Big Brake Kits
Discussion in '3rd Gen Tundras (2022+)' started by jnasty, May 12, 2024.
  1. May 12, 2024 at 3:32 PM
    jnasty
    jnasty [OP] New Member
    2022 Tundra TRD Pro
  2. May 12, 2024 at 4:15 PM
    Coal Dragger
    Coal Dragger New Member
    Kung Fu Dick
    Only the Wilwood proudly proclaims it will give people in California cancer. That’s how you know something is going to actually work and be worth buying.
    With your contributions and hard work installing those brakes you can give a Californian cancer. Do your part to eradicate the plague of Californians!
  3. May 12, 2024 at 4:31 PM
    Nm6300'asl
    Nm6300'asl New Member
    2022 DC SR5 4x4
    Oem tonneau, side steps, spray in liner. Trd skidplate.
    Disregarding the above, unless you have some crazy heavy wheel and tire set I don't understand the need. I am in the Rockies and have mine loaded for work as well as towing, never any brake issues. They sure look cool tho.
    aj350925 and pwpblue like this.
  4. May 12, 2024 at 4:32 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
  5. May 14, 2024 at 9:16 PM
    jnasty
    2022 Tundra TRD Pro
    My brakes have been replaced once for “total failure” - Toyota unable to find a reason. Replacement ones suck and I have to hit the pedal hard to come to a stop.
  6. May 15, 2024 at 7:55 AM
    jnasty
    2022 Tundra TRD Pro
    ryanwgregg[QUOTED] likes this.
  7. May 15, 2024 at 8:09 AM
    jnasty
    2022 Tundra TRD Pro
    True. I just bought a Ferrari though.
  8. May 15, 2024 at 9:37 AM
    jnasty
    2022 Tundra TRD Pro
  9. May 15, 2024 at 9:43 AM
    chunkytundra
    chunkytundra New Member
    SOCAL
    KING 2.5 Coil Over Resi W/ Adjuster KING 2.5 Rear Shock Resi W/ Adjuster KING Rear Sway Bar Billet Link Kit KING 2.0 Rear Bump Stop Kit MAZZULLA Billet UCA MAZZULLA Billet Trailing Arms DR.KDSS Track Bar Correction Kit PERRY PARTS Front Bump Stops BAJA DESIGN 9 XL Linkable Roof Bar Kit BAJA DESIGNS XL Sport A-Pillar BAJA DESIGNS S8 20" Behind Bumper Light Bar BAJA DESIGNS S2 Dual Fog Light Kit BAJA DESIGNS S8 20" For TRD Heritage Grill BAJA DESIGNS S2 x2 Chase Lights BAJA DESIGNS S2 x2 Flush Mount Revers Lights BAJA DESIGNS Rock Light Kit SPOD HD BantamX SDHQ Built A-Pillar Light Mounts ALPHAREX Nova Headlights RRW 17x8.5 ET 0 TOYO TIRES RT Trails 37x12.5R17 Extended Brake Lines INNOV8 Racing Billet Bed Support Kit PERAGON Tonneau Cover Limited HDx CHARVONIA DESIGN Billet D-Rings ALPINE Off-Road Y Strap TRD Heritage Grill TRD Pro Marker Lights TRD Camo Fenders TRD Skid Plate W/ Black Lettering Gold Hook "TRD 4x4 Sport" Replacement Bedside Decals in Black/Gray/Silver Colorway SEIBON CARBON RR-Style Carbon Fiber Hood Painted/Matte Clear Carbon Fiber
    Thinking of ordering the Wilwood kit. But fitment is a concern on the 17inch wheel I am running. I sent them an email, but they are not eager to help or sell.
    416taco, jnasty[OP] and ryanwgregg like this.
  10. May 15, 2024 at 9:49 PM
    romanlegion
    romanlegion New Member
    Roman
    Katy, TX
    2022 Tundra SR5 TRD Off-Road Lunar Rock
    I have a set of the Rotora brakes on mine (6-piston front / 4-piston rear). I've had mine since October and so far so good. Massive difference in braking performance over stock.
    Adam B, jnasty[OP], kirkb and 3 others like this.
  11. May 16, 2024 at 1:32 PM
    chunkytundra
    SOCAL
    Wow it fit a 17 inch! Good to know! Thanks!
