Brand new platinum, cosmetic accent panel falling off
Discussion in '3rd Gen Tundras (2022+)' started by Pigchampion, May 19, 2024.
  1. May 19, 2024 at 10:01 PM
    Pigchampion
    Pigchampion [OP] New Member
    Picked up a brand new platinum the week before last just before I had to go out of town for the week. Drove 5 mins from the dealer to pickup a kid and noticed a long thin panel on the rear passenger door is loose and on its way to falling off. See photos:
    Was pressed on time and omw out of town but let the dealer know and they assured me that we can work out fix when I return. Seems like a easy QC issue that can be trivially fixed.
    Chatted with them while I was gone and they propose I drive 45 min to drop the truck for an indefelinte period of time and go home with a loaner car. Dealer much closer said to bring it in and see what they think they can do, but that they should be able to fix
    Question: is it worth the trouble or is this just a gorilla glue job ? It looks as if it was originally attached with adhesive and no nuts or bolts. It's beginning to loosen more and will probably begin scratching paint while it wrattles.
  2. May 19, 2024 at 11:15 PM
    TundrX
    TundrX New Member
    Toan
    Sacramento, CA
    2024 Tundra Hybrid Platinum
    If they're offering to potentially fix it, I would take them up on that offer and load up some miles on a loaner. But can gorilla glue do the job? Probably. Though, personally, I wouldn't want that to be my solution after paying ~70k.
    cmiles97 likes this.
  3. May 20, 2024 at 12:29 AM
    blschaefer1
    blschaefer1 New Member
    Common problem on Platinum trim. Dealer can fix it, but it will probably happen again. Issue is the black plastic expands in heat causing the adhesive to fail. Many of us (myself included) simply remove the trim altogether. I like the cleaner look.
    Others have had the trim expand to the point where it intrudes on the opening/closing of the front doors and it snaps the end off.
    A little searching will yield numerous threads on this topic.
    Amazing to me Toyota has not implemented a solution to this failure.
    digitalwiz likes this.
  4. May 20, 2024 at 7:31 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Let them fix it. My 22 Platinum did the same thing 2yrs ago...doing it again as of a few months ago.
  5. May 20, 2024 at 7:33 AM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    I would NOT gorilla glue it. Let the dealer fix it under warranty. God forbid you do something that they then say later caused the issue and deny a warranty claim….like a paint issue. Or remove the piece of trim entirely.
  6. May 20, 2024 at 8:02 AM
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    What I would do (and did after I swapped my 1794 badges into black oem platinum trim)
    get the new pieces from toyota, but don’t have them install them. Have them remove the existing ones on the truck and clean/ prep the area.
    Get on Amazon and buy a big thick roll of VHB tape by 3m and do the entire emblem in one run per section, cut it right on the edges. Heat the truck up and heat the VHB up and stick them on- mine never came off after doing that
    Hella Krusty and mayan like this.
  7. May 20, 2024 at 11:56 AM
    ChucklesToy
    ChucklesToy Retired
    Chuck
    Georgetown , TX
    2024 Honda Ridgeline Black Edition
  8. May 20, 2024 at 12:01 PM
    Markus
    Markus Hermitic Member
    Mark
    Boring, MO
    2 1794 Tundys 2014 and 2023 AG TRD
    A few
    Well quit picking at it
    SilveradoSwap and 1lowlife like this.
  9. May 20, 2024 at 12:22 PM
    DRP
    DRP Old Member
    Dave
    I second not using gorilla glue. At least not the stuff I have. Says right on the bottle that it expands. Of course I used it before reading that and it was a mess.....
  10. May 20, 2024 at 12:31 PM
    cmiles97
    cmiles97 New Member
    2018 Toytota Tundra SR5 4x4 XP
    XP package
    Well over $60k with glued on exterior trim pieces on a truck, that fall off??? Apparently Toyota Engineers expect these to be always garaged and never see any work, parking lots, car washes, etc.
    That is disappointing and sorry for you to have to bother taking back. Please let us know if the solution is a permanent one, not just to make it last past the basic warranty.
  11. May 20, 2024 at 2:25 PM
    Pigchampion
    Thanks for replies and link to main thread--didnt have good luck choosing search terms that would have landed me there.
    Today I noticed the front platinum badge on the other side of the truck has also started to separate. Brought it to the closet dealer and have an appt next week. Hopefully it's a quick one.
    cmiles97 and ChucklesToy like this.
  12. May 20, 2024 at 5:33 PM
    SilveradoSwap
    SilveradoSwap New Member
    2024 1794 Edition Tundra
    This comment almost made me spit out my drink. LMAO
    Markus[QUOTED] likes this.
