Just bought my first Tundra (hoorah)
Discussion in 'New Member Introductions' started by Billykid77, May 5, 2024.
  1. May 5, 2024 at 5:11 PM
    Billykid77
    Billykid77 [OP] New Member
    2004 Tundra Limited
    Found a needle. Searched for a little over 2 months when suddenly she fell from the sky. Very grateful to the seller for saving it for me as he had numerous calls and offers above asking price. I made sure to get a quick jump and send a deposit right away.
    2004 4x4 DC Limited.
    -81k
    -Oil, ATF and Coolant: pristine
    -Body / Frame: 9.5/10
    -Southern truck
    -Undercoated (per seller - owner was just that kind of person)
    -Timing belt: @75k
    -Not a leak anywhere
    -4wd works perfect.
    -The tires are still hairy
    All original, and all service was done by Toyota w/ records.
    upload_2024-5-5_18-37-33.jpg upload_2024-5-5_18-38-9.jpg upload_2024-5-5_18-38-9.jpg upload_2024-5-5_18-38-9.jpg upload_2024-5-5_18-38-9.jpg upload_2024-5-5_18-38-9.jpg upload_2024-5-5_18-38-9.jpg upload_2024-5-5_18-38-9.jpg upload_2024-5-5_18-38-9.jpg
    After reading shifty’s “So you wanna buy…” post,
    the gaskets/seals come to mind. This truck was driven an average of 4k miles/ year. As said there are no leaks. I would expect, if I had an issue w/ seals, I would see something. Drove it home 6 hrs and not a rattle or burp of any kind.
    I like how the truck shifts. Not soft, but not rough by any means. I can feel it engaging as it should.
    Upgrades: I wouldn’t mind modernizing the truck in a subtle way, without disrespecting it. It deserves only the best care and the seller’s only wish was that it would go to a responsible owner that would take great care of it. There is some sentimental value here since it was a family member’s who passed.
    I want to honor that and at the same time make it my own.
    Being mindful of: ball joints, coolant / trans oil, and this: “4WD trucks have ample grease zerks on the driveline and need to be lubed with moly-fortified NLGI 2 grease every 5k-10k miles”, as well as regular maintenance.
    I am looking for input for the things I may overlook w/ specifically the 2004 1GT.
    05-06 have a different trans and VVT I believe?
    I couldn't really find much on the 2004 model - which may be a really good sign.
    I’ve installed a Kenwood DMX958xr w backup cam.
    Not a fan of the faux wood dash bezels but will not compromise them for a different look. Maybe I will find black in good shape at a junk yard but dreaming. Wish there was an alternative that would not damage the panels.
    Lights: I have read a little info on LED projectors, which I would prefer, but from what I understand, I may need additional wiring / harness? I need to research more.
    Lift:
    I have seen some very nice lifts that are subtle but give the 1GTs more of a modern truck look.
    -Bilstein? Have not ventured down this road yet.
    -Tire size? 32s? 33s?
    There seems to be varying opinions, but
    I do not want rub, and will not cut or hammer anything.
    I have a lot of homework to do and plan on doing it, but if anyone has a 2004 and already went down this road, suggestions and do's / don'ts are certainly appreciated.
    Side note, that rear window is outstanding.
    HulkSmurf14, OHwendTrd, MS22 and 2 others like this.
  2. May 5, 2024 at 5:15 PM
    Cruiserpilot
    Cruiserpilot New Member
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    Well now, that was worth the wait! Beautiful truck!
    Billykid77[OP] likes this.
  3. May 5, 2024 at 6:29 PM
    Welcome from NY.
  4. May 5, 2024 at 6:34 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Wow what a nice looking gen 1
  5. May 5, 2024 at 7:09 PM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    Looks great! You can tell it has been well kept care of.
    2004 was the first year of the Double Cab. 2005/06 brought changes across with the updated 4.7 and 5 speed transmission.
    However, your truck has a transmission dipstick, unlike the 2005-06 trucks. That makes drain & fills a lot easier. The 2004 transmission was solid and generally trouble-free.
    HulkSmurf14 and Billykid77[OP] like this.
  6. May 5, 2024 at 7:58 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome from LA (Lower Alabama)! True unicorn! Beautiful truck!
  7. May 5, 2024 at 8:04 PM
    Randydw
    Randydw New Member
    Randy
    Ozark,mo
    2021 platinum crew cab
    Very nice, traded in my 04 for a 21. Same condition as that one but had double the mileage. But yea very nice keep that thing as long as u can.
  8. May 5, 2024 at 8:07 PM
    Randydw
    Randydw New Member
    Randy
    Ozark,mo
  9. May 5, 2024 at 9:30 PM
    Markus
    Markus Hermitic Member
    Mark
    Boring, MO
    2 1794 Tundys 2014 and 2023 AG TRD
    A few
    Good find. Welcome from West MO