  12. May 17, 2024 at 9:40 AM
    teab
    teab 2023 Platinum w/ PRO bits
    Ty
    Denver
    2023 Platinum MGM 6.5
    TRD Pro Wheels, Go Rhino D6, Airlift bags/compressor, Talons Alum Cat Shield, Cheap-o Amazon Mud Flaps, Fastop Tonneau/Topper, Rear TRD Pro Shocks
    With replacing the rear calipers with a 4-piston set up. Does your electronic e-brake still work the same?
    romanlegion[QUOTED] likes this.
  13. May 17, 2024 at 9:55 AM
    romanlegion
    Roman
    Katy, TX
    Nothing has changed in the e-brake functionality. :)
    Tundrastruck91 likes this.
  14. May 17, 2024 at 10:13 AM
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    Wilwood is great if you don't have to worry about winter since they have no dust boots, Powerbrake seem to also use just pistons seals vs dust boots + seals, keep that in mind.
    chunkytundra likes this.
  15. May 17, 2024 at 10:14 AM
    teab
    Ty
    Denver
    Thanks for the reply, so you're saying the Rotora 4-piston caliper in the rear has a provision to accept the the electronic actuator that applies the electronic e-brake then? Curious to know if it applies two pistons or just one. Or if it applies all 4. I thought the actuator is mechanical and pushed the one piston out rather than through brake pressure. This is also why I would assume most big brake manufactures are staying away from the rears because they would have to work with the Toyota actuator or have their own. If Rotora has that figured out I agree with Ryan they are actually pretty competitively priced compared to others on the market.
    Polo08816 and Tundrastruck91 like this.
  16. May 18, 2024 at 2:07 PM
    romanlegion
    Roman
    Katy, TX
    As to the number of pistons in the rear brakes for the e-brake, that’s a technical question to ask Rotora. Sorry, I don’t know the answer to that.
  17. May 21, 2024 at 8:17 AM
    Downytide
    GTA
    yes, standard EPB uses a ballscrew mechanism, this photo shows it looks like it uses a similar set up,
    https://hpbuilt.shop/products/rotor...ston-rear-electronic-parking-brake-compatible
    Wilwood and others have also done this for a while, some like the EPB to be a standalone caliper, it reduce the complexity.
    Then I've also seen these integrated ones.
    romanlegion and teab[QUOTED] like this.
  18. May 21, 2024 at 12:42 PM
    Foques
    Foques New Member
    god damnit.. I've never had a stronger sales pitch in my life
    brhodea, Raven67, jnasty[OP] and 3 others like this.
  19. May 21, 2024 at 12:51 PM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
  20. May 21, 2024 at 1:43 PM
    chunkytundra
    SOCAL
    Bahahaha
  21. Jan 7, 2025 at 8:42 PM
    Motalu
    Motalu New Member
    Luis
    2015 Tundra Pro
    I’ve been running the Wilwood and have had issues with brake judder. I resurfaced the rotors which Wilwood advices against. They felt good for a bit but now having issues again. About 15k total miles on the kit. Keep in mind rotors are $500 a piece and pads are about $250 for the set. Wilwood wasn’t helpful either when I asked for support on why the rotors warped so quickly.
    2015 Tundra with 35’s and occasionally tow a 6500lb travel trailer.
  22. Jan 7, 2025 at 8:50 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Did you bed them in?
    blenton likes this.
  23. Jan 7, 2025 at 9:08 PM
    blenton
    blenton New Member
    … and torque the wheels properly instead counting uggha-duhgghas?
  24. Jan 7, 2025 at 10:19 PM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
  25. Feb 23, 2025 at 11:30 AM
    jnasty
    2022 Tundra TRD Pro
    I finally installed a front Alcon BBK. Nice so far.
  26. Feb 27, 2025 at 8:59 AM
    chunkytundra
    SOCAL
    Do you know if this kit fits a 17inch wheel?
  27. Feb 27, 2025 at 9:01 AM
    6rian
    6rian New Member
    Alcon offers kits for both 17" and 18" wheels.
    jnasty[OP] likes this.
  28. Feb 27, 2025 at 9:03 AM
    chunkytundra
    SOCAL
    Yeah just found it on google. Very nice!
  29. Feb 27, 2025 at 10:07 AM
    romanlegion
    Roman
    Katy, TX
    I have the Rotora kit on mine and using a ICON wheels 17X8.5. I've had the BBK since October 2023 and so far so good.
  30. Feb 27, 2025 at 10:10 AM
    Uhhhh....
    Uhhhh.... New Member
    Dave
    Virginia
    2016 Silver Limited DC
    7” BDS, 37s
    I've had mine in the box for a couple months - still have to install. How have the pads been wearing in your experience?
