  1. May 10, 2024 at 3:56 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I assume the gears will make up for the power loss from the tires too. I'm on 4.56 and 33's. Someday I'd love to dyno my trucks
    Voss likes this.
  2. May 10, 2024 at 7:47 PM
    Riverdale21
    Riverdale21 Speed seeker
    OTP ATL
    06 DC SR5 Tundra TRD Off Road
    If I do gears before cams I'm not sure I'll get an apples to apples comparison on actual power gains from the cams. I feel like the change in gear ratio will change chassis dyno results.
    Maybe dyno after gear change but before cam to see how it effects power? Then I can compare baseline gear change vs cam change dynos.
    I think I just talked myself into gears and more dyno time.
  3. May 10, 2024 at 7:55 PM
    I’d definitely do gears last to get the proper dyno comparison.
    I’ve done most of the stuff you have so far, injectors, long tubes with x pipe duals out. But 4.88s woke the truck up for sure.
    Voss and 455h0le_dachshund like this.
  4. May 10, 2024 at 8:15 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    :yes: I think we have a winner, winner, chicken dinner!
    The Black Mamba and FrenchToasty like this.
  5. May 10, 2024 at 8:18 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Let's all dyno our trucks! Those of us with the power mods anyways. Normies need not apply... :D
    I wonder where I can get mine done and how much it would cost?
  6. May 10, 2024 at 8:54 PM
    Riverdale21
    OTP ATL
    The shop I go to is $50 for 3 pulls. They pick the best pull and give those results. The operator is always impressed with how consistent the 4.7 is run to run.
    If you're in NW GA, Moe's Speed Shop is the place to go.
    oscardog86, FishNinja, abcinv and 2 others like this.
  7. May 10, 2024 at 8:57 PM
    Do they specialize in speed? I feel like out here most people aren’t wanting or trying to attract trucks for dyno runs? Or they don’t care, 50$ is 50$
  8. May 10, 2024 at 9:05 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Good to know. I'll have to search around Houston and see what I can find on my side of town. $50 seems very reasonable. Do they do the pulls or do they let you?
  9. May 10, 2024 at 9:29 PM
    Riverdale21
    OTP ATL
    They do a bit of everything. Drag cars, dune buggies, street, carb, EFI, and boosted. But yeah, $50 is $50.
    They do the pulls. They drive the truck in, strap it down, and drive. I just watch.
  10. May 11, 2024 at 5:08 AM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    NW Georgia
    Ordered an air filter for a few cars from Rockauto; discount code worked -
    265676881199123591 expires June 7th 2024
  11. May 11, 2024 at 10:56 AM
    Voss
    Voss Not a new member
    2003 AC TRD 4x4
    Gave her a nice wash. Had some 2030 meal size critters splattered across the front end from last week’s trip. 51F4163C-381F-40BA-84A4-2DE1FC77ADD7.jpg
  12. May 11, 2024 at 11:15 AM
    BroHon
    BroHon Bitch in the Mitten
    Bro
    2000 SR5 AC 4x4 4.7
    Sketchy street barnacle
    About lost my camper shell glass! It is an old SnugTop, pretty decent. Another first for me, I've never messed with a camper shell/hardware before. Pretty straight forward easy to figure out.
    Everything got soaked/lubed with some Deep Creeper, as usual my shit is rusty af but we're makin it work :D:thumbsup: Uh, I took a lot of pics o_O
    Beefed up the Rivets one size, got the gasket all back in place correctly, Adjusted (bent) the closing bars and a little flap disking so it locks super easy. Lucky save, and a good fix today.
    20240511_112204.jpg 20240511_112150.jpg 20240511_113116.jpg 20240511_114026.jpg 20240511_120419.jpg 20240511_122437.jpg
    Looks like she snuck out for a bachelorette party with the ladies last night... :monocle:
  13. May 11, 2024 at 11:30 AM
    Voss
    2003 AC TRD 4x4
    Remember @RUSTYNUTS having this issue…
    Mr.bee and FrenchToasty like this.
  14. May 11, 2024 at 12:38 PM
    This seal is pulling out on my rear door.
  15. May 11, 2024 at 1:34 PM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    De-chrome! De-chrome!
    I've been obsessing over my chrome mirrors for years. At first I thought I'd paint them to match, but painting chrome never works well. Then I thought I'd wrap them...I even bought the material. But, I still needed to figure out how to pop the caps without breaking anything <sigh>. Then last spring I parked under a tree which coated my windshield and side mirrors with this resinous goo, which hardened and resisted washing, so I scraped it off with a razor blade. Worked great on the windshield, but guess what? The side mirrors are coated with plastic or some such thing, so now they have scratches! (BTW, the replacement heater mirror glass with backing costs ~ $50 each).
    I looked at Rock Auto for black replacement mirrors, and found one on closeout for $25 (left side only). It's mate for the right side cost $55.
  16. May 11, 2024 at 2:07 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Chrome isn't that hard to paint. Just gotta prep it right.
    Sand the shit out of it first. Then wipe it up clean with alcohol or wash with water and let dry. Then hit it with like three coats of self etching primer. Let dry. Then paint. Dry. Clear coat.
    oscardog86 and Voss like this.
