  1. May 7, 2024 at 9:14 PM
    daveeasa
    They are easy to measure. Wire is super accessible and no tool needed for the rear ones.
  2. May 7, 2024 at 9:23 PM
    VR6T
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
    Who made to OE O2 sensors for Yoda? Was it Denso or Asin?
  3. May 7, 2024 at 9:24 PM
    PenderBen
    PenderBen Forum lurker…
    Gulf Islands, BC Canada
    2003 Tundra AC 4x4
    Are iridium plugs worth it?
  4. May 7, 2024 at 9:25 PM
    VR6T
    Aren't all plugs coated in an iridium based alloy plating? Or is this my race car boogie side coming out?
  5. May 7, 2024 at 9:42 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Pretty sure denso
  6. May 7, 2024 at 9:43 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Only necessary for supercharger or VVTI
    oscardog86 and PenderBen[QUOTED] like this.
  7. May 8, 2024 at 1:05 AM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    Would hub runout cause odd shoe engagement? No brake pedal pulse? Easy to check runout..
    The Black Mamba likes this.
  8. May 8, 2024 at 3:10 AM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    When I did the full exhaust on our 00civic I allegedly did the capacitor-resistor thing on b1s2 (because I'm running a test pipe until I can afford a new cat:cool:) No codes:rolleyes:
  9. May 8, 2024 at 5:19 AM
    texoma
    texoma Triple C Chop Shop
    ChrisTopher
    Lago Vista, TX
    2018 Limited Tundra
    All the Chrome
    :benchpress::burnrubber::bikewheelie::mudding:
  10. May 8, 2024 at 5:41 AM
    No brake pedal pulsing. And only 77k original miles on the entire truck. Started around 75k miles.
    May as well get some CRC MAF cleaner, and some CRC Throttle Body cleaner and do those too. NGK on the plugs. I like to buy local w/Advance Auto, using coupon RMN15 to get 15% off on most things, for in-stire pickup, so I know I'm getting legit parts, today. Remember to pull the negative batt cable for at least ten minutes any time you're tinkering with fuel/air/spark items on the engine.
    Warning: Don't fuck around with O2 sensor part numbers. The part numbers change based on year, and often based on whether you're 4WD or RWD.
    Always look up O2 sensors at the Denso site directly: www.densoautoparts.com
    Be VERY careful when you pull your part numbers:
    • Make sure you're getting the "direct fit" part, not the "universal" (purple below)
    • Pay close attention to the POSITION i.e. "upstream" vs. "downstream" designations (blue underline below)
    • Look really carefully at the DRIVE TYPE descriptions for "RWD" or "4WD" (red underline below)
    • Look at the REQUIRED QUANTITY box can sometimes tell you if there's a RWD/4WD difference or not, or if you see "left" or "right" that's also a red flag you need to pay attention.
    • DO NOT use the following example to figure out the parts for your truck, because these sensors apparently vary by trim package! (SR5/Limited/etc.)
    Example.
  11. May 8, 2024 at 5:58 AM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    Completely different application, but i also used resistors to bypass the 02 sensors in my ktm 990 adventure. At a later point i use TuneECU to install a different map on my ECU to simply turn the 02 sensors off. But like i said, it’s a completely different, but it’s going to be somewhat similar process.
  12. May 8, 2024 at 6:06 AM
    Rich is O2 sensors fault, as evidenced by the CEL. Cats aren't cleaning unburnt fuel, they decrease NOX and CO primarily. If your O2 sensors fault, the default program for the computer is to run rich. Think you still have an O2 sensor problem.
  13. May 8, 2024 at 6:32 AM
    kentuckyMarksman
    kentuckyMarksman New Member
    Got the leaky valve cover gaskets taken care of. Only broke 2 bolts...
    artsr2002, ToyotaDude, Voss and 6 others like this.
  14. May 8, 2024 at 6:45 AM
    Take longer to drill them out than to do the rest of the job? :rofl:
    @txagg still holds the record on most VC bolts broken, as I recall...
    Voss likes this.
  15. May 8, 2024 at 6:48 AM
    kentuckyMarksman
    Sure did.
    Voss and shifty`[QUOTED] like this.
  16. May 8, 2024 at 7:05 AM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    closed your hood? :boink:
  17. May 8, 2024 at 7:21 AM
    oscardog86
    oscardog86 New Member
    Southern California
    So I removed my stock washer fluid reservoir and cut my bumper area a bit. I cut it at an angle and think it looks pretty good. But my other car was in front of the truck so couldnt get a good view of the front to see how I like it. Ill try to take a picture today to get a better view of it to share with you guys.
    My question is: Can I remove the fluid reservoir pump/sensor and just drill a hole in any other container and mount it up? Id rather find a container and reuse my pump/sensor rather than buy another one if possible. Although, new reservoirs with the pump/sensor arent very expensive either for generic ones. But figured why buy a new one when I have a perfectly good one i can reuse.
    Unless anyone here wants my stock washer fluid reservoir before I hack mine up?
    Voss likes this.
  18. May 8, 2024 at 7:24 AM
    FishNinja
    Lee
    06DC2wd
    pretty our oem washer fluid res. And pumps are worth gold? Or am I wrong?
    oscardog86[QUOTED] likes this.
  19. May 8, 2024 at 7:27 AM
    oscardog86
    Southern California
    In that case, lets start the bidding at $100! Haha jk
    bmf4069 and 455h0le_dachshund like this.
  20. May 8, 2024 at 7:47 AM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Yeah, I've looked at what it does in live data and it doesn't look quite like a normal reading would be. Rolls a bit higher, but must be within parameters
  21. May 8, 2024 at 7:47 AM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    I might have to look into that...
  22. May 8, 2024 at 7:51 AM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    You think I need to replace em again?
  23. May 8, 2024 at 7:55 AM
    I think the O2 sensor system including wires and sensors should be inspected and tested. Make sure your sensors are bad before replacing them.
  24. May 8, 2024 at 7:57 AM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    I'll gather the deets tonight when I arrive back to the compound and pm you. Allegedly
  25. May 8, 2024 at 8:00 AM
    Interesting, while looking something else up I RTFM and notices this "clip" over on the left, which I don't believe my truck has/had when I swapped pads a few days back.
    Also, just to put this one to bed once and for all, the FSM only shows one "anti-rattle" spring and it's top-side on the caliper, closest to the hood. And (2nd pic) am I nuts here, or does the 05-06 FSM only show greasing in one spot? (EDIT: NOPE! I'm nuts, there's definitely more, it's lithium/soap base in the wheel cylinder, and normal high-temp grease everywhere around all other contact points and the lowers. Time for another cup of coffee!)
    Voss likes this.
  26. May 8, 2024 at 9:47 AM
    Voss
    Voss Dust in the wind
    Valod
    2003 AC TRD 4x4
    I used my old pump on the new tank. Think they’re universal
  27. May 8, 2024 at 10:03 AM
    oscardog86
    Southern California
    You bought a tacoma tank correct? That one didnt come with the pump?
    Voss[QUOTED] likes this.
  28. May 8, 2024 at 10:08 AM
    Voss
    Valod
    2003 AC TRD 4x4
  29. May 8, 2024 at 10:27 AM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    455h0le_dachshund likes this.
  30. May 8, 2024 at 10:43 AM
    Looks like hopping under acceleration came back today and threw a misfire code for cylinder 5. Pulled a cheap AA1 reserve coil aside out of what I have left and threw it along with my craftsman ratchet/socket kit and my actron OBD2 reader in the back seat and headed back to work.
    455h0le_dachshund and des2mtn like this.
