1.5 inch spacers for 20 inch wheels to give the proper offset for Superlift 6 inch lift
Discussion in '3rd Gen Tundras (2022+)' started by WhiteDevil1978, Apr 18, 2024.
  1. Apr 18, 2024 at 9:55 PM
    WhiteDevil1978
    WhiteDevil1978 [OP] Ye Olde White Devil
    Dustin
    North Carolina, 'Murica
    2023 Tundra SR5 TRD Off-Road
    6 inch lift, 37 inch tires, Badlands Apex 12,000 lb winch, Fab Fours concealed winch mount with 30 inch LED, Prinsu roof rack with RC 40 inch LED and 10 inch RC LED's on sides, Auxbeam 12 switch controller, Heretic ditch lights, RetraxPro XR bed cover, Elevate bed crossbars with additional bar that connects them, Pedal Commander throttle control, overlanding solar array (2) LiTime 230ah batteries, Renogy 40 amp DC to DC charger, LiTime 60 amp MPPT, LiTime 40 amp LiFePO4 AC to DC charger, Renogy 400 watt suitcase panels
    I have a 2023 Tundra TRD Off-Road with the factory 20 inch wheels. Factory offset is +55. I have a 6 inch Superlift kit sitting on the back porch just waiting to be installed, but the kit requires an offset of +18 to +20, which I have learned is necessary due to a bracket that is part of the lift kit actually hitting the wheel.
    A 1.5 inch wheel spacers SHOULD give me nearly the exact numbers I need to be able to use those factory 20 inch TRD wheels, which I absolutely LOVE, by the way.
    Has anyone else installed the 6 inch Superlift kit #1026 on their Tundra and ran this setup successfully? I'm not sure if it is pertinent information, but I also plan on running Nitto Ridge Grapplers that are 37x12.50 inches on the factory wheels. Nitto says that 20x8 wheels is acceptable for that tire. I am also aware that a little trimming is necessary for a 37 inch tire, even with a 6 inch lift. I am not against an even wider spacer, say 2.0 inches, but that would place me firmly out of the recommended offset range of +18 to +20. I don't know if it is OK to go even further with the offset or not. 2 inch spacers would give me an offset of around +4.
    If anyone sees a flaw in my planned setup, especially the wheel spacers, please feel free to chime in. Thanks in advance!
  2. Apr 19, 2024 at 8:47 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    This should be helpful
    WhiteDevil1978[OP] likes this.
  3. May 4, 2024 at 10:03 PM
    WhiteDevil1978
    Dustin
    The setup I mentioned above worked perfectly and the truck is on the OEM 20 inch TRD wheels, 6 inch Superlift kit, Nitto Ridge Grapplers and 1.5 inch spacers. This thing turned a head or two bone stock, but everyone who likes trucks comments now! I couldn't be happier with the results!
    pwpblue, blenton and Coal Dragger like this.
  4. May 4, 2024 at 10:51 PM
    Coal Dragger
    Coal Dragger New Member
    Kung Fu Dick
    Go get it dirty, and for everyone’s sake no more pictures in mall parking lots… even if that is the natural habitat for most lifted trucks.
    PBNB and MrKABC like this.
  5. May 5, 2024 at 12:12 AM
    WhiteDevil1978
    Dustin
    That photo was 5 minutes after I got the truck back from the lift. I was in Bojangles parking lot. A man has to eat!
    PBNB likes this.
  6. May 5, 2024 at 12:29 AM
    blenton
    blenton New Member
    :rofl::rofl::rofl:
    Man, it’s been a minute since I’ve been to a Bojangles. Now I want some chicken an biscuits…
    Truck looks awesome! Glad it worked out.
