Crank pulley removal & torque?
Discussion in '1st Gen Tundras (2000-2006)' started by Cag215, May 6, 2024.
  1. May 6, 2024 at 7:41 AM
    Cag215
    Cag215 [OP] New Member
    2002 Tundra
    Hello
    2002 ac cab 313k miles, original owner.
    Need advice, methods & tools to remove and then retorque the crank shaft pulley.for a timing belt replacement.
  2. May 6, 2024 at 7:53 AM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
  3. May 6, 2024 at 7:56 AM
    AZBoatHauler
    So.Arizona
    Pull the radiator and use an impact. No issues doing mine that way. Chances are the radiator is due for replacement anyhow.
  4. May 6, 2024 at 7:58 AM
    Be sure to get the Aisin kit, and from a source other than fleaBay/scAmazon. At that mileage, be sure to get the kit with tensioner to replace it, and might as well replace the pulleys too. "Better safe than sorry".
    AZBoatHauler likes this.
  5. May 6, 2024 at 8:02 AM
    Teutonics
    Teutonics BestGen Member
    2005 DC SR5 4WD 4.7L AX
    For pulley removal, an impact wrench zipped the bolt right out on mine (no holder tool needed). I did have to use a puller to get the pulley off the crank though. And I used the holder tool referenced above for reinstallation/tightening.
    One note: I did need the radiator out to get the impact wrench in the available space. Luckily I was replacing the radiator at the same time anyway, but removal isn't terribly difficult.
    One more note: My electric impact was too big (Ryobi) to fit in the space, so had to go old school with the pneumatic which would fit.
  6. May 6, 2024 at 8:07 AM
    87warrior
    87warrior Whiskey Tango Foxtrot
    Kansas
    2004 DC 2uz 4x4
    A compact Dewalt DCF921 with a standard impact socket will fit between the radiator and crank pulley. Yes, this compact impact will break the bolt loose.
  7. May 6, 2024 at 8:51 AM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    $7 harbor freight chained pulley holder, piece of old belt to protect the pulley, breaker bar and a pipe.
    Most cost effective way. Or dump the radiator and put in an impact. Most compacts don't have enough torque to zip off the crank bolt. You're gonna need a big Uga-duga.
  8. May 6, 2024 at 9:09 AM
    Cag215
    2002 Tundra
    You guys are great.. Thanks....
    I purchased the Aisin 021 belt kit with water pump from summit.
    I've been lurking on here and watching videos but some how missed the tool to hold the fly wheel. I did see where the guys were zipping the crank pulley bolt out with a impact, but thought, really can it be that easy.
    shifty` likes this.
  9. May 9, 2024 at 4:52 PM
    Sailor95
    Sailor95 New Member
    If ur impact can't do it, I bump started mine on a previous 100 series cruiser!
  10. May 9, 2024 at 5:27 PM
    FishNinja
    Lee
    06DC2wd
    you got giant balls my friend.
  11. May 9, 2024 at 9:08 PM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    just make sure that whatever sort of tool you use to hold the crank while you tighten the bolt, just make sure to use a torque wrench to get the correct torque.
    D5DE6F0E-48E5-44D1-A10C-C75DA0043C4E.jpg F22F30E5-960A-4CAE-B0D8-E0D9D4FFE994.jpg
  12. May 10, 2024 at 5:24 AM
    Cag215
    2002 Tundra
    Little update....
    I bought the recommended pulley tool to hold the crank fly wheel... torqued the crank bolt to 181 ft pounds ... ezypezy
    I'll do a write up of the timing belt change once I finish.....I have the fan, serpentine belt, radiator hoses and coolant to do.
