General Supercharger Thread
  1. May 5, 2024 at 12:21 PM
    snivilous
    SW UT
    300k+ Supercharged 2008
    You are on the money with everything you said. Increasing the tube size and going to the new MAF result in the exact same outcome. The reason to go with the MAF instead of an intake is for the simplicity aspect as far as I'm concerned. In this case the guy has a fancy UMP intake that trophy trucks and prerunners use, so needs fabrication to increase the tube size. That's the same case with some other people I know who have got the Turbokits MAF, they have a 4.5" intake but there's no 5" options readily on the market so the only practical option is the MAF. The flip side is someone like @reywcms where I built him a 5" intake, but he was going to a huge throttle body and changing a bunch of stuff so for him it made more sense to get a 5" tube made for his final goals, even though the 5" tube (just the tube, not the rest of the intake) from me cost more than just the MAF.
    And since the outcome is the same, they both require rescaling. So the tuning is essentially the same, it's purely how you want to go about the hardware side of things to get the voltage back in range.
    Fastlane47, nags, Saltyhero13 and 6 others like this.
  2. May 5, 2024 at 1:00 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Just a side note when installing the @TurboKits.com fpr and it is too close to the maggy 2650 body. It needs a -6 orb to -6 orb 45 degree or 90 degree fitting to clear the 2650 side by the return. May need a bracket mod to support weight vibration?
  3. May 5, 2024 at 1:05 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    10-4, it's a work in progress. :thumbsup:
  4. May 5, 2024 at 2:12 PM
    bflooks
    bflooks New Member
    Metrowest MA
    I have nothing to contribute that hasn't already been discussed, except that I am beyond happy that our worlds are blending nicely and that I'm glad there's plenty of opportunity to share the same products in all of our installs.
    For obvious reasons, I'm a @TurboKits.com fan boy, but it's nice seeing other FI implementations recognize the amount of work they've put into the platform and the quality of their product offerings. They carry different risks than most of us since they are for profit, and I'm thrilled to see the recognition that their R&D is for the better of the community. Love seeing them get kudos, and I appreciate everyone for having open minds.
    Thanks for listening. Rock on!
  5. May 5, 2024 at 2:29 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    While on the TK fanboi tangent, I had a 100000% terrific experience!!!
  6. May 5, 2024 at 2:33 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Hopefully throw mine when im back end of the week and see how it clears
    e30cabrio, HulkSmurf14 and bflooks like this.
  7. May 5, 2024 at 2:33 PM
    bflooks
    bflooks New Member
    Metrowest MA
    Jesse is no joke and a genuinely cool dude. What you see online is absolutely what you get in person, too. Good people.
  8. May 5, 2024 at 7:36 PM
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    I ordered the dongle and software off Amazon. The software comes on a mini disc so you need a cd reader. It's a cracked version but they give you instructions on how to use it. Worked for me. The only thing you can't do is connect to techstream servers for any software updates.
    I think I still have the files downloaded on my laptop too
    https://www.amazon.com/dp/B0CPXKPM1W
  9. May 6, 2024 at 2:21 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Seems the guy showed a rcf picture but part is for lx570. And the cooler was just a 4 row. What a joke.
    Hmm. Back to drawing board. No cheap option unless that gx460 works. Is it just enlarging the diameter of the ports?
  10. May 6, 2024 at 4:36 AM
    TurboKits
    TurboKits New Member
    Our issue was purely when we went from the MPVI2 to the MPVI3, we had to move the license.dat file out of the HPT folder in order for it to connect and synch the new MPVI3. Once we did that it and the MPVI2 with all the other VINs coded to it, work fine from the same laptop.
  11. May 6, 2024 at 4:38 AM
    TurboKits
    Got your PM as well. I'll see what I can find and get it up to you ASAP. Thanks again :)
    Wynnded and Mdl[QUOTED] like this.
  12. May 6, 2024 at 4:49 AM
    TurboKits
    Love it! We'll keep them flowing as fast as possible. We did get our shipment in, the site hasn't been updated, but the ones just ordered over the weekend will go right out :)
    And we are very happy to help the community.
    :bananadance:
    Yes, our high flow MAF stops the requirement to move to a larger MAF tube for higher flowing set ups. So you guys are spot on!
