Supercharger Running Lean
Discussion in 'Performance and Tuning' started by mralanle, Apr 9, 2024.
  1. May 1, 2024 at 6:54 PM
    #121
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, solid Offroad engine mounts, DIY Traction Bars, Tuning by snivspeedshop.com
    Not sure where it says that. Just going by those that had permanent 60psi mod.
    Post a pic of what it says in Toyota manual to remove relay?
    Edit: I see the confusion from the previous post!
  2. May 1, 2024 at 7:01 PM
    #122
    mralanle
    mralanle [OP] New Member
  3. May 1, 2024 at 7:09 PM
    #123
    mralanle
    Also going off this, the prong that needs to be grounded is facing the front of the truck right? Not towards the rear
  4. May 1, 2024 at 7:35 PM
    #124
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Just to clear things up.
    If you remove the relay you will need to jumper wire pin 3 and 5.
    Or keep the relay and wrap a grounding wire on the leg shown. This will ground it out at key on. Both do the same thing. You have to attach the other end to the body so it grounds out.
    Then test to see if it stays at 60 psi and better, richer afr's at wot or shifting. Whichever gave you lean condition.
    reywcms likes this.
  5. May 1, 2024 at 7:37 PM
    #125
    mralanle
    Gonna try it. So is the grounded wire on the tab that’s facing the front of the truck or the rear? Just so I don’t mess anything up
  6. May 1, 2024 at 7:56 PM
    #126
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Make a jumper wire for vsv fuel pump relay.
    Plug it in the where the 2 copper colored prongs go.
    Turn key on and you should hear your pump on. Start and verify pressure and test drive.
    reywcms likes this.
  7. May 1, 2024 at 7:58 PM
    #127
    mralanle
    And if I were to keep the relay and ground the prong, is it the prong facing towards the front of the truck?
  8. May 1, 2024 at 8:01 PM
    #128
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Yes.
    Then ground the other end to ground point.
  9. May 1, 2024 at 8:29 PM
    #129
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    Magnuson has you remove the relay so it stays in 45psi mode all the time. They tell you not to run the supercharger on E85, so no need for it to switch pressures for "flex fuel".
    Seems like it would be better to include a jumper and have it at 60psi all the time, but they probably figured that 45psi is enough for the stock pulley on their canned tune.
    Mdl likes this.
  10. May 1, 2024 at 9:00 PM
    #130
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Thanks for the clarification!
  11. May 2, 2024 at 8:26 PM
    #131
    mralanle
    Tested it today, no difference sadly :(
  12. May 2, 2024 at 8:33 PM
    #132
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Ok. Before thinking of fuel pump. Have you tried boost referencing? Hook your boost port up to the fuel pressure regulator.
    Other FFV members will ground relay and boost reference. In all honesty the supercharger manufacturers should recommend boost referenced. Only one does, Whipple. It's worth a try.
  13. May 2, 2024 at 9:05 PM
    #133
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Also. Can you hear the pump click on with key on not start?
  14. May 3, 2024 at 1:35 PM
    #134
    mralanle
    I only hear a click when I put the relay in and out. Not when I touch it to a ground. Also did boost reference. Made AFRs a tad richer but still losing pressure.
  15. May 3, 2024 at 2:31 PM
    #135
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Last thing before suggesting a different pump would be to make the jumper wire without using relay.
    As I stated earlier @e30cabrio battled fuel pump pressure issues with the walbro 450 for a while. He is FFV too.
    He installed the deatswerks dw300 fuel pump and it solved his issues. He has the fuel line mod and grounded relay with boost referencing.
    Just a thought...
    reywcms likes this.
  16. May 3, 2024 at 2:34 PM
    #136
    mralanle
    Is it technically the same as grounding the relay or does this do something else?
  17. May 3, 2024 at 2:42 PM
    #137
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    It does...but removes relay so it's a direct ground. No chance of any outside interference.
  18. May 5, 2024 at 12:09 PM
    #138
    mralanle
    Found a leak in the OUT line in my fuel canister. Replaced it, no more leaks. AFRs are better but fuel pressure dropping to about 43 still which is what non flex guys are running so it’s tunable but wondering why it’s dropping like that.
    reywcms likes this.
  19. May 5, 2024 at 12:23 PM
    #139
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    That's good. Did you try the jumper wire method besides the relay ground?
  20. May 5, 2024 at 12:25 PM
    #140
    mralanle
    Not yet, so whoever did the jumper wire method also ran the non flex fuel lines like what I’m doing?
  21. May 5, 2024 at 12:27 PM
    #141
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Yes but not using the walbro 450 and is at 60psi.
  22. May 5, 2024 at 2:23 PM
    #142
    mralanle
    Nothings changed, is he on here? Could he confirm he was around 60 PSI even under load?
  23. May 5, 2024 at 4:11 PM
    #143
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    @ARES35 @e30cabrio anymore input?
    Last item could be the fuel pump. Lots switch to dw300. Be it the pump install or wiring causing it to lose psi.
    ARES35 likes this.
  24. May 6, 2024 at 5:46 AM
    #144
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    ARES35 likes this.
  25. May 6, 2024 at 8:14 AM
    #145
    ARES35
    ARES35 New member for life
    Mile high
    Can't speak on other FP's, still run the stock FFV pump. Boost reference and the jumper with 750 injectors A/F is pretty consistent. Only other thing I should mention is I do reset fuel density alot, almost every fill up to keep consistency.
    Mdl[QUOTED] and helidave like this.
  26. May 8, 2024 at 7:19 PM
    #146
    mralanle
    Are you still running the flex fuel lines?
  27. May 8, 2024 at 8:33 PM
    #147
    ARES35
    Mile high
    All stock.
