  1. May 3, 2024 at 8:54 AM
    Oh, I'd totally do it if it was cool enough and worked in such a tiny format.
  2. May 3, 2024 at 8:57 AM
    VR6T
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
    I just cropped down the face section and then expanded it till the site was like ok this is fine lol. I was trying to get the moon in mine but nooooo stupid small pixel allowance
  3. May 3, 2024 at 9:14 AM
    I feel like you could probably use the one you've got as a seed image, then ask AI to put a TX flag behind it.
    VR6T[QUOTED] likes this.
  4. May 3, 2024 at 9:23 AM
    The Black Mamba
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
  5. May 3, 2024 at 9:36 AM
    VR6T
    Jesus AI is on point today
  6. May 3, 2024 at 9:39 AM
    What about the kid on the right in the third one. Who’s arm is on his shoulder?
  7. May 3, 2024 at 12:29 PM
    The Black Mamba
    DFW
    Imma keep it stock
    Who was it that made a timing belt belt? @JakeJake @metalpete ? Search sucks in this instance
  8. May 3, 2024 at 12:52 PM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
  9. May 3, 2024 at 12:54 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Voss, bmf4069, FrenchToasty and 3 others like this.
  10. May 3, 2024 at 12:55 PM
    The Black Mamba
    DFW
    Imma keep it stock
    FrenchToasty and des2mtn[QUOTED] like this.
  11. May 3, 2024 at 1:37 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
  12. May 3, 2024 at 4:11 PM
    VR6T
    Not my best work, but they're at least average good to low serious fabricator quality welds.
    That and this Miller Matic MiG unit hasn't been service since they bought it 4 years ago. The filler metal sheath is just fucking filthy. Not excuses, just statements of fact IMG20240503174939.jpg IMG20240503174948.jpg
    Voss, bmf4069, BroHon and 1 other person like this.
  13. May 3, 2024 at 4:22 PM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    I need to learn how to weld. The amount of money it would save me is unreal.
    455h0le_dachshund likes this.
  14. May 3, 2024 at 4:24 PM
    VR6T
    I cleaned some of the shit out of the machine, and this is what I'm getting now.
    Voss, bmf4069, BroHon and 3 others like this.
  15. May 3, 2024 at 4:27 PM
    Don’t you dress your welds?
  16. May 3, 2024 at 4:28 PM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    flux125 from the freight. Dirt cheap and gets it done. Unless you wanna go with gas. But truthfully flux core sticks metal together and is a cheap starting option while till being able to make structurally sound toys
    khooiii[QUOTED] and BroHon like this.
  17. May 3, 2024 at 4:28 PM
    FishNinja
    Lee
    06DC2wd
    still some porosity. Kinda odd for MIG
    edit: it actually just looks like porosity where you start/stop. You bringing that back a bit before letting off the tiger?
  18. May 3, 2024 at 4:33 PM
    FishNinja
    Lee
    06DC2wd
  19. May 3, 2024 at 5:18 PM
    VR6T
    If it was critical structural I would immediately. But seeing as this for a pig feeder I'll do it after it's all welded. Just a wire wheel, no chemical dressing.
  20. May 3, 2024 at 5:43 PM
    NUDRAT
    NUDRAT [OP] 6 lug life
    SW CT
    Between 'Ridgelines'
  21. May 3, 2024 at 6:55 PM
    VR6T
    Whelp after an hour of diagnosing cleaning fixing and replace parts I got the MiG back up and running at work. Had to grind a weld out for the first time since 2015 when I was in advanced weld school for the Navy, 4955 for fucking life. Don't know what the issue was, but it was shorting the wire feed and pulse arcing. It's not supposed to do either of those things.
    Oh and I forgot my cover gas on a test weld. But for no gas that root was fucking mint.IMG20240503184220_BURST006.jpg IMG20240503184236.jpg IMG20240503203134.jpg
  22. May 3, 2024 at 6:59 PM
    The Black Mamba
    DFW
    Imma keep it stock
    Much better :thumbsup:
  23. May 3, 2024 at 7:25 PM
    VR6T
    Yeah they're even better now that I fucked with the wire speed. What ever was causing that binding had been there for a minute cause they had it cranked all the way up, and it never seemed as fast I remember. That "good" weld was me trying to keep up with the wire speed after the cleaning. They look as they should now.
    BroHon likes this.
  24. May 3, 2024 at 7:37 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Back in 15 I did these for a project, but our welder was old AF and the lead was clapped out so bad it had to be laid out in a gentile loop or the feed was horrible. Armature hour for sure, but I love using the welder.
    Voss, bmf4069, VR6T and 1 other person like this.
  25. May 3, 2024 at 7:42 PM
    VR6T
    Easy fix a new liner and feed Paul's with a new tensioner spring would have done you right
    BroHon[QUOTED] likes this.
  26. May 3, 2024 at 7:55 PM
    VR6T
    Fucking dialed
  27. May 3, 2024 at 7:55 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Looks like the gas feed wasn't good maybe, I have forgotten to turn it on and it's way worse than that spittersputter though.
    Can you get a decent used MIG (that needs some love) for $500-700, It's on my list of post retirement wants. Recommend a brand?
  28. May 3, 2024 at 7:58 PM
    Azblue
    The Dirty T ( ^_^)_且
    For the money, the Harbor Freight Titanium ones are a fine machine.
    VR6T and BroHon[QUOTED] like this.
  29. May 3, 2024 at 8:07 PM
    VR6T
    Shit you can get a HF Titanium for that price new, and they good welders. I got the MultiProcess Titanium purse welder and did the foundation welds at my old job on a 80x40 steel warehouse structure. Welded the foundation roots in at 154 amps and then did all the requisite filet, cover and cap passes at 125. Sure I went into duty cycle, but what welder wouldn't at 150+. Welds are still there as is the building
    Azblue and BroHon[QUOTED] like this.
  30. May 3, 2024 at 8:15 PM
    VR6T
    And if I was gonna do it again I would have just got that Vulcan 209 AC DC multi process tig welder. 1000 bucks and will absolutely hang with a Lincoln Miller or an ESAB
    Azblue and BroHon like this.
