(dis)Connected Services
Discussion in '3rd Gen Tundras (2022+)' started by TundraDan723, May 14, 2024.
  1. May 14, 2024 at 6:06 PM
    TundraDan723
    TundraDan723 [OP] Not as new as I used to be...
    2023 Celestial Silver Tundra 1794 TRD CM
    I just had this happen for the first time today. I opened the app and it says "Unable to Activate Remote" (see pic below).
    I tried to "Activate" the service following the instructions and it just sits on the "Waiting for code from app" screen. I also tried to activate using a Code with the same results.
    The truck is just shy of 10 months old so the service shouldn't be expired yet.
  2. May 14, 2024 at 7:21 PM
    pwpblue
    pwpblue My ignor list just keeps growing!
    Greensburg,PA
    2023 Toyota Tundra Platinum ADV
    Hit your emergency button on the top dome light console. Options will get some help from the people that run the service. Button does not automatically dial 911 it's there for assistance and will walk you through it.
  3. May 15, 2024 at 6:00 PM
    TundraDan723
    This was a REALLY bad idea. I hit the button and it gave me three options, including Enrollment Services. I stated I wanted "Enrollment Services" and the next thing I heard was the Emergency Responders talking with someone at the Toyota center stating there was a silver Tundra in need of help. I was NOT going to try it again, so i guess I will just live with out the connected services...
  4. May 16, 2024 at 5:33 AM
    nodak67
    nodak67 New Member
    JR
    if i remember correctly when i had to do this same procedure to renew (i had the same issue as you and had to call sos CS), you have to listen to the verbal commands the SOS button gives, 1st part asks if you want to contact EMS, if you dont respond it goes to toyota customer service.
    pwpblue likes this.
  5. May 16, 2024 at 8:49 AM
    TundraDan723
    This is exactly what I did. The first question is something like, "Do you need emergency services?". I said no and it came up with a menu of options for roadside assistance, enrollment services, and something else. I am not sure how it went back to EMS. I am afraid to try it again!
  6. May 16, 2024 at 10:05 AM
    Ore43
    Ore43 New Member
    2023 Sequoia
    I had a similar issue with my Sequoia. I could not get the app to activate after my trial period was over and also could not get the QR code to show up, like you mentioned.
    I was able to resolve it by calling Toyota ( https://www.toyota.com/support/contact-us/ ) at this number: 1-800-331-4331
    At the automated prompt I told them I needed help with connected services. The person they transferred me to was able to get it to connect. Interestingly, he did have me push the SOS button, say “No” to needing emergency help and then say that I needed help with enrollment or connected services, I don’t remember exactly, but it was obvious from the list of choices. When I pushed the SOS button it of course disconnected me from the phone call with the Toyota help center, but he called me back to make sure it was resolved.
    pwpblue and nodak67 like this.
  7. May 16, 2024 at 10:08 AM
    40man
    40man New Member
    Reset the radio and it will give you the code to repair to your app.
    pwpblue likes this.
  8. May 17, 2024 at 6:22 AM
    TundraDan723
    Resetting worked, thank you! It took about 15 minutes total, including fixing my custom vehicle settings, etc.
    40man[QUOTED] likes this.
  9. May 17, 2024 at 6:23 AM
    TundraDan723
    Question: When the trail ends for connected services, is there any use for the Toyota App? What will it give you if you don't continue to pay for the subscription?
  10. May 17, 2024 at 6:55 AM
    Rex
    Rex New Member
    2023 SR5 CrewMax 4x4 TSS
    When you lease do you only get 1 year? Lease term?