    Thanks Bri, we are also very happy to be working with you on this testing. You have been awesome to work with, excited, not afraid to be hands on and getting tons of great data for the community :)
    Thanks bro!! Glad we could help!
  13. May 6, 2024 at 5:21 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    It's @Wynnded who needs to have the fpr move away from the body of the 2650. I figured you would have access to to a range of fittings. A 45 deg fitting or 90 deg. Even using the fuel rail adapter with a -6an fitting to a 90deg -6 orb. Just some ideas?
    Or just this...
  14. May 6, 2024 at 9:48 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Raptor R and TRX’s in review is a nice feeling lol
  15. May 6, 2024 at 10:08 AM
    pursuit2550
    pursuit2550 New Member
    So with this you can do everything TS can do except update the ECU with the latest calibration? I wouldnt mind changing some settings.
  16. May 6, 2024 at 10:19 AM
    M3Tundra-JK
    Scott
    2005 GX470
    Yup! Part of using the cracked version is disconnecting from the internet so the software can't connect to Techstream servers, and then running a second program that, sort of injects fake credentials so Techstream program starts up. I don't think it works on newer OS like Windows 11
  17. May 6, 2024 at 3:38 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    @TurboKits.com looking forward to installing the new MAF!
    @snivilous the 2.0 pulley is a freight train! Right on the +2psi. I did touch 14.2 but that was at max...
  18. May 6, 2024 at 3:40 PM
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    absolute load 195%?!?
    Mdl likes this.
  19. May 6, 2024 at 4:32 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I did hit 200.8%. 3rd gear at 13psi 4500rpm. It's pumping some air.
    e30cabrio and helidave like this.
  20. May 6, 2024 at 5:18 PM
    snivilous
    SW UT
    I've started logging Air Load since absolute load seems to go insane and I can't find an obvious answer to how it's calculated. But the MAF maxed at 512 is like 160% air load which coincides with what the TRD tune sets the load values on the Y axis to. And with some fudging 512 divided by the stock MAF flow value ends up at 160% too.
    With that said, absolute and air load mostly parallel each other until you really get high in the throttle and then absolute load runs away and diverges from the MAF based air load calculation.
    reywcms, armyoffoo, e30cabrio and 3 others like this.
  21. May 6, 2024 at 5:31 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Thanks. When the maf was maxxed I could see it start leaning out. Just wanted to see where it was at to set some limits but looks OK .
  22. May 6, 2024 at 5:44 PM
    snivilous
    SW UT
    So time for a small run of 1.9" pulleys? I left room to go further :D
  23. May 6, 2024 at 5:54 PM
    NatesNightMare
    NatesNightMare Is what it is
    Pinetop Az
    For the likes of us :rofl:
  24. May 6, 2024 at 5:56 PM
    NatesNightMare
    Pinetop Az
    Funniest part some dick in another thread tried to claim as soon as I SCed I lost all reliability and ill never see 500k mi haha I said even if I had my truck to 500k lol then said theres a few guys over here with trucks pushing 300k
    HulkSmurf14, Saltyhero13 and Mdl like this.
  25. May 6, 2024 at 6:06 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Well Hot Dog! :rofl:
  26. May 6, 2024 at 6:19 PM
    blenton
    blenton New Member
    :rofl::rofl::rofl:
    reywcms and Mdl like this.
  27. May 6, 2024 at 7:05 PM
    Vendeta2k
    Jay
    Bozeman, Montana
    2018 Limited Cement CM
    Getting ready to purchase the innovate PSB-1. Where is the proper place to have the bung welded in? Picked up the Tacoma/tundra vent mount as well
    Mdl and HulkSmurf14 like this.
  28. May 6, 2024 at 7:06 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    If you keep it close to stock and use it conservatively it will last...famous last words.:rolleyes:
  29. May 6, 2024 at 7:18 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    On the maggy 2650 the boost port was a pain to get the brass plug out. Take it easy as some stripped theirs. Need a barbed nipple.
    Innovate says to have it 24 inches fron head and mounted between 9 and 3 o'clock. Keeps condensation off sensor.
    Most put theirs on passenger side in front of primary cat. Easy to weld bung in. Some mount map sensor on firewall.
  30. May 6, 2024 at 11:44 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Ha!
    @snivilous Didn't @ViktorG have a 1.9? Hmm, I would still be interested 15psi. Ha ha
    Just need my spare block...