  17. May 11, 2024 at 2:22 PM
    Voss
    2003 AC TRD 4x4
    Crap. I’m hearing clunking from the front driver side very similar to the passenger side I was hearing before changing the tie rod end links. The passenger side came loose just by undoing the top bolt.
    Wonder if maybe the new one didn’t set right on DS?… unless it’s LBJ
  18. May 11, 2024 at 2:48 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Yeah, That stuff is SO cracked and brittle, I am amazed I got it to stretch back over the glass. I cringed when I did it.
    I soaked it in DeepCreep for a few minutes min. still had to dead blow it in to the rivet alignment... a little harder than I wanted to.
  19. May 11, 2024 at 2:58 PM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    Really like the bumper and skid plate. Remind me where you got them or did you fab?
    Edit: Found it. Do you nake these for others or any build info to share if you don't mind a (n attempted) copy being out there?
    oscardog86 and Voss[QUOTED] like this.
  20. May 11, 2024 at 3:15 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    I was thinking that same thing how nice that looks with all the lights tucked in there, and the angles in the plate compliment the angles in the grill, Nice work @Voss :thumbsup:
  21. May 11, 2024 at 3:32 PM
    metalpete
    metalpete New Member
    ID
    2001 Tundra 4.7 4x4 SR5
    Toytech 2.0 Coilovers Camburg UCA's JBA headers Dynomax cat-back exhaust 90-221HD Leafs
    Are the boots busted or blown out at all? Maybe it just wasn't fully seated?
    Voss[QUOTED] likes this.
  22. May 11, 2024 at 3:36 PM
    metalpete
    ID
    I think I found a good spot for the controller. Right behind the kick panel. Gonna start the connection process, fingers crossed.
  23. May 11, 2024 at 3:57 PM
    Voss
    2003 AC TRD 4x4
    Evil Manufacturing made it for me. I made a mock one with cardboard mimicking the C4fab Tacoma bumper and simply asked for how I wanted the tubing to go. Evil Man made it happen. C3E82B9A-79B8-4C81-B91F-B9730FF153F4.jpg
    The skid plate is of own design. Little different, large with side protection and since it’s bolt on I can get behind it easily.
    Maybe one day I’ll learn how to make one on my own, that would be cool but don’t have those skills as of now.
  24. May 11, 2024 at 3:58 PM
    Voss
    2003 AC TRD 4x4
    Boots are fine, some oil on the boot on PS tho. I’ll find out soon enough if it’s simply not seating correctly.
  25. May 11, 2024 at 4:07 PM
    Good ol CAD(cardboard aid design)
  26. May 11, 2024 at 9:42 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Exactly the same except completely different. Lost my back glass indeed, but there was no saving it.
    So.... there I was, blazing thru the desert, offroad and about 60 mph. I was informed by one of my trail buddies (@alb1k) via radio (baofeng) that "you lost something". I should mention, this was not a smooth road by any means. Apparently, the latches had come undone, glass door opened and slammed shut so hard that it shattered the glass, and blew apart the frame. Half of the frame still hung from the camper. i looped back to recover the other half, and within a couple days, I rebuilt it with plexi.
    THEN, a year or so later, on another not so nice-n-smooth road, same thing happened. This time the entire frame ripped off. and again, I rebuilt with new plexi. BTW, decent plexiglass is not cheap. Roughly $110 each time, then add for all-stainless hardware, sealant, and possibly new struts.
    Neither of those times had me sweatin like the time I almost lost the entire shell off the side of a mountain. Savior credits out to @des2mtn and again, baofeng for that one
  27. May 11, 2024 at 10:04 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    The news was fear mongering about hail a couple days ago, and in a state of panic i moved my truck to protect the back glass. The rest of the truck probably coulda handled it, but i had to protect the caps hatch.
    RUSTYNUTS and Voss like this.
  28. May 12, 2024 at 5:06 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    After a week of not working my oil psi gauge rose from the dead this morning, like JC Zombie. Then it promptly died again five mins later
    bmf4069, shifty`, RUSTYNUTS and 2 others like this.
  29. May 12, 2024 at 5:30 AM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    I've worked with Polycarbonate quite a bit and I remember buying 4x8x1/4 for about a hundred, now its $250 or more. That had to have dropped quite a few pounds off the weight on that door/hatch:thumbsup:. Mine will prob never see that kind of use so this should hold. It's obviously not it's first Rodeo and you can see someone had already moved the fasteners to some new meat. I haven't looked extensively but Ide like to get all the locks working again. I have no key and the side window locks are rusted to shit, so I can't keep anything valuable back there.
  30. May 12, 2024 at 12:59 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    you have a glass roof hatch? interesting
    The sheet I was pricing is only 6x3x1/8" IIRC. 1 sheet 48"x96"x.220 (1/4") is about $340. OR, $390 if you want the bronze tint.
    Even with locks, I try not to leave too much money in the shell. I would rather have used 1/4", but the glass was not that thick, nor the channel that it lived in. I've considered a piece of sheet aluminum. Would be more secure, and I dont use my center mirror anyways. Gotta have a reverse cam with a shell. That's mando
    BroHon[QUOTED] likes this.
