO may've parked under a carport or other covering or maybe they parked with the driver side lower. Jump to 4m22s mark for the fasteners.
    https://www.youtube.com/watch?v=2RZkZNPNcPM#t=4m22s
    The Black Mamba and BroHon like this.
  6. May 24, 2024 at 7:12 AM
    KingSequioa007
    San Diego, CA
    07 Sequoia SR5
    I get the occasional P0420 but then it clears itself. I do have a bad rear 02, so that code constantly pops here and there. I recently bought a set of high flow cats by Private label. Can't wait to get back from this deployment and have DD install them.
  7. May 24, 2024 at 7:13 AM
    And I'm pretty sure these are the cause of the A-pillar leak into the fusebox, leaks @RUSTYNUTS and I think @FrenchToasty have suffered with. This one, specifically.
  8. May 24, 2024 at 7:35 AM
    MT-Tundra
    Montana
    Thanks. This is the driver side upper corner of the windshield? Sorry with some of the photos of leak areas I have a hard time orienting myself.
    Now that I'm 99% done with getting everything to a baseline with fluids and mechanics, I can start focusing on this type stuff.
  9. May 24, 2024 at 7:39 AM
    Oh, well this isn’t good. I’ll need to address it before it gets worse. I hate rust.
    Tlar25, Voss, BroHon and 1 other person like this.
  10. May 24, 2024 at 9:37 AM
    phudz
    phudz
    Michigan
    2004 DC V8 4WD
    Update: It was the damn sway bar end links... apparently I tightened them down, but forgot to go back and torque them down at the control arm ends. Corrected that, went for a test drive, and the clunk is gone!
  11. May 24, 2024 at 9:37 AM
    Indeed, check that video, starting around 8:30.
  12. May 24, 2024 at 9:53 AM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    If you ordered new OEM grommets can you post up a picture of how they look when they show up. Really wondering if the quality is any different than the last time I ordered. I only got 2 and a half years out of my replacements before it started leaking again.
    https://www.tundras.com/threads/def...n-water-leak-thread.70464/page-2#post-3554294
  13. May 24, 2024 at 9:58 AM
    MT-Tundra
    Montana
    I remember seeing that. I've also seen videos/photos where people just took their existing grommets and either added butyl tape or silicone. I would have just done that, but mine are actually missing. I need something to start with first...so I ordered them even though the quality is likely crap. I'll just improve them with some type of sealant.
    But yes, I'll follow up when they arrive.
    KNABORES likes this.
  14. May 24, 2024 at 10:22 AM
    NickB_01TRD
    KY
    The one you just posted pictures of isn't the problem area, it's the ones the screws go through up by the wipers.
    shifty` and abcinv like this.
  15. May 24, 2024 at 11:06 AM
    Those are normally filled with a translucent "tophat" looking thing, and a black spindle-looking fitting snaps the cowl down, by snapping into the tophat pocket thingies.
    Like Nick said, when you pull the cowl, you take out some screws. What you're sealing up is the snap-in receiver those screws go into. You only need to seal up around the edge of the receivers, and only two of them, but they tend to break apart when you pop them out, so ... be forewarned. Let them cure fully before reinstalling the cowl, or replace the fasteners totally like I did (wish I'd have sealed my new ones in ... the foams they come with are cheezball)
    Part numbers you need (maybe even quantity) are in the definitive leak sticky thread.
  16. May 24, 2024 at 12:59 PM
    MT-Tundra
    Montana
    I ordered the part number from the sticky, guess I just didn't realize they weren't what's missing in my photo. I'm still interested in putting in the new grommets I've bought, but it looks like I also want to replace the things my photo shows missing. I don't see those addressed in the sticky...did I miss it? Or should I not even worry about those?
  17. May 24, 2024 at 1:33 PM
    metalpete
    ID
    So, uhhhhh... is this supposed to be flat?
    Shoot grabbed the wrong pic. I'm talking about the mounting hole, bottom right. Tailgate handle.
  18. May 24, 2024 at 1:35 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    yeah
    oscardog86 and metalpete[QUOTED] like this.
  19. May 24, 2024 at 1:38 PM
    metalpete
    ID
    Thanks. I man-strengthed it back into place.
  20. May 24, 2024 at 1:52 PM
    And should have a bolt in it too? Is it maybe rattling around somewhere?
  21. May 24, 2024 at 1:55 PM
    Cowl clips: 9008018055 (these are the leaky part)
    Cowl push pin: 904670704522 (these are the black ball-end things that "rivet" down the cowl)
    White receiver: 9046708184 (these are the white cups that snap into your steel body, and act as a receiver for the black push pins)
    Cowl clips:
    Push pin:
    White receiver:
    NickB_01TRD, BroHon, daveeasa and 3 others like this.
  22. May 24, 2024 at 2:01 PM
    Oh, and I've updated the leak thread to link back to my last reply, and update with a new leak-fix video that covers most of the possible leakes these trucks will ever have. Someone posted a new video on the 'Tube that sorta covers all the info I had in the leak thread.
  23. May 24, 2024 at 2:13 PM
    metalpete
    ID
    That pic was when I was installing the new one and the bolt was angled when I removed it. Didn't think much of it at first. 'cause weird shit, ya know? But during installation, I realized something was off.
    oscardog86 and shifty`[QUOTED] like this.
  24. May 24, 2024 at 2:14 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    I know it's in the sticky, but saving for later as I too have to do this
    shifty`[QUOTED] likes this.
  25. May 24, 2024 at 2:15 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I still haven't figured out where my leak originates. It's been dripping off my hands free mic
  26. May 24, 2024 at 3:00 PM
    757TundraAC
    757TundraAC New Member
    Cody
    2002 Tundra AC 2wd
    6 inch rcd lift 35 inch nitto tires 17 inch Mickey Thompson rims
    Any prep work such as sanding involved or just take off and spray?
  27. May 24, 2024 at 3:03 PM
    MT-Tundra
    Montana
    I'll likely order those, but it's going to have to wait till I need a few other things. They really get you on shipping for these inexpensive orders. Or I can call the dealer about 2 hours away and pick them up from there whenever I'm in town next.
  28. May 24, 2024 at 3:08 PM
    Voss
    Voss Not a new member
    2003 AC TRD 4x4
  29. May 24, 2024 at 3:08 PM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    I hit them with 320 grit unill they were matte.
  30. May 24, 2024 at 3:35 PM
    757TundraAC
    Cody
    2002 Tundra AC 2wd
    Ok, 320 grit, anything else and how many coats. And any brand you would recommend to do on it?
